Page 25 of 26 FirstFirst ... 1523242526 LastLast
Results 601 to 625 of 632
Thread: The Welding Cart Thread... Post 'Em Up!!
  1. #601
    Aug 2016
    Michigan
    Re: The Welding Cart Thread... Post 'Em Up!!
    Nope. Completely fabricated by me.
    Sent from my LG-TP450 using Tapatalk
    Miller Syncrowave 300(s)
    Miller 330 A/BP
    Miller CP-200 Haas / Kamp'd / CP-300 in process
    Miller Radiator 1
    Miller 30A /S-52E feeders
    Hobart GR-303
  2. #602
    Dec 2009
    Greenville TX
    @86turbodsl can you tell much difference in the sync and the a/bp with tha square wave ? always been curious
    thermal arc 252i - millermatic 350P - miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs - Hypertherm 1250 G3
  3. #603
    Quote Originally Posted by 86turbodsl View Post
    Nice!
  4. #604
    Aug 2016
    Michigan
    Quote Originally Posted by woi2ld View Post
    I haven't been able to tell on steel. Maybe on aluminum. Haven't tried aluminum yet.
    Miller 330 A/BP
    Miller Radiator 1
    Hobart GR-303
  5. #605
    I just finished the tank mounts on this cart that I needed to modify
    and even had time to throw a coat of semigloss black on before dinner.
  6. Likes ronsii, whtbaron, VaughnT liked this post
  7. #606
    Looks great!!!!!
    Only one thing I would have done different but I won't get into that...
  8. #607
    The fenders made a come-back.... looks great even if Ronsii doesn't like the color! Wheels look familiar... think I've got a couple sets of those too...think PraxAir would complain if I started painting their cylinders to match my carts?
    Princess Auto flyer specials !
    And don’t worry about ronsii. He’s in “transition”.
  10. Likes ronsii liked this post
  11. #609
    Looks great!!!!!
    I don’t even want to know after what you did to poor Pat’s dog!
  13. #610
    But ... He was smiling the whole time....
  14. #611
    Here’s a couple pics of the “Tip, Slide and Drop” gas mixer base for the welding cart. Designed for quick tool-less install and removal.
    View of underside
    Tip and Slide position
    Dropped in place and secure.
  15. Likes VaughnT, whtbaron, ronsii liked this post
  16. #612
    Swivel Mig gun holder. Stops 45 degrees either side of vertical courtesy angle iron scrap.
  17. Likes ronsii, Munkul liked this post
  18. #613
    Cup holders also work for holding tig rod tubes
  19. Likes ronsii, psacustomcreations liked this post
  20. #614
    Outside of Raleigh, NC
    Lis, I always enjoy your posts and seeing your fabrication artistry. Thanks for sharing.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  21. #615
    Thank you for the compliment!
  22. #616
    Dec 2012
    I built this a few weeks ago using scrap metal from a clothing rack. The top and bottom panels are floor boards from a CRJ-200, they just happened to be the perfect size for what I wanted to do. The file cabinet is a non-structural part of the cart, it is just bolted on from the bottom where the adjustable feet were. The bottle holders are seat belt extensions that have a total open size of 7.5 inches, so even if the adjustment slips they aren't much bigger than the bottles.
    I'm still deciding on what if any cable management I want to do and adding some tig rod holders.
  23. #617
    Mar 2005
    Under a Rock
    Last year I made a reptile tank stand for my niece.. this year she went off to college and gave away the reptiles....
    So I took it back and re-purposed it....
    need to add some locking casters and hooks etc.
    everything together will save me room also....
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  24. Likes Lis2323 liked this post
  25. #618
    Nice repurpose and efficient organization, John
    Your multi machine setup is screaming for gas line quick couplers and Y valves if you haven’t already done so.
  26. #619
    Lis,
    Is there anything exceptional about those gas couplings over regular airline couplings?
    ---Meltedmetal
  27. #620
    Nov 2014
    Southern CT
    I posted this already in the Esab forum but I'll add it to this thread.
    Aluminum tube frame, steel sheet metal panels and drawer, though rear axle, bolt on front swivels, and a pull-tight MC strap for the tank.
    Handle doubles as a place for the cables/hoses and is tubing with the ends capped and machined.
    I tested the balance with just the water cooler to make sure the tank didn't make it do a wheelie.
    The drawer is bent up like my favorite tool box brand .
    I haven't had the need for a cart for many years. The other machines are monsters on their own under carriages.
    Ernie F.
  28. Likes Equilibrium liked this post
  29. #621
    Lis,
    Yes. They are NOT NPT. Typically 5/8-18 for inert. 9/16-18 for O2.
    Plus they need to have the ball swivel end to seat.
  30. #622
    OK Makes sense. Thanks.
    I see the other exceptional thing about them is the price.
    ---Meltedmetal
  31. #623
    Yeah....there’s that too
  32. #624
    I did my best plumber impression (sans butt crack) and made up my gas line hoses and got them routed half decently.
    I even found an oil filter seal that fit tig rod canister holes to use as a grommet.
  33. #625
    Mar 2005
    Under a Rock
    I like those bottle straps...
    need to find a couple of those.
    Hypertherm PM 45
    HTP 221
Page generated in 1,594,104,382.32540 seconds with 13 queries
