Results 1 to 22 of 22
Thread: Weld Copper to Stainless
    Oct 2009
    Prince George, BC
    Hi Guys,
    I need to connect a 2" copper fitting to a flat piece of stainless. I have a Syncrowave 200. I have tested fusion welding the two together but the puddles don't want to mix, as I suspected.
    I thought for sure I could just use JB Weld but that didn't stick to the stainless.
    I want the joint to be pretty strong as a tall apparatus will be sticking out of the fitting.
    Is there any way to TIG this (PS I am brand new to TIG)?
    What about silver solder?
    PS Yes, this is to connect a copper still to a mash pot!
    Aug 2007
    Re: Weld Copper to Stainless
    Silver solder is perfect for what you want to do.
    Have we all gone mad?
    Wenatchee Washington
    Good luck with your still...
    Aug 2008
    Canada with mosquitoes.
    Can be tiged with silicone bronze but not a job for a beginner tig welder.
    Mar 2007
    TX
    What about a threaded fitting of the same metal welded on to each piece and then screwed together?
    HH 187
    Miller Bluestar1E
    AHP AlphaTig 200X
    Jan 2008
    Quote Originally Posted by Greyhorse View Post
    poooosies way out...an you still gotta solder or braze the copper side...
    Sep 2006
    NJ, USA
    Braze the pieces together.
    Because short of some sort of 'solid-state' joining method (explosive welding and such), there is no real way to arc (or gas, or laser, or EB) weld two such dissimilar metals together.
    Pay attention to the brazing alloy and possible fluxes involved, as not all such may be food-safe.
    Maybe an alternative could be to weld or braze the appropriate flange-fitting halves to their similar metals and then make a bolted and gasketed flange joint between the two?
    Jun 2011
    Aiken SC area
    Yes on the silver solder. Keep most of your heat on the stainless. Bob
    Jun 2010
    Louisville, KY
    Quote Originally Posted by MoonRise View Post
    ...short of some sort of 'solid-state' joining method (explosive welding and such), there is no real way to arc (or gas, or laser, or EB) weld two such dissimilar metals together.
    I beg to differ. Not only do I believe that it can be done, I have seen it done and x-rayed.
    Mar 2006
    Oklahoma
    i have welded my copper template to a SS blade by accident
    idealarc 250/250 ac-dc tig
    idealarc 250/250 ac-dc tig #2 used for stick
    lincoln sp100
    hh125
    dual arbor grinder polisher
    30 yrs of hand tools
    52 pitch blocks 6p-26p
    rake gauge -pitch gauge
    G&D prop repair
    918-207-6938
    Hulbert,okla 74441
    Mar 2006
    Oklahoma
    doin some reading
    ( google search welding stainless to copper turn up some scrolled down found one
    " welding-copper with intense heat localized heat input "
    2/3 down article PWL# 027 Weldability for weld repair,copper to stainless
    .welding-advisers.com/PRACTIAL_WELDING_LETTER-PracticalWeldingLetterNo.27
    grrrrrrrrrrr cant get link to work
    lincoln sp100
    hh125
    G&D prop repair
    918-207-6938
    Hulbert,okla 74441
    May 2004
    Edison Wa.
    I have TIG brazed, with a silicon bronze filler rod, lots of copper, brass, and bronze to stainless. Works fine.
    Copper is a lot easier than brass, especially if it has zinc and lead in it, like CDA 360 does.
    Copper takes a lot of amps, though. You will probably need to turn your welder up all the way.
    I would start the arc on the stainless, feed in silly bronze, and wash it down onto the copper.
    Oct 2009
    Prince George, BC
    So I went to get silver solder and talked to a buddy at the LWS. He had silver solder and some Bernzomatic "metal solder" So I bought both to try the metal solder stuff. It was $8.99 vs $54 for silver solder.
    I didn't realize that silver solder requires and OA torch. I only have Oxy Propane, but he figured I could use my TIG for the heat source.
