Results 1 to 25 of 43
Thread: Fork It
    Apr 2010
    Fork It
    I have been asked several times if I could do brush clean up work with my Kubota B 7800 and couldn't because I lacked a set of brush forks
    if you have ever tried to do this with a standard bucket it's a PITA ... like trying to scoop up a plié of bailing wire what little you get in the bucket wants to fall back out because it's tangled up
    and you don't want a load of dirt mixed in
    So this is an old design my father made quite a few sets of these in different sizes and both loader mount and 3 point hook up
    just going to alter it for quick attach / detach ... and maybe a future thumb load holding thing
    The material is 2 x 2 x .250 tubing that is what I have on hand and was scrap from another project that we are done with
Size:  69.5 KBName:  DSC_0303.jpg
    making the points is easy used a wood stake for the template make the cut lines and break out the gas axe
    plasma cutter would have been easier for this
Size:  48.2 KBName:  DSC_0287.jpg
    And the Trail Blazer went to the shop to be repaired so were using the old but reliable Millermatic 35
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Apr 2010
    Re: Fork It
    The points after welding
Size:  41.1 KBName:  DSC_0293.jpg
    Cut to equal length with my Rage 3 dry saw mounted on a folding mount it folds down and has wheels
    I am doing the real welding when the TB get back from the shop
    I don't want it fail so 7018 1/8 esab atom arc is what I will be using
Size:  43.0 KBName:  DSC_0301.jpg
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Jun 2008
    Re: Fork It
    I like that design, I think I'll borrow it if you don't mind :-). Two questions, what anchors the top and what prevents the bottom from being push back?.....Mike
    Apr 2010
    Re: Fork It
    I got the Trail Blazer back and it's not working right so it's going back Monday
    I wanted to put most of the stress on the bottom of the bucket and not have it just swinging around only hanging on by the top quick mounts and needed it to not interfere with normal loader operation
    so I came up with using 2 pieces of 4 x 4 x 1/2" plate cut in a L shape and welded inside to the sides of the bucket
Size:  55.3 KBName:  DSC_0309.jpg
Size:  53.8 KBName:  DSC_0312.jpg
    This holds it in place and doesn't get in the way while keeping the stress pushing down onto the bottom of the bucket and against the lock plates
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Jan 2012
    Re: Fork It
    That should work great! I did some brush work with a very similar setup once and it worked well. That machine also had a thumb thing on top like you're planning. With the thumb you can move some serious brush piles!
    How do you like your Rage saw? I think I'm about to get one.
    Sent from my C811 4G using Tapatalk
    Apr 2010
    Re: Fork It
    Now the top quick mounts were a pita because I had to buy an odd size piece of angle iron and I am trying to keep this light as possible
    but I could only find a piece of it a little thick...overkill 4" x 7" x 1/2" I would have liked to have found it in 3/8" thick
Size:  50.8 KBName:  DSC_0322.jpg
    It locks over the 3 x 3 x 3/8 angle that is welded to the top of my bucket for the hooks
    but you see how it basically works and mounts so I can detach it quickly and the only stress on the top hook up is the weight of the whole assembly
    the pushing and raising stresses are all kept to the bottom of the bucket and the two locking plates
    I will post the rest later
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Apr 2010
    Re: Fork It
    I have had my rage for three years now and still love it cuts that tubing nice quick and burr free
    but cutting 250 wall wears on the blade so i'm going to have to sharpen it soon..i should have bought another of the blue blades so one on the saw and one to sharpen
    it takes some time to sharpen them with the HF machine I have
    if you look at that one photo I posted were my ground clamp is that was cut with the rage 3
    nice and smooth ..I didn't even grind it
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    May 2010
    Port Orchard, WA.
    Re: Fork It
    Very nice build! I built something close to that years ago for my tractor, but not near as heavy duty as yours. But eventually I ran into a good deal on a grapple for a skid-steer, cut all the mounting brackets off and built ones to fit my tractor. A grapple makes life so much easier!
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Costa Rica
    Re: Fork It
    Is that 420 hydrostat ? I miss my 955
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Screw gun --bad battery (see above)
    May 2010
    Port Orchard, WA.
    Re: Fork It
    Quote Originally Posted by Burpee View Post
    420 is the loader, the tractor is a 4200. Yes it is an automatic.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    May 2010
    Port Orchard, WA.
