Results 1 to 12 of 12
Thread: Sa200 gear tooth
    Sa200 gear tooth
    So I removed the magneto since it has no spark and inside the timing cover I found, what appears to be, a broken tooth off the gear. Before I start tearing my sa200 apart, I just want to make sure it is totally necessary. I checked the governor and nothing seemed to be missing off the gear. Any help is appreciated.
    Oct 2013
    cntrl FL
    Re: Sa200 gear tooth
    Doe's the Impulse coupling still snap, when you turn the mag over by hand?
    SA 200s : 1944 1945 1963 1965 1969 1980
    1981 SA 250 D3.152 DC only
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    May 2008
    Orange, TX
    That's not a governor, cam or crank gear tooth. They are all helical type.
    BYW200 might be on to something with the thought of a piece from the impulse coupler. Specifically the end of one of the "dogs" that make contact with the stop screw to cause it to wind up before it releases. But even then, it looks too small for that.
    Is it a metallic or fiber material?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    It's metallic. And the impulse coupler does snap.
    Jul 2012
    My first thought was a part of cam thrust washer/ hold on plate .
    May 2008
    Orange, TX
    Quote Originally Posted by _gomez_ View Post
    Twice for every revolution or only once? What brand mag?
    Quote Originally Posted by guajilloweld03 View Post
    Too small for that I believe. Both 2-bolt and earlier 3-bolt designs.
    I still think it's part of an impulse coupler dog.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2012
    Broken dog would go with no start or hard start condition.
    May 2008
    Orange, TX
    Agreed on possible hard start as the impulse coupler wouldn't catch for every other cylinder with one bad dog but it wouldn't surprise me if it started with no problem with just one - if that's where this piece came from.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    I believe it is. I fished out another piece and looked at the mag and sure enough he impulse coupler was broken.
    May 2008
    Orange, TX
    Which make mag? Just curious.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    It's an American bosch
    May 2008
    Orange, TX
    That's why the piece didn't look like a Fairbanks-Morse impulse coupler dog.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,607,059,093.64330 seconds with 12 queries
