Results 1 to 15 of 15
Thread: Random Projects
    Random Projects
    Going through some old pictures on the computer today and found a few photos...I always enjoy seeing what others have been working on, so figured I'd post a few of the projects that I have pictures from.
    "Cross Box" for a David Brown tractor restoration - batteries go in each end compartment, toolbox under the seat, and the flat part with the 8 holes is where the seat sits - the holes give some fore-aft adjustment for the seat position.
Size:  60.1 KBName:  iPhone 046.jpg
Size:  62.6 KBName:  iPhone 051.jpg
Size:  64.2 KBName:  iPhone 067.jpg
Size:  63.9 KBName:  iPhone 090.jpg
    Re: Random Projects
    A few of the aluminum jobs I've worked on for a local fish farm
Size:  69.8 KBName:  iPhone 017 (2).jpg
Size:  64.3 KBName:  iPhone 022 (3).jpg
Size:  32.7 KBName:  iPhone 026 (4).jpg
Size:  57.4 KBName:  iPhone 027 (2).jpg
    Re: Random Projects
    New set of mounting ears on a ripper tooth - to fit a Case backhoe
Size:  85.1 KBName:  iPhone 062.jpg
Size:  50.1 KBName:  iPhone 068.jpg
    Re: Random Projects
    Residential Railing Install:
Size:  27.3 KBName:  iPhone 072.jpg
Size:  55.0 KBName:  iPhone 073.jpg
    Re: Random Projects
    Ditching bucket modified to wedge-style quick coupler:
Size:  69.9 KBName:  iPhone 020.jpg
Size:  77.6 KBName:  iPhone 026 (2).jpg
Size:  58.1 KBName:  iPhone 040.jpg
Size:  65.7 KBName:  iPhone 070.jpg
    Re: Random Projects
    3 compartment seed and fertilizer bin...pictures are a little out of order:
    Name:  iPhone 002 (3).jpg
Size:  62.8 KBName:  iPhone 002.jpg
Size:  55.0 KBName:  iPhone 003 (5).jpg
Size:  111.0 KBName:  iPhone 009.jpg
Size:  98.2 KBName:  iPhone 014 (3).jpg
    whitewater, mt.
    Re: Random Projects
    You are currently my new hero. The boxes for the Case are sweet.
    Arcon Workhorse 300MS
    Powcon 400SMT
    Powcon SM400 x 2
    Powcon SM300
    1968 SA200 Redface
    1978 SA250 Diesel
    Miller Super 32P Feeder
    Pre 1927 American 14" High Duty Lathe
    K&T Milwaukee 2H Horizontal Mill
    Bryan
    Re: Random Projects
    New lift arm mechanism for cultivator - the old ones were bend and the geometry didn't give the cylinders enough power to lift the wings after the rolling baskets had been installed:
Size:  66.9 KBName:  iPhone 035.jpg
Size:  51.4 KBName:  iPhone 036.jpg
Size:  77.4 KBName:  iPhone 040.jpg
Size:  109.0 KBName:  iPhone 043.jpg
    Re: Random Projects
    Set of troughs and stands for the fish hatchery:
Size:  92.7 KBName:  iPhone 004.jpg
Size:  61.8 KBName:  iPhone 023.jpg
Size:  80.0 KBName:  iPhone 024.jpg
Size:  33.2 KBName:  iPhone 026.jpg
    Re: Random Projects
    Last one I've got for the moment....little set of hangers to suspend discharge pipe within a large culvert:
Size:  60.8 KBName:  iPhone 079.jpg
Size:  77.3 KBName:  iPhone 156.jpg
Size:  67.5 KBName:  iPhone 159.jpg
    new york city
    Re: Random Projects
    Quote Originally Posted by djd775 View Post
    djd; nice work. looks factory built. no, better.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Aug 2008
    Sudbury, Ontario
    Re: Random Projects
    Really nice work, looks like factory oem.
    "The reason we are here is that we are not all there"
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
    Hellinois
    Re: Random Projects
    WOW!!! AWESOME work, for sure!!!
    How do you cut the mounts for the buckets? I do bucket repairs, but not enough to afford a plasma table. But I like to do the highest quality work I can. Keep the pics comin
    "Stick-man"
    Re: Random Projects
    Quote Originally Posted by blawless View Post
    Thanks!
    Quote Originally Posted by docwelder View Post
    Thanks
    Quote Originally Posted by norite View Post
    Thank you.
    Thanks. I lucked out a couple years ago and found a used PlasmaCAM DHC2 for sale locally. I don't know if I'd have been able to get into a CNC setup if it wasn't for finding the deal that I did. I have a Hypertherm PM85 on it, and I built a mount for a Victor 310 machine torch that I run oxy-propane for squareness of cut in the heavy plate. It's the oxy-propane that I used to cut the bucket mounts.
    Re: Random Projects
    Some 1-1/2" plate that I was notching today for quick attach mods on a Terex loader. This is about as thick as I can fit on the table before gantry clearance becomes an issue.
    I built a custom grate system with a removable section so I can cut up to 6x10 tubing...saved myself a lot of drilling on different projects by doing that.
Page generated in 1,611,414,539.38101 seconds with 14 queries
