Page 38 of 39 FirstFirst ... 2836373839 LastLast
Results 926 to 950 of 965
Thread: HF tools that don't suck
  1. #926
    Feb 2017
    Re: HF tools that don't suck
    I've had a set of these Berger MIG pliers for about 6 months now. They are very nice. They cut cleanly, the jaws align properly and they seem to be properly hardened. I'm very happy with them.
    https://www.harborfreight.com/8-in-m...ers-63513.html
    Home tinkerer and old tool junkie
  2. #927
    Mar 2005
    Under a Rock
    Quote Originally Posted by ndnchf View Post
    Mine donít say berger
    But I bought them at Harbor freight about 10 years ago.
    They do the job.
    https://uploads.tapatalk-cdn.com/201...0f994823bb.jpg
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  3. #928
    Feb 2017
    Berger is the new version that came out last year. I had the old ones, these are much better.
  4. #929
    May 2010
    Sparks, NV
    I have those red handled ones and a Set of the channel lock branded ones. The channel locks do have visible quality difference but I find with HF stuff you just look at every pair on the rack and find the ones that align correctly etc.
  5. #930
    Mar 2005
    Under a Rock
    Define better.
    I donít know how much you could ask from Mig pliers.
    If you want them to pull nose hairs thatís a different story.
    But I usually only use them to snap off a piece of wire or do a quick clean out of the end of the nozzle.
    I donít know how much better I can get at that.
    Hypertherm PM 45
    HTP 221
  6. #931
    Jun 2014
    Has anyone tried their mini mill ? I've been contemplating buying one but don't know anyone who has used one . They don't have a display model in the local store to me .
  7. #932
    Aug 2018
    'ta town, KS
    I use Bridgeport..
    Mac
  8. #933
    Jun 2014
    If I had the knowledge, space and the dollars ...................I would buy a Bridgeport. Thanks for your useless comment...................
  9. #934
    Dec 2009
    Stevens Point, WI
    I have been very pleased with the HF power pipe threader so far. No idea on longevity yet but it does have good power which is a bit odd for an electric HF tool.
    https://i.imgur.com/1aX6krI.jpg
  10. #935
    Feb 2017
    Cleveland, OH
    Quote Originally Posted by bfjou812 View Post
    I have not, but I have seen others comment that it's not well made. Plastic gears. Low torque motors. Check out Blondi Hacks on Youtube. The one she uses looks decent for the money.
    Hobart Handler 175 MIG
    Primeweld 225X TIG
    https://www.mylilmule.us
  11. #936
    Dec 2016
    https://www.harborfreight.com/two-sp...ine-44991.html
    this one?
    no experience with it other than seeing it in the store. 2.2 amps of power seems very low to spin a R-8 tool imo.
    but depending on your needs,it can probably be tweeked to be somewhat usable .
    https://www.harborfreight.com/1-1-2-...ine-33686.html this is a pretty good one however.
  12. #937
    Jan 2015
    Martha Lake, WA
    It's a hobby mill. I use mine mostly as a precision drill press but have done some light machining on steel and aluminum, and have milled a little wood although that made quite a mess. Picked it up with a 25% off coupon and have been happy with it so far. Do some reading on the net - lots of haters out there but also many users that take it low and slow and make good parts. I picked up a $15 hall effects sensor and readout and did a mod to add a tachometer which works well.
    Tweco Fabricator 211i
    Sieg X2
    AMT radial arm drill press
    AMT belt/disk sander
    HF 4X6 bandsaw
  13. #938
    Jun 2014
    Quote Originally Posted by filetobeef View Post
    this one?
    Thanks for the reply, when looking a that model , I didn't even notice the motor specs.
    I was looking more at The machine from The Little Machine Shop.
    This is the model I was looking at https://littlemachineshop.com/produc...ory=1387807683
    Thanks for all of the replies.
  14. #939
    Jun 2014
    Quote Originally Posted by jrporter View Post
    I did look at some of the reviews , they all seem mixed no matter what brand. I do understand they won't do large parts but that isn't what I'm looking for. I think I understand their limits .
  15. #940
    Minnesota
    If I had to do it again, I'd buy the one from The Little Machine Shop. I upgraded the gear system to the belt drive conversion (Little Machine Shop, removed the plastic gears) but it still has a low HP motor. Next upgrade will be putting a treadmill motor on it. In can't see throwing the Harbor Freight Mill away so I'll slowly do some upgrades.
  16. #941
    Oct 2013
    East Tennessee
    I've had one for about 15 years. Very little use, but my primary use for it is either drilling or milling with a 1/8" mill or even smaller. Huge slop in all the movements, but does what I need. Mounted to the bench next to the 7x10 mini lathe that has seen a lot of use. These days they are mainly used in rescuing old motorcycles, but in the past I used them for making physics research equipment one-offs.
    "Love 'em all... let God sort 'em out!"
  17. #942
    Apr 2018
    Wooster, Ohio
    Looks like this is an old thread but it's sticky so I'll add a couple of tools to the list.
    A few tools I've bought from HF that I like:
    Auto darkening welding helmet. The one with the blue flames. (I know it's cheap, but it works good.)
    12" F-clamp/ welding clamp. This thing is very strong!
    The big welding magnets.
    Earthquake xt 1/2" drive stubby impact wrench.
    13 piece standard and metric impact sockets.
    The little purple paint spray gun. (Goes on sale for $9.99)
    One I would not recommend is the Chicago Electric electric cut-off tool. If you're careful you can cut 16 gauge material without it bogging down.
  18. #943
    Sep 2014
    I have the helmet, magnets, and sockets myself. No complaints
  19. #944
    Apr 2016
    CA
    I put some 1/2" Husky sockets on those magnetic strips that go for free with purchase every now and then. It's about the best use I can think of out side of using them for welding and stuff.
    I did not know those things sold for $5.00
    https://www.harborfreight.com/18-in-...der-60433.html
    this is how many times it was on sale or free in the past.
    https://www.hfqpdb.com/best_coupon/1...IC+TOOL+HOLDER
  20. #945
    Aug 2018
    'ta town, KS
    Those magnetic strips work fairly well for putting legs on carts and tables.
    Mac
  21. #946
    Apr 2016
    CA
    Quote Originally Posted by Mac's Crew View Post
    Never used them like that. I use the cheap Rigid/Magswitch magnets I got on sale for things like that.
  22. #947
    Aug 2018
    'ta town, KS
    Kinda like clamping a bar to square up the legs but you can bypass the actual clamp
    Mac
  23. #948
    Jan 2009
    Sonoma County
    I cut down a Magnetic Bar and attached it along the top of the QuickHitch on the back of my tractor. Switching tractor attachments includes small clips and pins, that can disappear down into the weeds. Now they're still there when I reach for them.
    HF MIG-180 with all the mods.
    Grizzly H8153 Stick/Tig Pulse 130/160.
    Wards PowrKraft AC-230. Stick & carbon arc.
  24. #949
    Quote Originally Posted by California View Post
    Oh, I like that. Someone mentioned putting a magnet on their drill press to hold the chuck key and that has come in really handy. I might steal this idea too.
    I got a bunch of those little round magnets all over the mill, lathe, drill presses, just handy to put things like chuck keys, small spotting drills, anything metal of course they get shavings on them too but still very handy to keep things from rolling and getting lost.
Page generated in 1,604,110,451.01918 seconds with 11 queries
