Results 1 to 8 of 8
Thread: Never cut saddles again!?
    Dec 2008
    Has anyone used these?
    They would cut down on cutting and grinding.
    But you would have to weld twice as much!
    So... win win right!
    http://tap-gate.com/saddled-n-ready/
    Jul 2013
    La Porte, TX
    Re: Never cut saddles again!?
    Makes for a much easier job for those of us without the talent to cut saddles right the first time.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    Sep 2005
    Cave Creek AZ
    I have never found cutting saddles that bad, especially using the chop saw method. I have also built a pipe smasherfor my press that squashes 2" pipe down to about 1 1/4", makes for easy welding.
    Sebeka and Bemidji MN
    The goat farmer I weld stuff for likes the pipe smash method (fast is cheap) - goats aren't as strong as cows anyway.
    Chop saw method is awesome.
    Airco 300 - Syncro 350
    Oct 2013
    OH
    What is this chop saw method you speak of?
    -Spike
    With a chop saw you cut 2 angles about 30 degrees. Pirate 4x4 has a good article on this with different cut angles for different sizes.
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by Spike440 View Post
    -Spike
    Someone somewhere posted this years ago. I never tired it, but saved it.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Oct 2013
    NOVA
    Bicycle builders have been using these lugs for many years with some great results. That said, if the cost is the same to the customer, I would still notch myself to get the money for time instead of material.
    Multimatic 200
    Ellis 1800
    Haberle S225 9" cold saw
    MM 300; Spoolmate 30A w/ WC-24
    TB 302G
    Dynasty 280 DX Tigrunner
Page generated in 1,593,977,923.46790 seconds with 12 queries
