Results 1 to 7 of 7
Thread: Miller plasma wiring
    Jan 2011
    Tx
    I just purchased a miller spectrum plasma cutter, I planned on running it off of my bobcat generator. I got my filer and separator finally connected and the durn 220 volt plug is different on the plasma than it is on the welder. Duhh. I even told the salesman what I had planned on doing. I would like to know if there is a conversion adapter or just change the plug end on the plasma.
    Miller Bobcat
    Harris cutting outfit
    Miller spectrum 625 plasma
    Variety of shopmade tools
    forest lake minnesota
    Re: Miller plasma wiring
    plasma 3 prong? boocat 4? if so you need . ADAPTER CORD,ENGINE DRIVE
    Field NEMA 14-50P to NEMA 6-50R. Adapts engine drive 120/240 V plug to common Millermatic and Spectrum 240 V plug.
    300517 $59.00
    I got one a few weeks bad from welding supply I don't think it was that much.
    Hopes this help
    Daye out
    Pound to fit, paint to match
    Jan 2011
    Tx
    Thanks Tig
    Miller Bobcat
    Jan 2011
    Tx
    Does anyone think this could be made,and are the parts available from an electrical wholesaler to build this adapter
    Miller Bobcat
    Jun 2010
    canada EH!
    home depot should sell both parts. However up here in Canada Tractor Supply Company sells the nice female 6-50r plugs with a rubber boot that look like normal extension cord ends. Just a thought.
    Ryan
    _______________________
    OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
    Quote Originally Posted by jw3 View Post
    Yes , but it may cost more to make.
    Los Angeles
    Most Electrical supply places do not stock or even know what a 6-50 Connector is.
    Connector is the Female part of the extension cord. These are different than wall mount
    6-50R ( R = receptacle)
    You could probably use one of those but they're not designed for it.
    You need
    1- 4-wire range replacement cord- this will have the 14-50 Plug on the end
    1- 6-50r wall mount
    or
    1- 4-wire Range cord
    1- 6-50c
    http://www.amazon.com/Hobart-770204-.../dp/B001FOPXSE
    MM211 (Sold)
    Klutch 120v Plasma cutter
Page generated in 1,713,254,335.15216 seconds with 17 queries