    The TIG brazing sounds cool I will see if I can get some of that silicon bronze rod. Now in brazing you should be melting both host metals, right? Then add rod as filler?
    Anyway I attached it with the "metal solder" and did a test run with water, seemed to hold up OK. I need to patch a few leaks in my copper soldering now that I have run water through it. I will test the whole thing tonight on some apricot mash I have been fermenting for a couple of weeks. AND we have peaches and plums that are alomost ripe in the garden!
    Sep 2006
    NJ, USA
    Umm, no.
    In brazing, you heat the 'parent' metals just enough to be able to have -them- melt the brazing filler.
    Just like soldering, except hotter.
    No melting the parent materials. (that's called "welding" )
    And if the low-cost Bernzomatic "metal solder" is the stuff I'm thinking of, it is a solder that is either solid wire (may be a lead-based alloy, which you really-really don't want to use for food stuff) or an acid-core lead-based solder (again, which you really-really don't want to use for food stuff). So not the right stuff for your purposes either way.
    By me, TSC has (had?) some bare phosphor-bronze brazing rods (possible also some flux-coated ones too). Lowes and HomeDepot also have (had?) similar.
    You probably do want brazing rods and not "solder" there.
    Jan 2011
    Pensacola, FL
    You're making this too hard. I used compression fittings and simple gaskets to fit up a SS part on my SS still and then a compression nut on the copper line. You could even use high temp silicone instead of gasket material.
    Oct 2009
    Prince George, BC
    I tried with a local plumbing wholesaleer for parts to do this and didn't have any luck. I guess if I researched and found the parts I wanted then just ask/order those it would work better. My whole still is copper, made of 2" copper pipe so that is what I need to connect to the SS pot. The "metal solder seems to work. It is actually around the outside of the connection too so there isn't really any interaction with the vapour going by.
    Mar 2006
    Oklahoma
    with practice it can be done ----
    will be Hot and Fast Tig set just like i weld SS ,didn"t have a big piece of copper or smaller SS
    was running about 120 amps my SS was toooo thinguess in .020 ,copper .045
    needed both the same thickness and practice practice but could be done
    sorry crappy cell pics
    lincoln sp100
    hh125
    G&D prop repair
    918-207-6938
    Hulbert,okla 74441
    Dec 2009
    Stevens Point, WI
    I'll have to give this a try. I've accidentally welded aluminum to stainless with a very brittle but ok looking weld before.
    Aug 2007
    Looks like a situation where high peak, low frequency pulse welding would be ideal.
    Something like:
    Peak 180-220A
    Background 5%
    Hz .3-.5/sec
    Mar 2006
    Oklahoma
    all the amps were needed to puddle the copper
    but when it did you better be ready to move
    the SS was to thin just sucked right up, with same thickness materials could run a nice bead
    just didnt have enough scrap copper to play with
    any one got some test coupons to play with would like to see more tests
    lincoln sp100
    hh125
    G&D prop repair
    918-207-6938
    Hulbert,okla 74441
    Sep 2011
    Woodsfield, Ohio
    Sounds like you already got it done but there is a method I will always try in those situations.
    Get both materials in a round form so it can be like a socket weld. In this case I would put the stainless as the smaller insert piece. Make the socket pretty deep, flux up the parts a ton and pour lead free solder about like lead'n up a drain line cast iron part. You should get something like a mechanical joint that is leak free. Should work as long as your application is below melting temp of solder.
    Could use lead if you did not have a booze application.
    Biggest trick is how to keep the pour from leaking, a preheat and hammered tight fit up works, inner part cold, outer hot is better yet before hammering her in. Can try the packing method used in plumbing pours too. Method does work when nothing else you try does. Or you ain't got the right equipment for something fancy.
    Jun 2010
    raleigh nc
    silly question - why do you need to weld the copper to the stainless? Why not weld a female threaded stainless part to the stainless, and then use a male threaded copper piece on the copper side.
    miller syncrowave 250
    hobart handler 140
    home made 400 amp engine driven in progress...
Page generated in 1,594,293,482.66034 seconds with 12 queries
