Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Thread: Best quality multimeter for general testing?
  1. #51
    May 2010
    Sparks, NV
    Re: Best quality multimeter for general testing?
    I use this one when testing the AC and DC response on welders, very happy with it Amprobe ACDC-100 http://www.amazon.com/dp/B001HNDM5Y/...ing=UTF8&psc=1
  2. #52
    Aug 2008
    Sudbury, Ontario
    Congrats on the 117, excellent choice, you will be very satisfied.
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
  3. #53
    Aug 2018
    I am looking for a cheap alternative. Fluke 117 price is 162 bucks but my budget is only $60 bucks. Which type multimeter I should buy for general home use?
    I was searching for the best multimeter for the money and found an article about Multimeter Reviews https://bestmultimeterreviews.org. I have found mastech multimeter as a cheap option & bought that.
  4. #54
    Sep 2014
    I had a Fluke 175 for almost eight years. I lost it on a job; we believe a new guy thought it was his and took it with him, on his first and last day on the job. I liked the 175, but it was slow to beep in continuity mode. I had read that the 87v was fast, so I bought it. It cost almost $600 after I got all the different probes for it.
    I use my meter for two hours straight sometimes, looking for ground faults. It is much better than my old 175 because it instantly beeps if there is continuity. That may not sound important, but when you are trying to find a ground fault in a fire alarm system in a high rise, it is very important. Also, it can withstand a fall from a ladder, or if I am working on a standpipe on a ladder troubleshooting a water flow, and I have it suspended by its magnet from the standpipe, and it falls it is not affected. I do not do that, but it will happen.
    But I believe as many have said that almost any common meter will work for what you are doing.
    Sincerely,
    William McCormick
  5. #55
    Sep 2014
    Both the 175 and the 87v measure hertz. It is important if you have a data line that will show voltage as if it is a constant voltage. With the hertz capability, you can see it is pulsed DC rather than continuous DC. Also for AC frequency drives you can see what the hertz are.
    Sincerely,
    William McCormick
  6. #56
    Mar 2017
    Dubai
    Quote Originally Posted by deskion View Post
    As cheap but good alternative, you should look at Uni-T, they are good multimeters and have been reviewed to death.
  7. #57
    Dec 2011
    I have several Fluke meters and they all work great. Any time the voltage reading is off, change the battery. I had one that instead of 240 volt read 175 or so. The ohms readings were still all right but the voltage reading was the only thing wrong that I noticed. All other meters I had used would be way off on ohms readings not being able to zero them out when the battery was low. The most complicated meter I have is an old OTC automotive meter I bought on EBay years ago. It came with a full set of leads for cars with several sizes of back probe leads, RPM, DC/ AC amp clamp meter, and a full set of thermo-couples for air and liquid and contact. Very nice meter they don't make any more.
Page generated in 1,713,263,341.05035 seconds with 17 queries
