Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Learning to TIG
    May 2016
    Southern California
    Re: Learning to TIG
    I use a form block cut in half with a little s curve. Spin the wire slowly as you draw it through, works great for hinge pin stock, will let you know about .030 wire. Will try my setup on some safety wire and post a picture.
    Miller Multimatic 220AC
    Miller Thunderbolt 225
    Victor OA
    Jul 2016
    Midwest
    Re: Learning to TIG
    Quote Originally Posted by _Dom View Post
    Thanks Oscar, you are right of course. Just trying to limit my consumables, actual project I will be welding is thicker. This thin stuff was some repurposed material I had laying around. Thinking the MIG process for stainless will be more trouble than itís worth but I want to try it. Will have a look at thread with multiple flow meter/mixer data if it turns into a process I use often
    75/25 on stainless mig will likely disappoint. Good luck though.
    Thermal Arc 320SP ( Lorch )
    Cobra Pythons
    ESAB 301i AC/DC ( Lorch )
    Thermal Arc 161STL ( WTL )
    Thermal Arc 190S ( Sanrex )
    Victor Gas Apps.
    May 2016
    Southern California
    Re: Learning to TIG
    Yeah, LWS suggests trimix, thinking helium is the drug of choice. Not happening anytime soon, will start with 75/25 on carbon steel and work on some shopping container repairs.
    Victor OA
    May 2016
    Southern California
    Re: Learning to TIG
    Shipping container repairs will probably use the MIG gun. Here is more stainless TIG with oversized filler. You can see my straightener cut from a chunk of nylon. Pretty simple and works ok with safety wire so I will probably run what I have. Name:  549E958E-1E5C-4714-B6B4-793106FC2CC0.jpg
    Victor OA
  5. #30
    May 2016
    Southern California
    Re: Learning to TIG
    Here is the project. 1/8” alloy unknown. I am pretty happy with the autogenous top face. A little sugary on the back since not setup for purge flow. The rest was looking pretty gnarly, grinder might clean it up enough.
    Victor OA
  6. #31
    May 2016
    Southern California
    Re: Learning to TIG
    This is made of scraps from the pile so used drop from the top frame as feet for the steel stud legs. 1/8" stainless angles TIG brazed onto the 24 gauge galvanized sheetmetal.
    1/16" silicon bronze filler.
    3/32" tungsten, 2% dedicated.
    15 cfh Argon.
    Have fooled around with sil/bronze in the past with mixed results. 60 Amps seemed a good level but the 1.5/ sec pulse made a big improvement. Really like this new machine!
    Victor OA
Page generated in 1,606,457,502.79521 seconds with 12 queries
