Page 477 of 480 FirstFirst ... 377427467475476477478479 ... LastLast
Results 11,901 to 11,925 of 11987
Thread: Show us what you welded today
  1. #11901
    Apr 2016
    Re: Show us what you welded today
    [QUOTE=ronsii;8775407]
    A lot of truth in that I have to 'braile weld' sometimes... and usually the bead looks great... now if I could just keep the bead on the joint it would be perfect
    A week or so ago I was wondering how often folks find themselves welding by "ear." I had to do a short weld the other day that I could not reach with my gun. I found a small hole, about the size of the square for a half inch carriage bolt, that I was able to stick a 6011 (first time ever using that too, will probably use it more often now) through. I was able to pivot on the flux and do a short run, clean the weld, then repeat. The welds turned out great, just not exactly where I wanted them to be.
  2. Likes ronsii, Capt B liked this post
  3. #11902
    Nov 2014
    PDX PNW
    Making a picture frame out of redwood. Going to remake the stainless part. Probably use a thicker piece also so it won’t discolor muchName:  F4956D07-BC4F-4595-9345-05B447611BB6.jpg
Size:  98.9 KBName:  7445E731-4DB8-47F6-8E2E-A981505ACF63.jpg
Size:  191.7 KBName:  17E22F97-2910-4680-9FBD-B0B77E7AB411.jpg
  4. Likes ronsii, whtbaron liked this post
  5. #11903
    Did a bit of fence welding today... they don't need perfection - just something that looks good from a hundred feet and 15 mph
  6. #11904
    Ct
    Did a 23ft long brushed stainless rail
    Sent from my moto g power using Tapatalk
  7. Likes ronsii, 12V71, Munkul liked this post
  8. #11905
    Nice. I like the way the mini HF roller is clamped to the table, too.
  9. #11906
    Ooooooooo pretty
  10. #11907
    Ct
    Lol that's my special mini roller with attached ground clamp
  11. #11908
    Had the miller 211 out for 5 minutes today - busted railing support... whoever 'welded' it up before had about a quarter inch of something on it surprised it lasted as long as it did
    Had some more truck breakage too... you think some 7018 will work on the HC track
  12. #11909
    Bilbao, Spain
    That's what I could call repurposing for sure...
  14. #11910
    Sep 2015
    SE Pa
    Preheat
  15. Likes ronsii, pigpen60 liked this post
  16. #11911
    Pic of a trailer we redecked last week. The hay haulers like plywood decks, so we run the flat bar strips down the length of the trailer to keep from having to cut each sheet of plywood to an exact width. Name:  20201027_114941.jpg
  17. Likes Lis2323, whtbaron, ronsii liked this post
  18. #11912
    That's exactly what I would do (if I thought of it by my tenth trailer.)
  19. Likes 12V71, ronsii liked this post
  20. #11913
    We screw as much as we can through the cross members but the flat bar supports the joints in between. Most trailers get 3/4" (or 21/32") plywood to stay on the lighter side. Being a distributed load it works just fine until a loader guy sticks a fork through it...
  22. #11914
    Yeah like that never happens. I've seen forklift guys poke through/under aluminum reefer floors.
  23. Likes 12V71, ronsii liked this post
  24. #11915
    Yeah!!! they like to put em' through the sides of seacans too
  25. Likes 12V71 liked this post
  26. #11916
    How do they load hay? Forks? Clamps ?Push - off platens?
  27. #11917
    Mostly with a squeeze clamp. Some with a fork spear with grapples. I have some pics buried somewhere.
  28. Likes whtbaron liked this post
  29. #11918
    Pics... first is a squeeze head. Second is a spear with grapples.Name:  20191218_131335.jpg
Size:  113.9 KBName:  20191206_073950.jpg
  30. Likes Lis2323, ronsii, Munkul liked this post
  31. #11919
    Does that squeeze head place a full deck width eight foot stack or just four foot deep?
    And do guys in your area have those tricked out highway speed forklifts like they do in California?
  32. Likes ronsii liked this post
  33. #11920
    That one is mounted on a Case 721 loader and will handle six 3'x4'x8' bales at a time, either cross ways or length wise on the trailer. the spear only gets 3. The truckers around here like to load the big bales crosswise and strap them like the old small bale loads from front to rear.
  34. Likes ronsii, Lis2323 liked this post
  35. #11921
    There are a couple of guys loading around here with the "roadrunner" lifts, but they don't do well in the sandy stuff. So regular front end loaders and telehandlers are the kings.
  36. Likes ronsii liked this post
  37. #11922
    A good operator on an articulated wheel loader would be able to "kick" those bales in tight.
  38. Likes ronsii liked this post
  39. #11923
    Especially with 9,000 Lbs of bales in the squeeze head.
  40. Likes ronsii liked this post
  41. #11924
    Around here its' still mostly big rounds... they just use a bucket with a couple bale forks and a grapple.
  42. Likes ronsii, 12V71 liked this post
  43. #11925
    Seward, Ak
    My dad used to paint rolling stock for the MBTA in Boston. He said if you can spot a flaw in the job at 40' going 30 mph we will certainly repaint it
  44. Likes Lis2323, bfjou812 liked this post
Page generated in 1,606,447,422.54969 seconds with 13 queries
