Page 51 of 54 FirstFirst ... 414950515253 ... LastLast
Results 1,251 to 1,275 of 1346
Thread: Blacksmithing and forging
  1. #1251
    Fredericksburg, VA
    Re: Blacksmithing and forging
    Today was a bit of a failure as expected.
    I tried to make the cross that was demonstrated a few weeks ago. I could not forge weld the circle as expected. I cranked the pressure of the propane forge, even used a grinder on the material to clean the sides being joined, and then used some borax.
    I let material soak up as much heat as possible for about 10 minutes. Maybe I needed to wait longer. This was my first attempt ever at forge welding.
    The material was 3/16×3/4.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  2. Likes Lis2323, whtbaron, Thats Hot liked this post
  3. #1252
    Not bad at all. You got a good clean turn to the circle and the scarfed end is still very attractive rather than smooshed all to snot.
    I've never tried forge-welding in my propane forge so I don't think I'll be much of a help. From what folks tell me, it's a whole different kettle of fish compared to a coal forge.
    One tip I've heard time and time again is to clean the joint really well... and then spray it with WD40. Borax is a caustic substance that eats at the scale that forms in the joint and traps it in the sludge that flies out when you hit it with a hammer. WD40, or diesel fuel, flashes off in the first instant in the fire, leaving behind a residue of carbon that precludes the creation of scale in the first place.
    I think you've still got a wonderful piece, and I'd put a rivet through the scarf when you put it on the cross. That way it all looks very intensionally-designed.
  4. #1253
    I think it looks pretty good!
  5. Likes psacustomcreations, VaughnT liked this post
  6. #1254
    Fredericksburg, VA
    Thanks.
    I was just talking to a friend who was at the same demonstration. He suggested using the rosebud on the O/A torch to add the last bit of heat.
    It is really humid right now so I had to take a break.
    I may try to round out the circle a bit more later. I still want to try the additional steps to make the cross.
    The demonstrator uses brass rivets to add a nice touch of color where the ring intersects the arms. I might try that as well.
    Millermatic 252 MIG
  7. Likes VaughnT liked this post
  8. #1255
    Some brass rivets would look very nice against the dark iron. I just picked up a few dozen brass screws at the hardware store when I was getting my tank re-certified and filled. Cost me better than a hundred for that visit! :O
    The paperwork that came with my not-so-Majestic forge stated that forge-welding was only possible above 25psi on the gas. Obviously, I never cranked the think up to that kind of pressure just to play with welding, but it might give you a target to shoot for.
    Another idea might be to braze the joint. That'd go real nice with the brass rivets and kind of give it something of that Japanese aesthetic.
  10. #1256
    Aug 2012
    AR
    psa, for material that thin, I believe you let it soak too long. Bring it up to red/orange, apply borax, then get it to welding heat before the borax boils away. That probably created more oxides than the borax could handle as well as possibly decarbonizing the steel somewhat. Check out some forge welding videos on YT by Black Bear Forge (John Switzer) and Technicus Joe (Joey van der Steeg) as well as iforgeiron.com to help you with forge welding. Happy forging!
  11. Likes psacustomcreations, VaughnT liked this post
  12. #1257
    Fredericksburg, VA
    My understanding is that forge welding temp is when the material is beyond orange and closer to yellow/white. If I am wrong, let me know.
    If I am right, then it seems the best way to do what you are describing, is that the transition between application of borax and welding heat needs to be quick.
    On a semi-related note, I need the correct tongs to hold the material. I just had a set of wolf jaw tongs and some made to hold 5/8 rr spikes. Having the correct tongs was one of the demonstration points.
    I will definitely check out more videos.
    Millermatic 252 MIG
  13. Likes whtbaron liked this post
  14. #1258
    Aug 2012
    AR
    You are right on both counts. Borax, and any flux, will boil away and become ineffective if left on too long coming up to welding temp. When coming up to welding heat with propane, it may take longer than coal/coke depending on how "powerful" your gas forge is. That is, generally speaking for mild steel. Tool steel and any high carbon steel needs to be treated differently. Just get some 1/4" thick x 1/2" to 1" wide scrap pieces and practice faggot welding several times with those until you get the process down pat. Thin stock will burn very quickly when coming up to welding temp, BTW.
  15. Likes psacustomcreations, whtbaron liked this post
  16. #1259
    Fredericksburg, VA
    Here is the cross. I cheated and drilled through one part of the back side then tig plug welded before I finished shaping the ring.
    I used some pieces of 1/8" silicon bronze tig rods as the pins. The pics show the front versus back side.
