Page 1 of 3 123 LastLast
Results 1 to 25 of 57
Thread: Best stick welder for a newbie
    Baytown Texas
    Once again, as i posted on my other thread about running pipeline. I am fairly new to the welding world, so don't laugh at my inexperience haha. Anyhow, i wanna know what would the best stick welding machine for a newbie like me. I wanna be able to weld using 6010 as well as 7018 rods. So what would be the best cheap but reliable welding machine for that? Also been reading about ac/dc and dc machines. Still a little confused, but just my question. I'm looking into buying a machine to weld at home and practice myself. Thanks!
    -Kyler
    Life is really simple, but we insist on making it complicated. -Confucius
    Jul 2011
    Bossier Parish La.
    Re: Best stick welder for a newbie
    Get you an SA 200 or 250 to practice with. That is the preferred machine for pipe line welders, so might as well get used to that machine since you want to go pipelining eventually anyway. Then you will be set up for a machine, and then just need the truck to haul it on.
    Getting one of these machines, means you won't have to worry about if you have enough electrical power to supply it, or getting a 240 receptacle installed. Just pour in the required fuel, fire it up and start welding.
    Jul 2013
    La Porte, TX
    Quote Originally Posted by Bistineau View Post
    He's a high school senior so that probably isn't an option right now.
    angler, Any ac or ac/dc buzzbox will serve you well (Lincoln tombstone, Miller Thunderbolt, Hobart Stickmate, etc).
    Here is a Lincoln 225 AC machine in Alvin for $125. Not a bad deal in this area and it looks like it has plenty of lead. Do you have a 240v outlet in your garage or wherever you will be welding? Even an electric dryer plug will get you more than half of the max output of this machine.
    I prefer the Thunderbolt because the amperage has infinite adjustment whereas the Lincoln has tapped settings.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    Sebeka and Bemidji MN
    Cheap and reliable AC/DC welder?
    (you need the DC for your 6010 and 7018 rods - they taught you that right?)
    I'm a fan of the Miller Dialarc - it can be found down in the $200-$300 range and you can practice all day with it.
    Many of the smaller home-owner machines like the little Lincoln 225 and Miller Thunderbolt are very good little welders - but not if you want to practice to pipeline.
    The Lincoln Idealarc is also a top choice.
    For modern inverters, cheap is normally not in the cards if you want it big enough to do serious hours of non-stop practice - in my opinion.
    Airco 300 - Syncro 350
    Stick to the major name brands and stay away from the cheap box store imports. If you are going used, I'd hold out for an AC/DC machine.
    Jul 2013
    La Porte, TX
    Unfortunately for him, he won't find a Dialarc in this area for less than $500 or $600. The one I got for $325 was a fluke.
    For $200-$300 you are fortunate to find an ac/dc lincoln or miller machine. I'm going to keep my eyes open for him. He only lives about 20 minutes from me.
    Gravel
    Jul 2011
    Bossier Parish La.
    Quote Originally Posted by Gravel View Post
    He did ask about the best, didn't he? I think for the line of work he is planning on getting into, this would be one of the best for him to consider. There will be no need to upgrade for quite awhile either, so that makes it an even better choice.
    Jul 2013
    La Porte, TX
    True story. But wouldn't he get spoiled to that perfect DC wave?
    Gravel
    Jul 2011
    Bossier Parish La.
    If your going to be learning, might as well learn on good equipment, eliminates any confusion on whether it's the man or machine that is not performing as needed. As for getting spoiled. Since it will be his machine for many years to come, he can keep himself spoiled on it for all I care. There is the added benefit of getting to disturb the neighbors every time he wants to do some welding. Always a GOOD time.
    May 2010
    Port Orchard, WA.
    I paid $200.00 for this Lincoln SA-200. Paid $294.00 for the Everlast PowerArc 300. The PA-300 with stack 6010 every bit as nice as the SA-200, but it won't run 7018 as nice as the SA-200.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Vermont
    You paid $200 for the SA 200? Holy smokes. I need to get to know the people you do! That's mind blowing. I just saw a SAE-500 on the back of a truck driving by. What a nice machine.
    Oh and to the OP, as tempting as it may be, don't buy a craftsman 95 amp Arc welder from Sears, or any welder from harbor freight. You will regret it sooner than later.
    Craftsman 90 amp Arc welder
    Jan 2014
    Hallieford, VA
    CEP, is that cloth covering a classified project?
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by lighttekku View Post
    Yup. Paid $250.00 for this one.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by storeman View Post
    You mean the red rag? It's covering the spool gun to the V350-Pro.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Vermont
    You have two? :O
    May 2010
    Port Orchard, WA.
    You have two? :O
    Oh at one time I had 5 or 6, now I'm down to just 3!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Vermont
    Jeezum. I guess it's good to have backups! How many welders do you own?
    Jul 2013
    La Porte, TX
    Texas_angler, found you an SA200, just find CEP's house!
    In 1960?
    Gravel
    Jul 2011
    Bossier Parish La.
    Keep in mind, CEP is ONLY a hobby welder.
    Jun 2014
    CEP - in the pictures and prices you posted - is that the condition they were in when you bought them? Or did they require a total rebuild?
    I've been seeing them pop up at on-line auctions I frequent but have been hesitant to buy because of potential rebuild cost.
    Jun 2014
    And he's only been welding for 2 weeks and a few days!
    Yes!
    I've only been welding for about 2-weeks now, but you'll want your 6010, and 7018 welds to look more like these.
    Morton, Washington
    Show us a photo of it before the restoration!
    May 2010
    Port Orchard, WA.
    Only 9 or 10.
    In 1960?
    No, I think it was 3 or 4, maybe 5-years ago. Here on the west coast they go cheap sometimes.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Vermont
    A hobby welder. Must be nice to have so many nice machines. With enough practice and patience I may be able to call myself a hobby welder in a couple years.
    Quote Originally Posted by newbury View Post
    So I've been told. But they also tell me not to believe what I read on the internet, I'm guessing that's one of the things they refer to.
    Only 9 or 10.
    Oh is that all. And here I was thinking you owned a bunch.
    Wanna add a craftsman 95 to your collection? I have a feeling you might have a welder I'd be willing to trade it for
    May 2010
    Port Orchard, WA.
    Mostly just some body work, I bought a new hood for the Short hood. And paint. It cost about $150.00 to paint one. The Red face didn't weld when I bought it, 15-minutes after I got it home I had it welding.
    Here you go.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
Page generated in 1,607,103,855.75525 seconds with 12 queries
