Page 11 of 147 FirstFirst ... 9101112132161111 ... LastLast
Results 251 to 275 of 3660
Thread: Trailer fail pics
  1. #251
    Jul 2013
    La Porte, TX
    Re: Trailer fail pics
    Quote Originally Posted by Gravel View Post
    Definitely overloaded. Either shouldn't be hauling it or should have put it over the axles.
    Glad you didn't post pictures of the smashed Corvette!
    Quote Originally Posted by propanehotrod View Post
    I hate it when idiots think semi trailers should be loaded "over the axles" They are designed to divide the load between the tractor and trailer axles. Completely different than your single axle TSC golf cart/lawn mower trailer that makes you a trailer expert. Putting that coil "over the axles" would have put him overweight and shut down by DOT. Most likely failed due to rust and failed maintenance and inspection.
    So, I'm an idiot? What I was saying is that he shouldn't be hauling it but if he had to he should have put that over the axles. He would have been way better off. I do know the proper way to load a semi trailer.
    Obviously this trailer has been abused/neglected and shouldn't have been on the road in the first place...
    Gravel
    The difference between theory and practice is that in theory there is no difference.
  2. #252
    Jul 2013
    Pine City mn.
    The over weight fine for putting that coil over the axles would be in the $20,000.00 range, (most states are $1.00/pound) plus another $1-3,000.00 for a wrecker or crane to come and make it right before you could leave the scale. It is loaded correctly as is, it's the trailer that failed.
    Yeah, I know, but it'll be ok!
    Lincoln Square wave 255
    Miller Vintage mig
    30a spoolgun
    Thermal Dynamics Pacmaster 100xl plasma
    Smith mc torch
    Ellis 1600 band saw
  3. #253
    May 2008
    US Virgin Islands
  4. #254
    Jul 2013
    Pine City mn.
    Quote Originally Posted by IamVince View Post
    Hate that when that happens.
    Miller Vintage mig
    30a spoolgun
    Smith mc torch
    Ellis 1600 band saw
  5. #255
    Mar 2014
    Atlanta, GA
    These guys need to hook up with the guys from welding fail
  6. #256
    Jun 2014
    Added these pics to welding fails but fitting for this thread too.
Size:  64.5 KBName:  ImageUploadedByTapatalk1406613246.368275.jpg
Size:  70.1 KBName:  ImageUploadedByTapatalk1406613270.815981.jpg
Size:  37.5 KBName:  ImageUploadedByTapatalk1406613283.625251.jpg
Size:  43.5 KBName:  ImageUploadedByTapatalk1406613297.014707.jpg
  7. #257
    Mar 2014
    Atlanta, GA
    Quote Originally Posted by traumajunkie720 View Post
    What kind of trailer is that? Besides a ****ty one.
  8. #258
    Re-purposed pickup frame/box maybe?? A little knarly lookin'.---Meltedmetal
  9. #259
    May 2013
    The best I have found so far!
    Everlast PowerARC 300
  10. #260
    Mar 2014
    Atlanta, GA
    Quote Originally Posted by DXN1EL View Post
    I was expecting all the bikes to fall like dominos. Talk about having a bad day. Trailer fell off, he fell chasing it while tractor ran into it.
  11. #261
    Jan 2014
    Palmer AK
    This isn't a trailer fail, but I'm sure it was, and the trailers gone, so its a fail right???
    Saw this at a stop light last night....
  12. #262
    west texas
    They towed it, I don't know how far, but they towed it just like that to the scrap yard. I saw it coming from down the street so I know it was on public road way just like that.
    Apparently you can do what ever the f you want in NM.
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Miller model 250 and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
  13. #263
    Jun 2014
    That is what it is. I'm not sure how they ever pulled it. Looked like they took the hitch off a garden tractor and mounted it on a S-10 frame.
  14. #264
    Jul 2013
    Pine City mn.
    This was parked at a Mc D's that I stopped at today. At first it looked like just a wheel bearing went out and started a fire til I started to look at all the stuff that was wrong long before the fire.
    Name:  trailer fail 007.jpg
Size:  61.3 KBName:  trailer fail 001.jpg
Size:  83.8 KBName:  trailer fail 003.jpg
Size:  35.5 KBName:  trailer fail 011.jpg
    Miller Vintage mig
    30a spoolgun
    Smith mc torch
    Ellis 1600 band saw
  15. #265
    Jul 2013
    Pine City mn.
    Been missing the hoses for the air brakes for a long time.
    Name:  trailer fail 004.jpg
    Chains been dragged and have no hooks. Also check out the retainer on the dropleg.
    Name:  trailer fail 009.jpg
    Busted ramp lift cylinder mount.
    Name:  trailer fail 010.jpg
    This could be why the bearings went out. And the rust is a tell for loose lugs, yes I check and they are loose.
    Jack could use some work too.
    Name:  trailer fail 005.jpg
    Miller Vintage mig
    30a spoolgun
    Smith mc torch
    Ellis 1600 band saw
  16. #266
    Jul 2014
    that trailer is from Tennesse where are the bullet holes?
  17. #267
    Jul 2013
    La Porte, TX
    Quote Originally Posted by gxbxc View Post
    Louisiana
    Gravel
  18. #268
    Jul 2013
    Pine City mn.
    Louisiana
    And a long way from home since it's sitting in Madison Wi.
    Miller Vintage mig
    30a spoolgun
    Smith mc torch
    Ellis 1600 band saw
  19. #269
    Jul 2013
    La Porte, TX
    Quote Originally Posted by welderj View Post
    Probably why it failed when it did.
    Gravel
  20. #270
    Feb 2012
    [QUOTE=welderj;4505961]This was parked at a Mc D's that I stopped at today. At first it looked like just a wheel bearing went out and started a fire til I started to look at all the stuff that was wrong long before the fire.
    Is this really a single axle trailer? Or am I missing something?
  21. #271
    Jul 2013
    Pine City mn.
    [QUOTE=Strangedex;4507711]
    The front axle had a bearing go out and started on fire burning off the tires and burning the truck on thr bed.
    Miller Vintage mig
    30a spoolgun
    Smith mc torch
    Ellis 1600 band saw
  22. #272
    Feb 2012
    Thanks for clarifying that for me.
  23. #273
    Jul 2013
    Pine City mn.
    Quote Originally Posted by Strangedex View Post
    If you look close at the first pic you can see another axle in front of the obvious one. They pulled the tires off the side the pic is taken from because this happened on the highway. The owner drug it to this Mc D's and dropped it and abandoned it according to the manager at the store. It's been sitting for 2 weeks. They have been trying to get it hauled off but can't find anyone to take it because noone can contact the owner. At least that's the manager's story.
    Miller Vintage mig
    30a spoolgun
    Smith mc torch
    Ellis 1600 band saw
  24. #274
    Apr 2010
    welderj
    #280 - #281.
    Rarely can one capture so many gene-defects [photo ops] in a
    single specimen.
    The Darwinian explanation: the truck on the trailer - was actually
    towing the trailer.
    This would account for the symbiotic-totality of negative-pairing.
    Opus
  25. #275
    Mar 2012
    Charlottetown,PE.Canada
    welderj
    #280 - #281.
    single specimen.
    towing the trailer.
    Opus
    Always a critical answer from someone who never started a post on here.....hmm maybe you're hiding something?
Page generated in 1,713,289,444.80473 seconds with 18 queries
