Page 467 of 477 FirstFirst ... 367417457465466467468469 ... LastLast
Results 11,651 to 11,675 of 11910
Thread: Show us what you welded today
  1. #11651
    Re: Show us what you welded today
    Built a jib for the new forklift to get an engine out of a truck. I cant use the crane inside the shop without hitting the ceiling, so instead of dragging it outside I did this. Worked perfectly.Attachment 1716555Attachment 1716556
    Nice!!! The forklift have a freelift mast?
  2. Likes ronsii liked this post
  3. #11652
    I dunno, 9,000 lb capacity Hyster on solid tires. I guess I'm not a forklift guy. It was really stable testing it with a 3200LB ecology block.
  5. #11653
    That's the machine.Name:  20200605_115129.jpg
  6. Likes ronsii liked this post
  7. #11654
    Yes. With a STANDARD forklift mast as soon as you raise the forks off the ground the mast raises an equal distance.
    You have a free lift mast.
  8. Likes 12V71, ronsii liked this post
  9. #11655
    Jul 2018
    Cumbria, UK
    We call them "container spec" - ie. you can lift the forks inside a shipping container without the mast punching a hole in the roof.
  10. Likes Lis2323, ronsii liked this post
  11. #11656
    Aug 2018
    Knocked out a "Prerunner" bumper for my friends F150...
    Welds last longer than Love...
  12. Likes Lis2323, ronsii liked this post
  13. #11657
    Quote Originally Posted by sapperb View Post
    Very nice!
  14. #11658
    I always referred to standard mast forklifts as having the “can opener” option.
  15. Likes 12V71, ronsii, Munkul, shortfuse liked this post
  16. #11659
    Sep 2009
    ocala Fl.
    I have had a few small projects in the shop that I needed to do.... Get these things off the floor... A hanger for the blower and two weed eater hangers. These hangers will keep the blower and weed eaters from coming off the wall...Name:  weed eater hanger #2.jpg
Size:  71.0 KBName:  weed eater holders.jpg
Size:  47.6 KBName:  Blower 2.jpg
Size:  60.5 KBName:  Blower 3.jpg
Size:  90.0 KBName:  Blower 4 test fit.jpg
    Miller 252
    Lincoln Square Wave Tig 200
    MM 211
    Red face AC/DC 225 Buzz Box
    Power Max 30
  17. Likes ronsii, Larry4406, DavidR8 liked this post
  18. #11660
    Sep 2009
    ocala Fl.
Size:  58.0 KBName:  Blower 6.jpg
Size:  63.2 KB These are the test fit. pict...
    Miller 252
    MM 211
    Power Max 30
  19. Likes ronsii, DavidR8 liked this post
  20. #11661
    @Thats Hot. Nice work. I will need to do similar.
  21. Likes ronsii, Thats Hot, DavidR8 liked this post
  22. #11662
    Sep 2009
    ocala Fl.
    Thank you....
    Miller 252
    MM 211
    Power Max 30
  23. #11663
    Finally got back to fixing the railing that had to take down for the water line break.
    Had to do some bending on the platform rail... then welded it up after I welded the concrete platform down to the supports.
    Then it was time to put the two concrete treads back on.
    The two steel flats cantilever under the upper tread to give it clearance from the tread below it and I can shim under the flats if the tread isn't running level
    When I removed this tread I just used a zip disc to slice right through the existing weld on the 4x4 support.. so reinstalling it was just grind a bit on the positioning plates an reweld them
    Didn't get the other two pieces of railing back on.... It was raining and blowing and I was wet and cold besides... it was friday and it's gonna take a bit of refabbing the rest of the railing as it had been 'adjusted' by truck drivers a few times
  24. #11664
    Apr 2018
    Finally built my largest project so far. A rolling material rack. Feels good to have little less chaos.
    Sent from my ONEPLUS A5010 using Tapatalk
  25. Likes LtBadd, DavidR8, ronsii, whtbaron, shortfuse liked this post
  26. #11665
    Here’s a pic of a homeless welder’s place. Found it on the internet.
  27. Likes LtBadd, ronsii, whtbaron, shortfuse liked this post
  28. #11666
    Quote Originally Posted by therider View Post
    Cool. And nice large diameter wheels to roll it around.
  29. Likes ronsii liked this post
  30. #11667
    Sep 2015
    West coast of Florida
    I knew you were good, but now you're welding concrete?!!
    Richard
  31. Likes 12V71, ronsii liked this post
  32. #11668
    Apr 2020
    Canada
    Quote Originally Posted by Thats Hot View Post
    Well sorted!
    Looks like I have another welding project!
    David
    Millermatic 130
    Primeweld 225
    Victor Journeymen
  34. #11669
    Apr 2020
    Canada
    Picked up some 3” x 1/8 wall square tube and 1”x2” rectangular tube for my welding table base.
    Still need casters.
    Still working on my welding but much happier with my beads
    David
    Millermatic 130
    Primeweld 225
    Victor Journeymen
  35. Likes therider, ronsii liked this post
  36. #11670
    I worked on several tilt up buildings welding walls together and to the floor plates, some were covered with a thin wash of concrete and barely visible until you brushed them off... Had a carpenter ask me where we bought concrete arc rods.
  37. Likes ronsii, LtBadd liked this post
  38. #11671
    I find that if you wet the rod and roll it in portland cement dust it works best kinda works like flux for concrete...
  39. #11672
    Roll in Sakrete if you want fast freeze rods.
  40. Likes ronsii, 12V71 liked this post
  41. #11673
    LOL!!! yeah, it's OK... but the thin fabric roof is a bit on the leaky side Looked at a job the other day where we have to clean up a site and get rid of a bunch of rock slabs and eco blocks.... was thinking they would make a nice little block house!!!
    All this stuff needs to leave the site!!! would like to save the slabs but don't have a good way to handle this kind of thing??? I've seen granite guys use one of the edge pinch thingies like for lifting steel sheet... but this might be a bit different??? so our way would be 'tap' it with the excavator bucket and then scoop up the pieces
    A bunch of full quarry slabs too
    Probably a hundred and a half blocks need to leave too, nice looking blocks also... don't looks like seconds.
  42. #11674
    Cut some car tires to line the excavator bucket cutting edge and thumb...... maybe.
  43. Likes ronsii liked this post
  44. #11675
    Yeah... but you still have to handle them on the other end of transporting them??? cause dumping them out of a dump trailer *may* chip them up a bit
    FREE if you want em'... You haul and load.. we might be able to help load will probably have a couple excavators and forklift on site.... not sure what the slabs weigh??? but the blocks are ~3600 lbs each. In seattle, boeing area.
Page generated in 1,604,174,436.56283 seconds with 13 queries
