Hi Paul,
This build really has my attention. I was hoping you could elaborate more on the spindles you used for this (make, year) or what spindles would work. I would assume that complete front spindle assemblies from a ford with disc brakes would be the best way to go. My research on Dana 44 front spindles left me confused. I would be using GM steel rally rims to match my 2500 and assume these rims would bolt onto ford 8 bolt hubs with no problem.
Troy
That's good to know. I will sit back and enjoy the build, and learn a few things.
Trailer Wheels
Chevy, Dodge and Ford use the large opening in the wheel to center the wheel on the hub. Dodge has the smallest, followed by Chevy and Ford has the largest. While the Ford wheels will go on to a Chevy or Dodge hub, the wheel is not maintained centric to the axle. I have seen wheel bolt holes get egg-shaped or break studs. It's best to use the proper wheel made for the hub you are using.
Trailer Axles
The nice part of using a Dana 30, 44 or 60 spindle is that the outer bearing is the same. Depending on the vehicle you obtain the hubs from, there may be a difference in the size of the inner bearing. Using a bearing chart from Timken, you can determine the correct size bearing to use. The setup with the Dana 44 gives a gross weight capacity of 8,000 lbs (dual axles). If you want more capacity yo will need to step up to a #99, #120 or #160 and a 5-1/2" tube.
You can always purchase factory spindles. Here are a few examples at http://www.al-ko.us/download/FULLCATALOG(1).pdf
If you have something specific to ask about the axle build, ask away.
Paul
I want to get back to working on my trailer project. It's been 6 weeks since I go out of the hospital. Still have a few issues with speech, stamina and total lack of energy.
The irregular hear beat I acquired as a result of the viral pneumonia is really doing a number on my blood pressure. Getting better slowly.
I will be starting on the hoist and drawing up each piece and have them plasma cut. want it ready when the cross members and deck is on the trailer.
A few of you voiced your concerns about the amount of over hang on the trailer---- I totally agree. The trailer I have built will become a 500 gallon water hauler. I have enough material to build two more trailer chassis, one of which will be a goose neck trailer.
I just need to get back to work as soon as possible.
Paul
Hope you make a full and speedy recovery.
SA 200
Idealarc TM 300 300
MM 200
MM 251
30a Spoolgun
Precision Tig 375
Invertec V350 Pro
SC-32 CS 12 Wire Feeder
Oxweld/Purox O/A
ArcAir
Hypertherm Powermax 85
LN25
Good to hear from you again
Will be anxious to see the hoist build but not at the expense of a relapse. I moved a little too soon after back surgery and paid the price, steady as she goes Paul.
Geezer
Power Mig 255C
185 TIG
Blue 175 MIG
Ranger 8 Kohler 20HP
Victor/Harris O/A
K 487 Spool Gun
Hi All,
Things have not been much better since my last post. Starting June 3, 2015, I have been hospitalized 6 times with pneumonia and have been out of the hospital for two weeks now. Didn't realize how much muscle mass and strength you can loose laying on your back.
Want to get back on the project and finish it. Winter is already here and freezing weather will be upon us in a few weeks.
Paul
Sorry to hear this.
Best wishes for your continued recovery
Syncro 350
Paul, sorry to hear about all you going through. You will be in my prayers.
Hope you are feeling better
It's been a long while since I started this project, just need to get back to work.
Since June 3rd, I have been hospitalized 7 times. It was because my blood pressure was too high or too low.
After I was released the last time, the wife and I started to question why I was in a yoyo cycle. Stopped taking the blood pressure meds. For the next 12 days all readings were in the normal range. Over the next 3 days, my blood pressure became slightly elevated.
In researching what and how each med affected blood pressure, we divided the meds into three groups--mild to very potent. Its been 60 days now that I have managed my own health care and I've recouped to about 70% of what I used to be.
Met with my VA doctor in mid December. I am on a device that monitors my blood pressure and weight remotely. The Doc had the data in front of him and said, "This is great." I then told him what my wife and I were doing to keep my blood pressure under control. He looked irritated, and then he said, "Just keep doing what you're doing. It seems to be working well."
I just have to wonder how many other people are over medicated and aren't aware of it.
Trailer Progress
After re-reading my earlier posts, I indicated that I was using Dana front spindles. What I forgot was to state that I was using the rear hubs on the axles. Because the rear bearings are much larger than the front spindle bearings, I made bearing and oil seal bushings to be press fitted on to the spindles and just for good measure, I used RED Loctite before pressing them on.
I will post pics on my next post.
I have also had many requests to provide more detail on the axle fab--coming soon.
Paul
Wow what a roller coaster ride you been on! Good to hear from you and glad your doing better. I agree with you I think doctors over medicate all the time. It sounds like your wife is a better Doctor then the one you had. I will pray you continue to feel better and like most I am excited to read about your trailer build.
A while back I had my Millermatic 250 stolen and I was determined to replace it.
Purchased one sight unseen from the Uvalde TX School District for $350 and another $130 to have it shipped to Albuq. Plugged it in and the wire feeder worked fine however there was no power for welding. Using the Miller manual I was able to troubleshoot the unit and found VR-1 connected to CR-1 had a burnt varistor. The part was $5.54 from Miller.
By the looks of the machine, it has more miles on its castors than actual welding time. A lot of school districts auction of their equipment as soon as it stops working no matter how minor the issue may be.
