Page 14 of 14 FirstFirst ... 4121314
Results 326 to 336 of 336
Thread: Boostinjdm's Trailers
  1. #326
    Mar 2005
    Under a Rock
    Re: Boostinjdm's Trailers
    Looks great Jim.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  2. #327
    Northern Cal., Shasta County
    License plates on trailers are always a pain. They just never seem to 'fit in'..
  3. #328
    Mar 2009
    MN
    I've been asked a few times about my ramps. I can never seem to find pics even though I swear I have them posted somewhere.
    Sides are 2" channel. Rungs are 1-1/4 x 1-1/4" x 3/16 angle iron. Rungs are 10" long, making overall width of ramps 12". The hook plate on the trailer end is 3/16" thick. These were designed to be made from 1 length of channel and 1 length of angle IIRC. Ramps have a finished length of 61" tip to tip.
    I don't know what they should be rated for, but they cover my needs well. I can tell you that an 8000lb Bobcat S250 will bend but not buckle them. The guy I sold my old trailer to did that even after I told him he would be overloaded. My 6000lb forklift bent them even though I added 2" x 10" planks on top. I have loaded several cars and pickups (not 1 tons) without issue. They currently have a slight bow to them that I need to press out. Maybe 1/4" dip in the center.
    So, if you are going to be loading full size trucks regularly, or things over about 4000lbs, you should probably go a bit beefier.
    My name's not Jim....
  4. #329
    Dec 2009
    Stevens Point, WI
    Those look beefy enough for trucks. Look about the same build as the ramps on my last trailer and I loaded all kinds of trucks and even a mini excavator with them.
  5. #330
    Mar 2009
    MN
    Welp, dump trailer needed some new tires. Was starting to weather check bad enough I could see cords. So I searched high and low for the best deal.
    Ended up with Carlisle Radial Trail HD in 205/75-R15 LRD 8ply. Bit of an upgrade going from bias to radial, off brand to name brand, and 6ply to 8ply. Walmart.com beat everybody out at about $58 each after tax. Beat everybody local by $25-50 PER TIRE. Delivered to the store for pick up in 2 days and I mounted them myself manually. Homemade bead breaker and a few spoons made it pretty easy.
    I think I did good.
  6. #331
    Dec 2009
    Stevens Point, WI
    Not that it matters much for a car or dump trailer but on my camper trailer I used bias ply tires. Reason is if they blow out they don't tear half the trailer off.
  7. #332
    Jun 2014
    South Africa
    Ok, a little progress. Not much though, I kinda slow.....
    Got both fenders and light boxes welded up and ground smooth (forgot pics). Got rear hitch installed (also forgot pics). Got tongue enclosed and started on hydraulic tank. Trying to fit 10 lbs of **** in a 5 lb bag, or so the saying goes. Still have to finish tank and figure out my mounting for wireless box for winch and dump, and switch box for the on trailer controls. I plan on having toggle switches mounted on the tongue cover to control and disable both the winch (yet to be pictured) and the pump for dumping. I also plan to have a wireless remote for loading with the winch by myself, or dumping from the cab (reason for disable switch, don't want to catch interference and start dumping while going down the highway). Also need to figure out mount for circuit breaker. Heres some pics to tide ya over.
    Hi B, nice work. what is checker plate thickness of mudguards?
  8. #333
    Mar 2009
    MN
    1/8".
  9. #334
    Jun 2014
    South Africa
    1/8".
    TX Boost
  10. #335
    Mar 2009
    MN
    Dump trailer update. Ran it over 400 miles in the past few days. Had my first light go bad. One of the 3 center lights. Last one in the string. Only lights about half as bright as it should. Definitely a light failure and not wiring. I think the cause was ice over the winter in the light. I've had the trailer in my garage most of this year and it has been dripping water since the thaw. Popped the lights out and had a nice puddle.
    Now I'm replacing all 3 clearance lights and adding some drain holes. Almost 11 years without a light failure is doing pretty good in my book.
  11. Likes ronsii, AlabamaJoe liked this post
  12. #336
    Mar 2009
    MN
    Lights replaced and drain holes drilled. I ended up just desoldering the lights and soldering in new pigtails. Doubled up shrink tubes kept the connections as clean as the day I did them. 8 5/16" holes for draining. I bet I got 3 gallons of water out of the frame. I wouldn't be surprised if it was closer to 4. The front light boxes were the worst. That's were it has been dripping from. Had to take a break after drilling the pilot hole to let them drain.
Page generated in 1,603,992,048.77078 seconds with 13 queries
