Results 1 to 6 of 6
Thread: Hypertherm 600 torch needed
    I am looking for a hypertherm 600 torch only,,,mine has the 8 pin round connector,,, any one that has upgraded may have one laying around,, also what other torch's will work with this plasma cutter, i got this at a auction and not even sure it works, any help would be helpful
    Jul 2013
    La Porte, TX
    Re: Hypertherm 600 torch needed
    I have a used RT60 I will sell. PM me if it will work and you are interested. Also have lots of consumables.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    Oct 2007
    New Hampshire, North Carolina
    Best thing you can do for a Powermax600 is to upgrade to the Duramax torch, same torch used on the newer Powermax65, 85 and 105 systems. You will get squarer, cleaner cut edges, faster cut speeds, and as much as 2.5x consumable life. The RT60 is a good choice as well, and likely will be less expensive as a used one.
    Jim
    Quote Originally Posted by Beaver Weaver View Post
    Cool Re: Hypertherm 600 torch needed
    ok guys think i found one pac123t i believe,, if it works enough to check out the machine,, i may get back with you guys for an upgrade ,, i am still interested in better torches so let me mknow what you have,,, HOPE THIS 600 WORKS
    Jul 2013
    La Porte, TX
    I do have some Lincoln plasma torches. Some complete, some for parts.
    Have no clue if one would even work, but if someone who knows could verify, the price would be right.
    These Hypertherm have an 8 pin screw on connector...
    Gravel
    Ceres, California
    there is a slight difference between the 600 torch and the 800/900 torch.
    wiring inside the plug is different. At a glance they look the same.
    depending on experience around high voltage electronics, it is possible to power it up
    and make output. No load output is close to 300 volts DC.
Page generated in 1,606,991,396.56129 seconds with 11 queries
