Results 1 to 7 of 7
Thread: Slat table question
    Mar 2004
    Western Nebraska
    Slat table question
    I recently came across 5 48"x13" 1/2" drops that were cut by a shear, I've tossed around the idea of making a fixture table out of them, but my question is what are you guys doing for spacing in between the slats?
    Aug 2010
    Guelph, Ontario, Canada
    Re: Slat table question
    When I made a small rolling assembly table out of channel, I used the dimension of my vise grips turned sideways at 90* to the crosspieces. That made a gap that all my c-clamps fit into easily as well. Don't remember the exact measurement, but I'd pick your thickest clamp and use it to set the gap. There's nothing worse than having one hand holding a piece, only to find the clamp won't fit in place. Just my .02.
    Mar 2004
    Western Nebraska
    The reason I ask others is because I doubt I own the largest clamps I'll ever own yet...
    Apr 2010
    Shamrock, TX
    It's always a compromise. I used 2" on my big table. It works ok till you need to place a piece of 2" tube right where the gap is. Usually I can work around it but sometimes it's a pain. My other table I made adjustable. It has a 2" gap but currently the rest are less. Sometimes it's to much sometimes it's not enough.
    In truth I think the best setup would be to have a 5/8" - 3/4" gap and use bolts and hold downs. But that creates a whole different set of problems.
    Millermatic 252
    XMT 304's
    Dynasty 280DX
    Hypertherm PowerMax 1250
    Miller Trailblazer 302 EFI
    Optima Pulser
    XR feeder and XR Edge gun
    and more at
    http://members.dslextreme.com/users/waynecook/index.htm
    Mar 2008
    Georgetown, Texas
    2" is what we use on that kind of table and it seems to be fine.
    Feb 2012
    Neenah, WI
    I did build pro spacing so if I wanted to use there tooling also water jet 5/8" holes too for there tooling. You can use drill press vice clamps like in the pic those are super handy. I'm modifying my table tho. If you noticed I bolted my slats down vrs welding them on so I can A replace them B remove to have open space if I'm working on and odd shape project. I will hower ever be modifying table. Taking 3" square tube cutting a gap all the way down them and putting a threaded square piece of flat stalk inside to blot to so I can sled the slats to different sizes or together. And putting a 2'x40" plate in center and drilling holes in that.
    Jul 2014
    Central fl
    Nice table man. I like the idea your going to incorporate with the moveable top. That should work well!
    Real welders know how to penetrate!
    (Equipment)
    Whatever can be used to beat my opponent into submission!
Page generated in 1,713,253,333.14387 seconds with 20 queries
