Page 63 of 118 FirstFirst ... 1353616263646573113 ... LastLast
Results 1,551 to 1,575 of 2938
Thread: Blacksmithing tools
  1. #1551
    Re: Blacksmithing tools
    I spent a little time mocking up a stand for that post mount blacksmith vise last night.
    The plan at the moment is to make it equivalent to a modern day bench mount drill press.
    I grabbed a disc brake rotor out of the scrap pile to be used as the base. Hopefully it will add a little style...
  2. Likes VaughnT, ronsii, whtbaron, DavidR8 liked this post
  3. #1552
    That's going to be seriously gorgeous!
    I love how the lines of the shield plate compliment the brake disk's lines. It took me a minute to realize that was just a old car part!
    The only thing I'd suggest doing different would be to use square nuts and plain washers instead of the new shiny stuff. Even if you have to make the nuts from some square bar, I think it'd be worth it just to add that little bit of "something different" and keep the old-world look.
    I have a old disk out in the shop and will definitely have to keep this in mind. That'll make a wonderful little table-top drill base!
  5. #1553
    Thanks Vaughn. Good advice as always and this is the PLAN!!
    I have a small inventory of new and used square head fasteners just for occasions such as this.
    Those hex head bolts in the mockup were used only because they are convenient for temporary use.
  6. #1554
    Too bad the wrong side is gone on this one... it would definitely have style
  7. Likes Lis2323, whtbaron, VaughnT, DavidR8, tackit liked this post
  8. #1555
    I’m getting a little closer with the stand for my new cordless drill press.
    I wish someone was paying me by the hour on this...
  9. Likes ronsii, VaughnT, tackit, Thats Hot liked this post
  10. #1556
    That's sweet. I picked up one of those set up with an electric motor years ago at an auction. The handle came with it, but it's ugly compared to the one you made. I had planned to attach it to a metal stand as well, but... well.... you guys know how my builds tend to look more like a pile of junk. My plan was to put the handle back on and use it for tapping threads. The PO had put a modern chuck in it as well.
  12. #1557
    My idea for a frame was a little "different". My complaint with this design ( and drill presses in general, really) is the lack of throat room for working on larger parts. My plan was to construct a frame that would hold the press securely to the wall, and quite high, so it would just clear my 7' ceiling. The frame would hold it about 3 ft. from the wall and there would be no base under the press. The base would then be constructed as a scissors lift table with "arms " that would attach to the frame on the wall and make it secure to the press. It should also have some kind of X/Y activity for fine tuning, but it would allow for drilling on much larger parts, both horizontally and vertically.
  13. Likes VaughnT, ronsii liked this post
  14. #1558
    Love the newel post cap! That's just the right finishing touch!!
    Les, I like your idea to use one for larger/deeper drilling. If you do it right, there'd be no problem getting an engine block under the thing! You'd have to make it something like one of those old radial-arm presses, but that wouldn't be too hard with a bit of I-beam and some rack/pinion gears.
  15. Likes whtbaron, ronsii, Lis2323 liked this post
  16. #1559
    Diesel engines and big transmissions is what I had in mind... but then again maybe that's just a good argument for a really good mag drill...
    I remember years ago reading about a shop that made an English Wheel for large panels by using the shop itself for the frame. The bottom pedestal was held by a block of concrete cast into the floor, and the top was secured to an I-beam in the ceiling. It could basically handle any size sheet that would fit in the shop. I always thought the concept was interesting when I started thinking about the limitations of other machines.
  17. Likes ronsii, Lis2323, VaughnT liked this post
  18. #1560
    Around here they call that a “PROJECT “. Where you live in the land of ice and snow they probably call it “second week of March.”
  19. Likes DavidR8, whtbaron, ronsii liked this post
  20. #1561
    A little more progress on the cordless DP today.
  21. #1562
    Whoa! That's lookin good!
  22. Likes ronsii, Lis2323 liked this post
  23. #1563
    WOW!!!!!
    Very nice didn't realize she was an 18V... way better then the really ancient 12 volters
  24. Likes Lis2323, Thats Hot liked this post
  25. #1564
    Sep 2009
    ocala Fl.
    Very nice job..... I like this fab job a lot.
    Miller 252
    Lincoln Square Wave Tig 200
    MM 211
    Red face AC/DC 225 Buzz Box
    Power Max 30
  26. #1565
    Here's the DP utilizing a vertical receiver bench mount.
  27. #1566
    Nice!!!! I am thinking this will make a great horizontal boring machine I can plug right into the back of my work truck
    I also am very curious how long that battery lasts???
  28. #1567
    50 percent longer than the previous brushed motor version.
  29. Likes ronsii, whtbaron liked this post
  30. #1568
    !!! Oh yeah!!!! I should have known it was brushless didn't see any brushes
  31. Likes Lis2323 liked this post
  32. #1569
    Remind me to include a vertical receiver into my next welding bench. That's looking really good. Does that old bolt tightening style push the small bits to one side and increase runout? Or do they self-center?
  34. #1570
    It makes a normal twist drill work like a step drill for enlarging holes
  35. Likes ronsii, whtbaron liked this post
  36. #1571
    LOL!!!!!!!! sounds like my kind of drill
    I found a very old probably antique tool while digging today!!!! could be turn of the century or so age wise.... I know it's old cause it says made in usa on it
    What cha think??? some sort of blacksmithing tool???
  37. Likes Lis2323, VaughnT liked this post
  38. #1572
    LOL... I've found a few of those sampling water at the bridges... seldom in good enough condition to use.
  39. Likes ronsii liked this post
  40. #1573
    Explains why most of the ones I've seen have modern chucks mounted in them.
  41. Likes ronsii liked this post
  42. #1574
    Sold an anvil today.
    195# John Brooks. Clean edges. No repairs. Good rebound.
  43. Likes ronsii, whtbaron liked this post
  44. #1575
    Oh man, I hope you're getting good money for these items because they are really hard to find in the condition you keep things...
Page generated in 1,713,297,352.45578 seconds with 19 queries
