Results 1 to 15 of 15
Thread: DC stick = easiest aluminum casting ever
    This is so simple it may blow your mind. I'm using a DC arc welder, a graphite crucible and kinetic sand (it's a kids toy) to cast aluminum parts.
    Temecula, CA
    Re: DC stick = easiest aluminum casting ever
    Did the sand return to its original state after it cooled down? Just want to know if it would be reusable.
    Oh! Awesome idea by the way! Has some potential, I just happen to have some kinetic sand, a dc stick welder and some scrap aluminium... Hmmm... Off to the LWS to grab some carbon gouging rods!
    Nov 2012
    new york city
    superuk; very cool. btw, loved the interruption during the narration.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Sebeka and Bemidji MN
    I found this very interesting
    Would it have been easier to use an AC welder and two carbon arc rods?
    Basically the old carbon arc torch used to heat bolts and such.
    If you did this you'd have a nice steady arc that wouldn't go out.
    Your video led me to look up this DIY crucible process.
    Airco 300 - Syncro 350
    Jul 2013
    Pine City mn.
    Wow!!! That is incredible. I doubt I'll ever have reason to use that, but I have some carbon rods laying on the shelf
    Yeah, I know, but it'll be ok!
    Lincoln Square wave 255
    Miller Vintage mig
    30a spoolgun
    Thermal Dynamics Pacmaster 100xl plasma
    Smith mc torch
    Ellis 1600 band saw
    Quote Originally Posted by Sheyda36 View Post
    The dye in the sand has turned grey, but otherwise flows the same as before.
    Temecula, CA
    Quote Originally Posted by superUnknown View Post
    Cool! I will have to try this!
    Feb 2008
    North of Philly
    Basically a miniature version of an electric arc furnace like they use to melt steel. ( I can't find the really good video some one here posted up a while back.)
    Ronald Reagan
    Oct 2011
    Elkhorn, WI
    Where does a person get graphite crucibles?
    Feb 2008
    North of Philly
    Jewelry supply houses or casting suppliers have them available. Also check art supply places.
    Quick one I pulled off my saved list when I was thinking about making a gas fired furnace to cast alum. I may have other suppliers on my other computer.
    http://www.budgetcastingsupply.com/F...les-s/1830.htm
    Ronald Reagan
    Morton, Washington
    I saw this the other day... I'm definitely going to try it.
    Quote Originally Posted by drujinin View Post
    I got mine on flea bay. Aliexpress also has 'em.
    Jul 2011
    Melbourne, Australia.
    Hi, years ago around '75, we used to melt aluminium in a steel ladle with a propane torch.....the ladle was the type used for melting lead etc, and held about a litre of alluminium.
    The furnace was a collection of fire bricks arranged around the ladle and the propane torch fired in one side and exhausted out the top.
    People say that aluminium does not cast well melted in a steel crucible, but we made many aluminium hammers for the shop and cast them also in a split steel mould......I still have one that I use on the mill for setting up etc.
    Then 10 years ago I melted aluminium in a steel pot using hardwood in a furnace made from a 25 litre drum lined with fire brick.
    The aluminium was scrap offcuts from rolled plate stuff with some chippings from the lathe added too.
    Ian.
    Nov 2014
    Southwestern Ontario
    What would the strength of this aluminium be. Just the same as its original form?
    Mar 2014
    North East Indiana
    Aluminum often requires a heat treatment to bring it back to strength. But like any casting, it can only be as strong as the materials used, and quality of the casting.
Page generated in 1,611,776,139.50930 seconds with 11 queries
