I recently purchased a Hobart 210MVP to weld up some 1/4" steel plate in the yard. I intended to install a 220V outlet in the garage to facilitate the work, but the electrician said that would require a new underground conduit between the main panel at the house and the detached garage. Too much expense to do right now.
I've used the welder in 120V mode with decent results (the work is decorative, not structural; complete penetration is not necessary), but I'd rather use 220V if I can.
The nearest 220V outlet is a 220V 30A three-prong for the dryer at the main house, about 100 feet from where I need to use the welder. The welder uses a maximum of 240V 24A at its rated output. The owners manual claims that a 14 gauge extension cord may be used with a maximum length of 53 feet, but gives no other guidance. 14 gauge stranded wire has ~ 2.5 ohms resistance per 1000 feet, while 10 gauge has ~ 1.0 ohms resistance. Is there any reason I can't use 10 gauge to make an acceptable 100 foot 240V 24A extension cable that is safe?
Also, any idea where I can get the appropriate plug ends?!? I think it's a 10-30 plug at the dryer and a 5-50 receptacle at the welder end.
Thanks,
Beuford
