Results 26 to 41 of 41
Thread: Best engine driven machine for MIG
    May 2012
    Albany NY
    Took some pics of my set up with the suitcase hooked up and how it's powered off the bobcat
    Hook up the regular old welding leads just like your going to stick weld use the stinger clamp to grab onto the lug on the back of the suitcase feeder
    Here's the feeder, it can be close to the bobcat or as far away as your leads allow you
    Then you hook up this clamp that's attached to the suitcase it senses the voltage your going to weld at
    Then turn the suitcase on and your off to welding
    Azle TX
    Re: Best engine driven machine for MIG
    It seems Mr Jackson and myself are having a similar problem, have all equipment in shop but need a power source that can be used mobile to power our machines in the field, Question will and what kind of generator will or will not work. I wish you all the luck with your new welding business. I build metal fencing and gates so my 220v welding equipment is just right seems hard to justify the expense of a engine welder to power something. thanks for any advice Clifton
    Dec 2007
    Los Angeles
    Quote Originally Posted by cnich View Post
    it seems mr jackson and myself are having a similar problem, have all equipment in shop but need a power source that can be used mobile to power our machines in the field, question will and what kind of generator will or will not work. I wish you all the luck with your new welding business. I build metal fencing and gates so my 220v welding equipment is just right seems hard to justify the expense of a engine welder to power something. Thanks for any advice clifton
    see post #25
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Miller 125c Plasma 120v
    SO 2020 bender
    Beer in the fridge
    Jul 2011
    Bossier Parish La.
    There's been a similar subject being discussed on the Miller forum about a Bob Cat for power and setting up a mobile welding business. You may want to look this over about what has been said there.
    http://www.millerwelds.com/resources...-know-can-help
    Apr 2010
    The Peoples Republic of Kalifornia
    Quote Originally Posted by Firemanmike69 View Post
    Mike how well does that work on mig using 035 or 030 wire ?
    I have a 12 RC feeder and have thought about getting a VS feeder also due to the distance of control cable problem with the RC
    Sent from my SPH-D700 using Tapatalk 2
    Backed my CATMA over your CARMA oops clusmy me
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Sep 2005
    Cave Creek AZ
    Get the license and the insurance first. Then get the work, then get the tools. In other words, don't tool up for work you don't have. If you manage to get a job you are not equipped for, just rent the tools you need. Do this until you figure out what type of work you are going to target. Mobil aluminum TIG is pretty specialized, and you are not likely to get that type of work until you have some experience.
    A Trailblazer 302 will do just about anything you want, but each new thing requires expensive accessories. Start out with the engine drive, as you can stick weld most repairs. Get a feeder for MIG, and a spool gun for aluminum MIG.
    You are not going to use your Sync 180 as a field unit, ever. The thing is just to heavy, and is a power pig.
    May 2012
    Albany NY
    Quote Originally Posted by killdozerd11 View Post
    It works pretty good with solid 035 a few weeks ago I ran some 035 fluxcore self shielded and that felt like it was the low end of the voltage I could run. Bigger wire runs awesome it will run 045 all day. Other than the weight with a 44 pound spool I love it, with the feeder, stick Is dead
  8. #33
    Mar 2013
    +1 on the Lincoln 305G and an LN-25 I have these at work and love them.
  9. #34
    May 2013
    Very well said. Everyone wants all the "stuff" first. There is allot to think about before you go gear up. The business model and the actual skills to preform the work is in reality more important than the equipment.
    I use a TB 302 to weld pretty much anything that u can think of. Its not cheap. Need a RC feeder for critical code mig work, a 12 vs for flux core structural stuff, spool gun for aluminum mig, Air cooled tig torch for scratch start tig, high freq. box and heavy duty air cooled tig torch for aluminum, 2/0 leads and adapters......
    Geez thats allot of stuff.
    Pry up around 10k plus.
    Find and trailblazer 302 it will have ac in case you do end up wanting to head down that road. Thats a good starting point. The TB 302 is a great machine. You wont regret it I can almost guarantee that.
    Piece together the extras as the needs arise.
    Good luck!
  10. #35
    Dec 2011
    Ted Kennedys Socialist Utopia
    Cant go wrong with a used Big 40 miller, the newer style with a 14 pin out. It doesnt drive wire like a TB55 but it will work. I run an S-32P off mine, works good for the big stuff, hardfacing etc. for small stuff in the field i run a beater home desperate lincoln 135.
    Miller Big 40G
    Miller HF-251 D High Freq
    Victor OA
    Lincoln 135 Mig
    MK 3A Cobramatic
    Bridgeport J Head
    Cronatron Oxylance
    Radnor ACAG Torch
    Weldcraft TIG Torches
    1 blown knee and two 5 Gallon pails away from being a hero.
  11. #36
    Apr 2010
    Stick is dead.... Sacrilege....
    As for the OP's question
    The TB 302 with a 12 RC or other sp feeder will cover all your wire processses except aluminum a spool gun is what you want for 1/4 or above aluminum unless you go with a water cooled tig ac tig setup
    You might want to consider a flux core gun if you do heavy steel work with big wire
    And don't forget stick work as for repair it will be your bread and butter most of the time
    And if you get the money an airpk model wil give you the complete swiss army knife allowing you to run plasma cutters and cac also air tools of all types
    I love mine and would be lost without it
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
  12. #37
    Sep 2005
    Cave Creek AZ
    Personally, I am not a fan of the airpak machines. They are nice, but I like to keep my compressor separate from my welder. That way if either breaks down, I am not out the other machine as well. I have a gas drive compressor, but also have an electric tha will run off the welder. Now if they only made an air drive welder...
  13. #38
    Jun 2010
    I have run the Miller SP32P VS off a bob cat and trailblazer. I was told it would run much better off the trailblazer, but there wasn't a lot of difference in my opinion. Although I was told hard wire is more picky than flux core on those machines and I was running fluxcore. I am told the VS suitcases weld about the same as the 14 pin ones, but I haven't used the 14 pin option. The new ones are rated at 10,000 watts AC aux power so technically they should run a stand alone welder or plasma, but I have had to do a lot of work on my bobcat from overloading it. So I wonder if the quality aux power is different on the bobcat compared to the trailblazer. The trailblazer runs an aluminum spoolgun fine, light airarc, scratch tig, but no AC weld for AC tig. The bobcat is not the latest model, it has an 8000 watt aux power and will not run a plasma or a tig machine, the new design might.
  14. #39
    Jan 2005
    Quote Originally Posted by Ace View Post
    Bingo we have a winner. The chopper power supply makes it like a Plug in quality welding power supply..
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
  15. #40
    Azle TX
    thank you Brocoli1 Clifton
  16. #41
    Apr 2010
    The big advantage to the airpak is the screw compressor that outputs 17 cfm at idle and 26 cfm at run speed you won't find any small piston compressors that can match that output...
    That's straight out of the compressor no waiting for a tank to build up at 120 PSI and 130 if you want to push at max...Which I don't suggest except for supplying abrasive blasters..it almost disassembled my little air grinder at 100psi
    Went into over tach
    Combine that with a fact of limited space and it just makes sense if you have the money ... not a cheap machine but it has it's advantages
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
Page generated in 1,606,666,251.08554 seconds with 14 queries
