Results 1 to 5 of 5
Thread: gaps are too large on Automotive panels
    Feb 2011
    Ok, don't ask how it happened, but I cut too large a section for some patch panels. They are about 1/2 inch too large on each side. My "in my head" math must have been off. What would be the best way to fill these gaps? Should I cut some strips and weld on both sides? I need some help.
    Thank you in advance.
    Jan 2011
    Coronado. CA across the bay from San Diego, CA
    Re: gaps are too large on Automotive panels
    Well thatawould work for drywall, so why not sheet metal?
    Nov 2008
    What are you working on? If it is just a patch panel there is a panel bonding adhesive that can be used. It is callled Fusor. You could cut a strip of metal and bond it in place with the adhesive. It can also be used to bond the entire panel in place.
    Fusor on amason
    http://www.amazon.com/LORD-FUSOR-109B/dp/B0015PI6IC
    Fusor dispensing gun
    http://www.amazon.com/Lord-Fusor-LOR.../dp/B000ZK3124
    The gun is somewhat expensive but if you do a lot of bodywork the savings in grinding and metalworking the weld will pay for it.
    If you have pictures of the repair area it would help in providing advice.
    Feb 2011
    It is automotive. My camera is on the fritz but it is a door jamb section. I am in the process of converting my 4 dr wagon into a 2 door wagon, but I (like my original post had stated) cut out too much and now the door jamb just falls out. way too much gone.
    Oct 2008
    Boyle-Ft.McMurray
    The peice you cut out is probably to thin to weld in a newer one and make a good fix then make the replacement a larger and cut of the replacement part for a proper fit.I've seem guys cut frame members to short, I quess it happens.
Page generated in 1,713,274,983.07746 seconds with 19 queries
