Results 1 to 21 of 21
Thread: My lead reels
    May 2013
    South of Dallas
    My lead reels
    Started making my reels today. I need ideas how to attach them so they don't ground out the machine. I'm going to build a stand to put my welder on to get it off the ground around 4ft high
    May 2013
    South of Dallas
    Re: My lead reels
    Here's my machine
    Mar 2008
    Georgetown, Texas
    Re: My lead reels
    Mine are almost just like yours. I have a sq. tube leg on it with a piece of channel going back under the reel. I used 2 pieces of plastic cutting board for insulation, one under and one above the metal where they are bolted. There is a piece of plastic gas line like they bury in the ground(very tough stuff) that goes through the hole in the base and the holes in the cutting board. Haven't had a problem in the 25 years since I built them.
    May 2013
    South of Dallas
    Re: My lead reels
    I was thinking about doing something just like that but am afraid it would ground out
    Mar 2009
    Re: My lead reels
    My shop machine reels are a work in progress. I look forward to seeing yours complete. I need some inspiration to finish mine.
    May 2013
    South of Dallas
    Re: My lead reels
    I've been to 3 welding supply stores today to figure out how to attach the leads and they look at me with the deer in the head lights. Im going to have to sit down and see what I can come up with
    May 2013
    South of Dallas
    Re: My lead reels
    Heres what Ive come up with
    Mar 2008
    Georgetown, Texas
    Re: My lead reels
    The leads will attach to the reels with a bolt. Cut a hole in the side of the reel and run the lead out through the hole to a bolt that is welded to the outside. Just put a terminal end on the leads.
    Be sure to run a plastic tube through the holes in the flat plastic so that your bolts don't ground out.
    May 2013
    South of Dallas
    Re: My lead reels
    I was thinking I would attach the leads with a lug on the side of the arm and another one on the inside the reel
    Jan 2012
    West Rutland, Vermont
    Re: My lead reels
    I used a small hole saw to cut some insulators from the plastic for the bolts to go through on mine. Hooked up the leads the way your thinking too. Best thing I've built so far. It's so nice to grab and go and wind em back up when I'm done.
    May 2013
    South of Dallas
    Re: My lead reels
    I'm hoping they make clean up time faster
    May 2013
    South of Dallas
    Re: My lead reels
    I decided to go a different route. I made a stand for the welder to sit on top of and I'll be able to store stuff under it. I need to add d rings so I can strap down a argon bottle. Any other ideas before it gets a coat of paint?
    May 2013
    South of Dallas
    Re: My lead reels
    Attachment 1091171
    May 2013
    South of Dallas
    Re: My lead reels
    I finally finished it, I'll go tomorrow and buy new leads
    May 2013
    South of Dallas
    Re: My lead reels
    I now want a wire feed attachment for this
    May 2010
    Sparks, NV
    Re: My lead reels
    Quote Originally Posted by Millwrightdude View Post
    I have a Lincoln LN 22 and an ESAB suitcase feeder for sale...
    Sent from my SM-N910V using Tapatalk
    May 2013
    South of Dallas
    Re: My lead reels
    Wish you were closer
    Jan 2011
    Tx
    Re: My lead reels
    I'm a plumber. Instead of yellow poly gas pipe, I used scraps of pex water piping I had in the bed of my truck.
    Miller Bobcat
    Harris cutting outfit
    Miller spectrum 625 plasma
    Variety of shopmade tools
    Jan 2011
    Tx
    Re: My lead reels
    Normally you can buy pex by the foot from the neighborhood hardware store. Retail it might cost$2.00-3.00 a foot
    Miller Bobcat
    May 2013
    South of Dallas
    Re: My lead reels
    Heres what I used, insulators from generator job i was on
    Oct 2016
    Re: My lead reels
    Replaced my wife's suburban bearings last weekend and it was raining this weekend so I made a couple reels for my welding trailer. Insulated the stinger only with some nylon plugs drilled out. I added some stops after I took the pic
    '82 SA 200
    Ranger 8
    HH 140EZ
    Ironman 230
Page generated in 1,606,201,774.22393 seconds with 12 queries
