Results 1 to 16 of 16
Thread: How do I put a half twist in a piece of thick metal
    Fredericksburg, VA
    I have an idea for a bell stand that uses pieces of 1/4-1/2" thick metal that is 12-18" wide. The legs are about 5 feet tall while the top is 3-4 feet wide. I want to put a half twist or 180 degree rotation in the metal. This pic is an example of how I think it will look.
    Name:  flat metal with a twist.jpg
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Jan 2008
    Richmond, Virginia
    Re: How do I put a half twist in a piece of thick metal
    I don't think it's going to look like the drawing when you twist it if it's a straight piece. More like a twist drill. A bow tie shape might get some of that effect.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Fredericksburg, VA
    I have seen some videos of a piece of flat bar in a picket twister that seemed to work. Scaling up from a piece of 1/8"x 2" flat bar is a lot harder to imagine the tooling or forces
    Millermatic 252 MIG
    Jan 2008
    Richmond, Virginia
    At best you might come up with something like this. Guess it depends on the width to thickness ratio and the length. Still a LOT of force required with the dimensions you want.
    SP-175 +
    Miller spot welder
    Or a lot of heat. There must be a way to roll that spiral but you would probably have to build a custom machine to do it.
    ---Meltedmetal
    Jan 2006
    In A Nice Comfy Chair
    It's going to shrink as you twist.
    But ya can't twist it anyway without some big azz machine .
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Fredericksburg, VA
    Yeah, it looks like this project will not happen with my tools
    Millermatic 252 MIG
    Mar 2012
    Find a freshly imploded building and bring a torch.
    Jan 2008
    Richmond, Virginia
    For a one-off, weld one end to a post or i-beam in the ground. Weld the other end to a big wheel rim. Bolt that rim to the axle of a big dump truck, tractor or similar. Use low gear to twist.
    SP-175 +
    Miller spot welder
    Jan 2006
    OR snap a axle.
    ...zap!
    Do not attempt.
    Big Lake/Monticello MN
    Looks interesting, if you were near me I'd say bring the steel out and we'd twist it up.
    I've got enough junk laying around to make that twist work.
    Syncro 350
    Aug 2012
    AR
    Get a rosebud and heat the center of your plate crossways about 12" wide to yellow hot. Before hand, figure out a way to secure one end, and get a couple of buddies and a 6-pak and twist the other end quickly while it's hot. Good idea to keep the rosebud on it and keep it yellow hot while twisting. How you hold the free end is up to you. Maybe stitch weld a bar to the free end for leverage when twisting then grind it off. The narrow heat area will allow for a short twist instead of it going the length of the plate. (use the 6-pak AFTER you make the twist....).
    Fredericksburg, VA
    Thanks for the offer. The twist with a truck sounds interesting but potentially dangerous. Might have to have someone hold my beer first😊
    Millermatic 252 MIG
    Jan 2014
    Hallieford, VA
    Try Kevin Caron (Sp?). He has done a lot of large twists for his art, though likely not with as acute turn as you are seeking. Probably much easier to achieve with something other than thick steel. Why thick?
    Jerry
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Northern Cal., Shasta County
    weld it up with box tubing, face it with sheet?
    Fredericksburg, VA
    Kevin does great work and I have followed him for several years.
    I was thinking about one thicker piece for the looks, but am now thinking of trying to use thinner material and boxing it in like was just mentioned.
    Millermatic 252 MIG
Page generated in 1,713,286,537.18468 seconds with 18 queries
