Results 1 to 25 of 27
Thread: Not another trailer build
    Dec 2014
    Arizona
    Bought an engine drive from a guy in California and we had to build a trailer for it. Welded everything with my little Lincoln Pro Mig 180T. Its not quit finished yet but this is just 2 weekends of work so far.
    Lincoln Weldanpower 225 AC/DC
    http://weldingweb.com/vbb/showthread.php...Em-Up!!/page14
    Dec 2014
    Arizona
    Re: Not another trailer build
    a few more pictures
    Dec 2014
    Arizona
    We had to modify the welder slightly to get it to fit the way we wanted it to but all in all i am very pleased with the way it has turned out
    Soda springs,Id
    Nice build!! Maybe you plan to, but I'd skirt the inside of the fenders for strength and to keep mud and water off both ends of the welder while traveling on the road. Also maybe some 1/8"x 1" flatbar around the inside of the fender on the outside of them again for strength if for nothing else if a fat a$$ gets parked on it.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Dec 2014
    Arizona
    Mike
    Lol yeah we plan to do all of that just ran out of material today and time.
    Apr 2008
    Yuma AZ
    Yes, we need inner fenders, paint, tires & plates.
    Don't tell me a 70Amp HF MIG welder can't glue metal together.........................
    Mark
    Craftsman 12"x36" Lathe
    Enco G-30B Mill
    Hobart Handler 175
    Lincoln WeldandPower 225 AC/DC G-7 CV/CC
    Add a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG
    PapaLion's Gate Build
    Nov 2012
    new york city
    Quote Originally Posted by MarkBall2 View Post
    markb; while you're at it capping the tube ends wouldn't hurt. nice build.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Apr 2008
    Yuma AZ
    We were going to put a tail light panel on it, but it would put the tail lights lower than the minimum of 15". After it's licensed, we may still do that. That would cap the ends of the tube.
    Mark
    Enco G-30B Mill
    Hobart Handler 175
    Jul 2013
    Pine City mn.
    I think a plate on top and bottom of the tubes where they make the bend would be a good idea. That is a critical area for that style tongue. You have no flow through beams, but instead a welded joint all the way across at almost the center of the beam span from axle to hitch, which is the highest stress point. In adition to carrying the weight you have a lot of up and down stress added to that area, especially do to that upright frame which will give you a high center of gravity and will compound the stress added too that joint. A plate top and bottom at the bend will significantly reduce the posibility of stress cracks there. When I do one like that they always get a plate both top and bottom.
    Otherwise a real nice trailer that should work well.
    Jon
    Yeah, I know, but it'll be ok!
    Lincoln Square wave 255
    Miller Vintage mig
    30a spoolgun
    Thermal Dynamics Pacmaster 100xl plasma
    Smith mc torch
    Ellis 1600 band saw
    Apr 2008
    Yuma AZ
    The outer arms on the tongue were "pie-cut" & welded solid. Then welded solid to the 3" tube of the tongue. Forgot to say, this is all 3/16" steel welded hot for full penetration. Might not hurt to plate the top of the outer arms, but I think that would be way overkill. The tubing size was my insistence, to prevent any weld/tubing breaks.
    Not shown are cross members at the 22" back/forward from the front/rear cross members. And we have 2 cross members at the rear of the welder skid. The welder is bolted to the skid, the skid is bolted through the wood deck to steel cross members.
    Son had it out & drove it around the block, said it pulled straight, easy & didn't bounce with the welder on the trailer.
    Mark
    Enco G-30B Mill
    Hobart Handler 175
    Jul 2013
    Pine City mn.
    Any time you have a weld joint like that you have to deal with the haz which can lead to stress cracks. You have 3 weld joints in a line across the highest stress area of the trailer, leaving it like that will be a poor design regardless of the thickness of material and quality of welds. Leaving it that way is of course your choice, but leaving it is a poor design suseptable to cracking, plating will make it a good and safe design.
    Jon
    Miller Vintage mig
    30a spoolgun
    Smith mc torch
    Ellis 1600 band saw
    Dec 2014
    Arizona
    Thank you for the input
    Jul 2011
    Bossier Parish La.
    Quote Originally Posted by ballingerjonathan16 View Post
    I'm wondering why you didn't use the engine drive to build the trailer it will live on. It could probably have used the run time on it, and would have been a good time to make sure it runs the way it should. Missed opportunity.
    May 2008
    Orange, TX
    Nice build Jonathan and Mark.
    I'm surprised you didn't mount the tail lights/plate on the rear face of the fenders where they would be higher and less susceptible to damage. Or do you have other plans for those areas?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2014
    Arizona
    Quote Originally Posted by Bistineau View Post
    I tested the welder previously and it works amazingly and I could have used it for this build but im a much better mig welder than i am at stick and with this being a structural build i went with what im good at and what i know
    Dec 2014
    Arizona
    this is actually the way i had designed it on autocad
    Apr 2008
    Yuma AZ
    License plate will go on the left, fire extinguishers might go next to the fenders.
    Original plan was flush LED's in the tailpan, but they would be too low for AZ law. Minimum of 15" max of 20". We are going to put flush LED's on the hoop, like a 3rd brake light.
    Mark
    Enco G-30B Mill
    Hobart Handler 175
    Sep 2011
    The Dalles, OR
    Nice design, looks great. Should be plenty strong enough for what you are doing. I look at some of the mass produced trailers out there and there is no comparison. Yours looks really nice.
    Dec 2015
    Looks like you used a drop axle, but mounted it under the springs? Any particular reason you did that, or was it just make the parts you had fit what you wanted?
    Apr 2008
    Yuma AZ
    The axle used to have the springs under, we moved the springs to the top. We wanted the trailer higher without spending money on a straight axle.
    Mark
    Enco G-30B Mill
    Hobart Handler 175
    Dec 2015
    Makes sense, making what you got do the job!
    Dec 2014
    Arizona
    Here are some pictures of the progress that has gotten done here lately
    Dec 2012
    Denison TX
    Weird, a guy posts a trailer build and no flaming. You guys go soft while i was away?
    Dec 2014
    Arizona
    Quote Originally Posted by jamesyarbrough View Post
    We must have done a pretty good job then lol
    Apr 2008
    Yuma AZ
    It's all wet today after a fine AZ shower. Going to have a great patina developing.
    Mark
    Enco G-30B Mill
    Hobart Handler 175
Page generated in 1,606,210,391.49634 seconds with 12 queries
