Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: Cleaning rust off asphalt driveway
    May 2016
    Spokane, WA
    Re: Cleaning rust off asphalt driveway
    Quote Originally Posted by aevald View Post
    Hello Econdron, we use muriatic acid on our sidewalks and surfaces around our swimming pool, it works very well also. You can generally buy it in 1 gallon plastic jugs and cut it with a little bit of water, spread it around, scrub a bit with a push broom, and then rinse it off. Good luck and best regards, Allan
    I second Muriatic Acid. Especially for Concrete. I also used it in a pool environment, back when I built and remodeled Gunite/plaster pools in Eastern Washington. I used it to acid wash plaster, and to acid wash decking around pools.
    RGL Motorsports LLC
    Jun 2017
    I was wondering what worked too as I have the same problem. Did find this info:
    "Acids will make a mess of asphalt so you want to stay away from them as a stain lifter ..."
    https://cleaning.tips.net/T006569_Re...Driveways.html
    Jun 2016
    Back to the jungle
    Geebus Moohammed Wally. Lets re-invent oxygen ! $25 Go buy a bucket
    http://www.homedepot.com/p/Latex-ite...3066/100479155
    Quote Originally Posted by KitCarson3 View Post
    I seriously doubt that "acids will make a mess of asphalt." Asphalt is essentially like an oil or wax, which means that a base (or alkaline chemical) might attack it (like lye attacks fats/oils) but not an acid. That's why acid containers are often made out of plastic (which like asphalt is made from petroleum).
  5. #30
    Jun 2017
    Thanks. a detail from organic chemistry that I'd forgotten!
Page generated in 1,713,261,478.42846 seconds with 17 queries
