Results 1 to 8 of 8
Thread: hobat stickmate lx ,leads
    Oct 2013
    holly mi
    picked up this welder leads were removed . I am sure they go to the select switch ,but to what lugs? any help will be great.thanks.
    Feb 2008
    North of Philly
    Re: hobat stickmate lx ,leads
    A pict of the inside would help us explain where you need to hook them up.
    Ronald Reagan
    Oct 2013
    holly mi
    will post sunday ,thanks
    Oct 2013
    holly mi
Size:  37.7 KBName:  Photo11101659.jpg
Size:  43.6 KBName:  Photo11101659_1.jpg
Size:  63.2 KB I have one screw out of the buss , and one where the connection is off . hope this helps.
    Feb 2008
    North of Philly
    OK, It's an AC only machine, so you don't need to worry about which connection is typically + or - like on an AC/DC unit. It won't matter which lead is the ground and which is the stinger on an AC only machine.
    here's the manual for that machine I believe.
    http://www.hobartwelders.com/om/0900/o950c_hob.pdf
    If I'm reading the wiring schematic correctly, it looks like one lead attaches to where those screws are missing on each terminal. Maybe Duane or Steve can double check me since I don't do a whole lot with wiring diagrams.
    Name:  AC stickmate.jpg
    Since you have to put all new leads on anyways, I'd look at either adding panel quick connects or short leads with quick connects on them so you can add or subtract lead as needed. I upgraded my Miller Thunderbolt ( same basic machine you have) to them so I could use my extra leads on it if I needed to.
    Ronald Reagan
    leads connect to terminals 6 and 2,
    2 should be the one with the transformer lead, 6 is just below the mount.
    looking at the back of the switch, count clock wise from two to six. look close at switch, numbers might be molded into switch
    Oct 2013
    holly mi
    Thanks guys , that is the same drawing on the cover inside. What is off is there are 4 transformer legs on the switch ,two on one lug but i think also where i pulled the screws were the correct spots. As for the leads , i run a thirty foot extenson on my 220. That way it brings my mig & stick out to the same work areas. I will get her wired up today and try it out. thanks on the manual link seems to be correct always helpful with a used unit. let you know how it works out.
    Oct 2013
    holly mi
    Must say i am welding again ,connections were correct, thanks all.
Page generated in 1,607,048,198.40266 seconds with 14 queries