Paul
I just want to say THANK YOU to all the forum members that have expressed their "Get Well" wishes during my bout with pneumonia and irregular heart beat. It's been a year since I was active on my trailer build. I was hospitalized a total of 13 times and now have a pace maker in my chest. This will definitely put a damper on welding for me unless someone knows a way around the issue.
I'm still not 100%, but well enough to want to get back into mix. The trailer project sat idle the entire time and last week I was determined to try and finish the project. The purpose of the trailer has changed. I had rented a storage space and had it for 22 years and the owner passed away. The daughter wants to sell the M-1 Industrial property and has booted us out. I also have to move my 3 horses. The location where I will be keeping the horses has no water and it's $40,000 to drill a well 1,000 feet deep. Gona have to haul water for the horses. There is a county water fill station just a mile away from the property and the trailer will now be used to hold a 500 gal water tank.
I will take pics of the progress and include them in my next post.
Again, thank you for being concerned and wishing me well.
Paul
Paul, Glad your on the mend. Sorry for your situation. Hopefully you can find a way with your pacemaker.
Hi Paul, So very pleased to see ya around. Was looking your thread over a couple of days ago.
I to have battled irregular heart beat for several decades. The side affects really made me feel lousy, but after a couple of ablations and meds, doing much better. I dunno, but I heard there is a vest one can obtain that shields your chest, not sure and that would obviously take a good deal of research. Anyway that is the least of your concern at the moment, just pleased you are up and about.
God BLess
Geezer
Power Mig 255C
185 TIG
Blue 175 MIG
Victor/Harris O/A
K 487 Spool Gun
Here are some progress Pics
Attachment 1582441
Attachment 1582451
Attachment 1582461
Attachment 1582471
Attachment 1582481
Took about 4 hours to complete the electrical. For those of you who have worked with trailers, you know how troublesome loose and hanging wires can be. Loose or unreliable grounds are the #1 problem with trailer lights. The weather tight junction box is the only break point in the electrical system. Grounded at 3 points including a wire run to the truck chassis.
This is a pic of the cross members. Haven't decided what type of deck to put on it.
Open items not completed
Trailer Deck
Jack
Safety Chains
Set of ST tires (Load Range J)
Brakes
Side Pockets at deck height ?????
Install raised side panels ????
Took the trailer for a test ride and it tows really well. As it sits, there is only about 150 pounds of weight at the tongue. Loads will have to be centered over the wheels. Overall I'm very please with the way it's coming along.
For those of you who were waiting for the scissor hoist, here are a few cad drawings I put together,
Nice thing about any cad is that you can rotate the components and be assured that everything will clear before you ever build it. The cylinder length that most manufacturers use for a cylinder is a 24".
Hi All,
I have finally got back to finish up on the trailer build .... been 2 years. My health has stabilized at about 50% of what it used to be. Everything is at a slower pace and takes twice as long as it should.
I installed new bearings and races on all 4 wheels as well as new grease seals. I can't believe the cost difference of hardware between an auto parts store and a trailer supply. B & J Trailers here in Albuquerque is about 1/3 the cost for the same bearings (Timken or SKF) from an autoparts store.
Still need to install the disc brakes and lines. Will also be adding a few more cross members and a stiffener at the bend on the tongue. Just as a bit of ins
Fabricated end caps for the axles and added a grease fitting. Could also have gone with oil bath.
Photos will follow in a few days.
Glad tomsee your back and working again. Looking at your main frame is see some things I would change. The crossmembers near the suspension should be at the spring hangers and full height so the are attatched to both the upper and lower flanges of the side rail. Without theat you can get fatigue cracking like this.
Your crossmember in front is also in the wrong spot and can result in failure of your tongue too. This is a more likely spot for failure for you as this one is particularly far off and will allow the bend in the frame to flex and fail. You may get by with the ones at the suspension, but I don't see the front one holding up to any kind of significant load. Here are some drawings I did up previously to explain how that works and why your design might fail.
Attachment 1670581
Jon
Yeah, I know, but it'll be ok!
Lincoln Square wave 255
Miller Vintage mig
30a spoolgun
Thermal Dynamics Pacmaster 100xl plasma
Smith mc torch
Ellis 1600 band saw
Welder J,
Thanks for the tips on the trailer fab. I still have some additional stringers and gussets to install.
My string of bad luck continues. I had a Landa 2000 pressure washer and 300 gal tank on a trailer. I had been using the rig to water my 3 horses as there is no water on the 37 acres (dry NM). Someone torched my gate and took off with it. The previous week I had 30 sheets of roofing material take a walk as well.
I have a 500 gal elliptical tank that is un-mounted. My wife thought she had a brilliant idea. She suggested that I use the trailer I am working on until I can replace it with something else. hummmm .......
Here are a few progress picks
I fabricated caps for the hubs and added a zerk fitting for greasing the bearings. I could have gone with oil bath as well
This is the completed and installed hub assembly. Really like how smooth they rotate. Had a difficult time finding 2" spindle washers locally and the ones I did get needed modification to fit the guide on the spindle.
Electrical on any trailer always becomes a problem after a few years of use. I found the junction boxes with grommet seals for about $10 and ran conduit to the coupler. If anything, it looks clean.