    Re: Fork It
    Hey CEP, that's a nice little tractor
    Yeah it saves me a lot of work, when you get old you get lazy for some reason. I don't even rake the yard anymore, just use a chain harrow.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Nov 2013
    Re: Fork It
    Looks good!! What's wrong with TB?
    Miller trailblazer301g
    Lincoln sa200
    Miller251
    Miller spectrum 625
    Victor oxy-acc
    2002 Chevy duramax 3500 dually 4x4
    Feb 2012
    ny
    Re: Fork It
    Looking great Al!
    I hate being bi-polar it's awsome
    My Heroes Have Always Been Cowboys
    Ga. USA
    Re: Fork It
    I stole your idea also. Gonna make it work on my Kubota M7040.
    Proverbs 4:23
    My company welds.
    Feb 2013
    Sweet Home Alabama
    Re: Fork It
    Good idea killdozer
    Ga. USA
    Re: Fork It
    Did you run third function Hydraulics on your loader? I've got a JD 790, I'd like to be able to run the implements off my Kubota and Skid Steer, on the JD also. Did you run it off the rear AUX, and just add a control?
    Proverbs 4:23
    My company welds.
    May 2010
    Port Orchard, WA.
    Re: Fork It
    John Deere calls it a "Power Beyond Kit".
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Ga. USA
    Re: Fork It
    Okay. 790 doesn't have a rear SCV.
    Proverbs 4:23
    My company welds.
    Sep 2011
    Iowa
    Re: Fork It
    That should move some loose brush quickly. Nice work Al
    Miller 250DX
    HTP 221 DV AC/DC
    Henrob O-A
    Miller 180 Mig
    Miller 150 Inverter
    Hobart 10,000 Welder-Generator Have a good day!!!
    May 2008
    Orange, TX
    Re: Fork It
    Quote Originally Posted by Blackbeard View Post
    He says Miller believes it's an issue with the engine control harness connector(s) due to a Service Bulletin regarding the operational malfunction the machine is experiencing.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Apr 2010
    Re: Fork It
    The TB went to running from extreme high rev to below normal idle no happy medium ..it didn't matter if switch was in auto idle or run so I took it back to airgas
    I got it back Friday and guess what it went back to doing it again but I could put the switch in run and it would run at speed so I could get this project done they had it for 3 weeks
    So back to airgas it went today
    Miller rep said it's kohlers problem they say it's millers problem all I know is it's only 4 months out of warranty and I paid 400.00 for them to fix it and it's not fixed
    the mechanic said it was the coil to that I say BS he said it worked fine when he tested it now he says that miller sent service bulletins out about bad connectors on the ECM harness
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Nov 2013
    Re: Fork It
    My tb had issues with the plunger getting corroded and sticking making it idle and run crappy. I've cleaned and oiled it a few times. Now I have a bad board. The amperage drops down if you turn it up past 150 amps. Change potentiometer with negative results. Gonna fix it soon.
    Lincoln sa200
    Miller251
    Miller spectrum 625
    Victor oxy-acc
    Apr 2010
    Re: Fork It
    Oh that sucks Blackbeard...Hope you get it fixed
    Was going to tell CEP
    the reason for me building them like I did was two of the jobs I went to look at people had dumped trash of all kinds on these places along with a lot of dirt that I am going to have to sort it out and load the dumpsters or trucks with a minimum of dirt ..This was the quickest way I could think of to do it
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    May 2010
    Stuck in Gavin Newsom’s world
    Re: Fork It
    Killdozer, that's a great idea. Mad Max would have loved that pimp ride in Barter Town!
    Lincoln Power Mig 216
    Lincoln AC/DC-225/125
    Miller 625 X-Treme Plasma
    Victor Journeyman O/P
    Milwaukee
    Dayton
    Makita
    Baileigh
    NRA Life Member
    May 2010
    Port Orchard, WA.
    Re: Fork It
    Quote Originally Posted by killdozerd11 View Post
    I really like your design! If I would have had enough box tube I would have used it too. I just dug around through my scrap pile and came up with my design. It worked, but I bent the round stock often. Couple smacks with the ol double jack, and back to work. If you ever run into a good deal on a grapple grab it, they work great!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
Page generated in 1,713,267,023.32869 seconds with 18 queries
