Results 1 to 25 of 27
Thread: What is a budget friendly quality plasma cutter that can cut at least 1/2"?
    Nov 2015
    Houston
    I am in the market for a plasma cutter and my budget is roughly $500.
    How well do the consumables hold up?
    Not looking for a cheap POS that is going to give me trouble down the road.
    Thanks,
    LoneStar
    Feb 2009
    Re: What is a budget friendly quality plasma cutter that can cut at least 1/2"?
    when you stop dreaming or increase your budget youll be on the right track..lol
    Mar 2009
    Cutmaster 42
    Order it today from Zoro Tools and get 25% off making it $863.
    http://www.zoro.com/victor-thermal-d...Q&gclsrc=aw.ds
    May 2010
    Sparks, NV
    For that budget, Craigslist
    Sep 2009
    Sedona, Arizona
    craigslist OXY cutting is in your future. your $500 budget and list of requirement sounds like a Diddy backstage rider. So no plasma cutter for you. Do you even have a big compressor with a new or fully serviced dryer and water separator?
    Nov 2014
    Quote Originally Posted by LoneStar View Post
    Thanks,
    LoneStar
    Stick to your budget. It is VERY possible to get a decent plasma cutter for that price.
    Others here can laff, but a few years ago I bought the older blue Harbor Freight plasma cutter...Then I hunted down mechanic 416 and bought consumables from him including circle cutter for it....The machine really performed well for me...never the first problem...I used it several times to cut 1/2" HRS, but usually thinner.
    I got a bug up my butt and bought first the Hypertherm 30, then added the Hypertherm 45 and gave the HF cutter to some kids in the hood that were into big mud trucks...They still use it with no problems.
    I've heard good and bad about the newer Harbor Freight plasma, but I can only attest to my experience with the older blue unit and it was all good.
    Friend, I'm the first to tell you plasma is cool to work with, but also the first to say that a good ole gas torch burning oxy/propane is usually all a guy needs to cut steel....I have both because they both have their best to offer depending on what's needed....Oxy/fuel will never go out of style because plasma simply can't heat and bend and braze, or easily go out in the boonies with you like gas can.
    Jan 2014
    Hallieford, VA
    Quote Originally Posted by wornoutoldwelder View Post
    Good observation you old super-swabbie.
    Jerry
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Feb 2014
    n.w. of chicago
    Quote Originally Posted by storeman View Post
    Jerry
    And it makes one of the most versatile welders aluminum included, people forget oxy acetylene welded a lot of this country, me included, plasma cutters are way overated, to inaccurate by hand unless close is good enough
    Nov 2014
    Quote Originally Posted by pat h View Post
    That little light plasma torch takes some getting used to......It's super easy to forever etch in metal your bobbles and wiggles, huh? A gas torch is much heavier and less prone to wandering when you twitch.
    It really helps to get a plasma torch setup that allows you to drag the tip....Even possible with the HF unit with right consumables.(mechanic416)
    I've learned best bet for me is to use a pattern or straight edge when cutting with plasma....plasma seems more sensitive to speed and standoff over gas....Using a guide removes just one variable where the the remaining ones are challenge enuff.
    Don't get me wrong-I love plasma...I just hate that I often ain't good nuff to use it the best it is capable of being.
    Feb 2014
    n.w. of chicago
    Worn out welder I agree with your last paragraph, 100%, me either, same with a torch anymore,
    May 2015
    Barre Town, VT
    I can vouch for Craigslist. I only paid $40 for my plasma cutter! Granted it had been crushed under a truck on a lift and took 3 months to rebuild, but after parts it only cost $120 total.
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Feb 2009
    Chicago
    Thanks,
    LoneStar
    http://www.harborfreight.com/240-vol...lay-62204.html
    Hypertherm Powermax45
    Esab ET220i
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Carbide3d Nomad3
    Sherline 4400 CNC Lathe
    Nov 2014
    When it comes to cutting metal, there really ain't no cheap way out...or I would have found it.
    Yaknow, when we first get into welding, we always first consider the cost of the welding machine where we buy whatever we can afford....THEN we discover the metal we want to weld needs to be first cut.....so perhaps we get a cheap grinder with a thin cutoff wheel and/or maybe a hacksaw....and it's THEN we discover just how hard it is to cut metal accurately and cheaply, just so we can weld it up.
    I'll tell you right now the biggest investment I ever made, and continue to make, is in how to cut metal before I weld it. Plus grind and shape it. Plus clean it.
    I just tonight dropped over 3K buying a horizontal bandsaw and clamp just so I could cut metal accurately...Plus I have another 1K in grinders and disks and table clamps easy...And I bytched cause I paid 1500 for my mig, and 3K for my tig, and another 1 or 2K for gas bottles...Just so I could weld up stuff....Stuff that first had to be cut and sized and ground and cleaned and handled before I could make the first arc.
