Results 1 to 8 of 8
Thread: idealarc 250 polarity switch
    Sep 2010
    Idealarc 250 code 7279. The switch has two fiber parts that the contacts ride on those parts are broken. The local welding store say's I can't buy parts have to buy entire switch.I hate to spend almost $300. if I could just buy those parts. Any help would be appreciated.
    Feb 2009
    IL
    Re: idealarc 250 polarity switch
    Might be able to find a used switch somewhere probably about half price. Check with Stumpfs - 618-566-4733 www.stumpfweldingsupplies.com
    Feb 2009
    Lafayette, Louisiana
    If you can't buy the parts, why not try to make them? The fiber is just to isolate the the current, correct? Why not use a cutting board (plastic) like you buy at wally world and cut it to fit? Just a thought, maybe I'm way off base.
    Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.
    -Cree Indian Proverb
    SA 200 Lincoln
    Victor Torches
    Sep 2009
    If you are like most, probably only use it DC+ , just hard-wire it, tape the extra wires off.
    The fiber is most likely Micarta, looks like a laminated fiberglass, available in different thicknesses. Can be cut and drilled easily to fit. It's been years since I've bought any (pre-internet), I'm thinking electric-motor rebuild shops, especially ones that do large DC motors. Assuming I got the spelling right above, could always do a google search ...
    Sep 2010
    I will try Stumpfs. I'm told that if it doesn't have perfect contact that the switch can get hot from arcing and may melt plastic. Sounds like it is micarta I will see if I can get some. THANKS GUYS
    Ceres, California
    the code 7279 is an AC only welder and does not have a polarity switch.
    at code 7100 they changed the switch. the $300 switch is a kit for the older machine that includes new conductor straps ( like wires) after code 7100 the switch is only $189
    Go look at your code number again. Are you looking for the line power switch or AC/DC polarity switch.
    Sep 2010
    My machine is labeled code7279 it is ac dc, all I know is what it says on the machine. I was told by Nordan Smith a new switch is $300 but later was told a kit was about $180. The Lincoln website had a drawing of the switch for code 7279 doesn't look like mine but is ac dc I think mine was updated. If I can figure out how to put a picture on here I will, thaks for your input . Micarta done the trick thanks JSFAB
    May 2008
    Orange, TX
    Quote Originally Posted by timberguy View Post
    If I can figure out how to put a picture on here I will, . . .
    http://weldingweb.com/vbb/showthread.php?t=111
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,713,258,550.08295 seconds with 17 queries
