For the resident welding machine experts: can I hook a Miller Spoolmatic spool gun up to my Thermal Arc Fabricator 252i?
I could swear I've seen reference to this issue on the forum before....but despite lots of searching, I can't find it back.
Here is the wiring diagram for my welder's 10-pin accessory socket:
And the pinout from the Spoolmatic manual:
To the best of my knowledge, it seems like this should work...I don't know enough about possible differences in resistance values, motor amperage values, etc....but the voltages and trigger configurations seem to line up well. Am I missing something, or can this be done?
Also, I've been wondering if it's possible to power a larger push-pull cabinet from this power source (such as a Cobramatic, etc). It seems like I could use the contact closure in the 10pin accessory socket to energize the weld power circuit, supply an external 115V power to the feeder and be good to go. Does this seem reasonable? I've been looking around for more info and availability on the Tweco torque assist guns that I've seen mentioned on this forum, but can't seem to find much.
In essence, my current spoolgun is becoming insufficient, so I'm weighing options for replacement. It would be great to get away from the 1lb spools and up to full size 12" spools, but cost is definitely a consideration in the short term.