    So ok, let's total it up....I got over 3K in plasma and gas cutting crap....Plus another 1 or 2K in grinding/shaping stuff. PLUS another 3K in just a bandsaw....but on the welding end I got maybe the same-no, not near the same.....so ok, cutting proves to be just as expensive or more as welding when it is done right, and can go much higher when you figure in notchers and rollers and other fab stuff.
    If you are serious about welding, then calculate that cutting equipment will cost the same as welding equipment or more....and take up more space....and make more noise...and use more electricity....and take more time.
    Jul 2015
    Central Florida
    The Eastwood Versa Cut40 is listed at around $550 but is only advertised to cut 3/8". The Cut60 goes to 7/8" but also jumps to $699 ($679 at CJ Pony Sales).
    http://www.eastwood.com/versa-cut-60...parent_id=5571
    I just bought a Versa Cut60 and it's a pretty nice machine. I haven't used it over the 30 amp setting yet but it has blown through everything I've put under it.
    For $500 and 1/2" you might end up looking at used cutters. I've watched for months around and there haven't been any used ones for sale at all. You might get lucky in your area though.
    Millermatic 180
    Hypertherm PM65 083300
    CandCNC Dragon Cut Linux 620-4 Bundle with Linux Computer
    Precision Plasma Magnum HD 5x5 Gantry kit
    Nov 2015
    Houston
    Thanks for all of the feedback. I took some of the advice on here and was able to get a gas torch set up for almost nothing. This will make due until I can increase my budget for a decent plasma cutter.
    Best Regards,
    Lonestar
    Dec 2012
    Woodstock, Ga
    Quote Originally Posted by roadkillbobb View Post
    Man ain't that the truth, must have wondered over from the GJ, lots of beer pocketbooks & with Champaign taste hang there.
    Magazines have issues, everything else has problems
    Jan 2011
    Isn't this the truth!!! If this were so,everyone and their dog would have one.HaHaHaHaHa
    Feb 2009
    I wish I could purchase stuff for what people think it should cost.....gona plant me some money trees in the spring.$$$$$$$$$$$$
    San Lorenzo,CA
    Everlast has a 50amp plasma/200amp tig combo for $650 on amazon supposed to cut up to 3/4"
    Jan 2008
    Lansing, MI
    Jasic Razorweld is selling some pretty nice units at reasonable prices.
    Saw some real budget friendly machines in their display at Fabtech. The company officers are first rate. Three year industry standard warranty, no games or BS posts on Internet forums. Just a decent product for the money. Sure, their Chicom machines, but the guys running the company struck me as some decent stand up dudes not trying to bullshlt anyone or scream at the top of their lungs how much better their product is over the "other" guys.
    Dan from Razorweld posts here once in awhile. I've met him twice in person. I would give him my business.
    Hoping to pick up one of their stick machines to demo at some point soon.
    May 2010
    Sparks, NV
    Quote Originally Posted by EvilBunny View Post
    No, Just no. Do not buy a combo machine with built in plasma.
    May 2010
    Sparks, NV
    PM Gamble, he is pretty familiar with razorweld product line
    Jan 2008
    Lansing, MI
    Yeah, we hooked up at Fabtech. I'll prolly get with him with what I have in mind when I'm ready and see what his thoughts are.
    I'm not saying by far I know everything there is to know about Razorweld, but I was thoroughly impressed with the guys I met both times in Chicago. They just seemed like real straight shooting dudes who put a lot of their own personal time and money into bringing their machines to the US. I believe they have been selling Jasic for some time in AUS and NZ.
    I've never been a big fan of the Chinese stuff, but I have come to see that if you get the right ppl selling it, it's not a bad value at all for the money and when you get stand up guys running the sales end of things and standing behind their product, it takes a great deal of the "Mailorder Mayhem" as Terry likes to say and risk out of the equation.
    Reputation alone is a big reason I feel the way I do about certain import sellers. Dan and Chris made a point of telling me they had invested considerably in this and didn't wanna fall on their faces right out of the gate. They have a lot riding on this from what they said. They wanted to do things right.
    Makes me more than willing to give them a shot.
    IMHO of course
    Delaware
    I sure hope the Jasic line is a lot better then it was 5 years ago
    Jun 2011
    Texas
    Excellent point. And you can cut pretty darn well with oxy/fuel, too, if you take time to practice. About a month ago I was watching an old-timer cut some 3/8" plate with a plain vanilla oxy/acetylene rig. I swear that cut was smooth as butter, and there was maybe 1/16" of slag on the underside, almost none. He has no use for a plasma cutter.
    -Ruark
    "Become one with the puddle, grasshopper" - Welding Instructor
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
Page generated in 1,713,307,120.00984 seconds with 17 queries