    It has been wire wheel brushed but no finish applied yet. I will most likely use spray on clear. It is a gift to my brother.
    Millermatic 252 MIG
  17. Likes VaughnT, whtbaron, Thats Hot, ronsii, DavidR8 liked this post
  18. #1260
    The cross turned out awesome.
    Probably only a purist would call drilling that hole cheating .
    My opinion is a craftsman uses whatever method or tools at his disposal to best create a project.
  19. Likes psacustomcreations, ronsii liked this post
  20. #1261
    Very nice work, Pat!
    That's gotta be a tricky thing to weave together.
  21. Likes psacustomcreations, ronsii liked this post
  22. #1262
    Fredericksburg, VA
    Quote Originally Posted by VaughnT View Post
    Thanks.
    I am already thinking of a few variations.
    Were you able to knock out all your hooks or orders?
    Millermatic 252 MIG
  23. Likes ronsii liked this post
  24. #1263
    Spent $100 today.
    Finally found a shop that's reasonably close and will cut my steel for me. 120 pieces of 1/4"x1/2"x6", or 3 bars 20' long, cost me just over $100. That's less than a dollar per piece when you factor everything in, and something I can tack on to the cost of the hooks I make with them.
    The downside is that it was really depressing to see a tiny little plastic tote carrying all that steel. It wasn't even the size of a shoe box!
    Of course, now I have a bunch of blanks that I can turn into hooks -- just grab n go -- and that makes me happy. I really hate trying to bundle up a couple sticks and work them through my bandsaw!
  25. Likes Thats Hot, ronsii liked this post
  26. #1264
    You should be looking in awe at how much profit margin you will be making from the little plastic tote.
  27. Likes VaughnT, ronsii liked this post
  28. #1265
    I'm trying really hard to remember that!
    $100 at my normal steel supplier would have netted me a gob of metal, so seeing this tiny little tote was rather, um, anticlimactic.
    Still, it'll go on the shelves with the railroad spikes and big nails. Every time I need to make one of these hooks, I can just grab what I need and chuck it into the forge! It's going to be real nice over the next couple of days as I try to catch up on the backlog of orders!
    Of course, now I have to figure out how many orders I have to place with them before I spend as much as a small hydraulic shear would cost me....
  29. Likes ronsii liked this post
  30. #1266
    Luke, one of the tenants in my maintenance yard is always giving me “goodies” left over from his commercial tenant improvement gigs.
    I was happy to be able to return the favor today by whipping up a pair of wedges that were MIA from his dad’s post leg vise.
  31. #1267
    He just sent me a pic of it mounted on a stump.
    It’s only a little 4” wide jaw/ 60 odd pounds but it looks impressive in the photo.
  32. Likes ronsii, whtbaron, VaughnT liked this post
  33. #1268
    Yesterday I spotted an ad: “WTB propane forge” so I replied with a pic of mine ....
    This morning I pulled it outta the shop....
    and it’s GONE!
    I won’t disclose what I sold it for as no point in fueling all you haters out there. LOL.
  34. Likes DavidR8, psacustomcreations, ronsii liked this post
  35. #1269
    LOL!!!!
    I hate you
  36. Likes Lis2323 liked this post
  37. #1270
    Wow! She was such a beautiful forge, too. Hate to see her go, and I can only hope and pray that you'll take this as motivation to build another one even bigger and better!
    Lets have a moment of silence for the dearly departed.....
  38. #1271
    You're scaring us with all this "selling tools" talk... I never thought that was an option. You must be making room for something really big...
  39. Likes ronsii, Lis2323, VaughnT liked this post
  40. #1272
    You're scaring us ...
    You don't think that maybe he's gonna start wearing those skinny jeans, do you? Can we mobilize some kind of intervention in time to stop his descent into madness? :0
  41. Likes Lis2323, ronsii, whtbaron, DavidR8 liked this post
  42. #1273
    Google says I can be there in 4 hours and 16 minutes and 38 seconds!!! but I think you guys are going to take a bit longer....
  43. Likes VaughnT liked this post
  44. #1274
    Better not count on whtbaron. Making the trek out West and taking his Lincoln Idealarc back with him may appear a bit hypocritical.
  45. Likes ronsii, whtbaron liked this post
  46. #1275
    Yea, I was thinking about that. Google says I will need 25 hrs to go 2,400 km. Google has never traveled with my wife....
  47. Likes Lis2323, ronsii liked this post
Page generated in 1,603,653,540.74170 seconds with 12 queries
