Page 1 of 11 123 ... LastLast
Results 1 to 25 of 257
Thread: Garage modification
    Garage modification
    Recently I bought a house with a 26'x30' detached garage. The garage is insulated and drywall sheets hung. Problem is the 2 doors, 9' wide by 7 ' high and a ceiling of just over 8' isn't suited for my uses.Name:  IMG_20160526_190205.jpg
    Jan 2008
    Lansing, MI
    Re: Garage modification
    We know what comes next
    The plan is to raise the building about 27" with 3 courses of 8" block and doubled plates between the block and the stud wall. The 3 sides will be done that way and the front will be reframed with longer studs to a plate directly on the slab. The 2 doors will be replaced with a single 9' high by 12' wide insulated door.Name:  IMG_20160526_185825.jpg
    The way I plan on raising the building is doubled up rough sawn 2" x10" pine lumber I obtained from some windblown trees. The 2x10s will be screwed to the studs about 12" off the floor after the bottom 4' high row of drywall is removed. Under the 2x10s , 8" channel iron will go across the 26' width of the building. Braces will be ran from the ceiling to the 2x10s in a few places to prevent shifting. Jacks will be placed at the area where the channel meets the 2x10s , started with a plate welded to the top of the channel so the lifting point can then go under the channel after the building is partially raised. More to follow as the progression happens.
    That's funny, being that I don't know what's next.
    sounds like a plan Mike. You sure you don't want go to 12' ??? Raise to your height , step back and take another look .
    In a perfect world I would probably start over, wider longer and taller. Preferably done for cheap by a scantily clad all female construction crew.( MN Dave probably has a pic or 10 to that effect). Hopefully all goes well, and with Menard's sale right now I will be saving one cent per block.
    Feb 2010
    TX / MN
    I have lifted a 24 x 24 and put one row of block around it. The hardest part was the first inch, after that larger pry bars and a track jack. I kept going around and dry stacking until I had enough clearance. It just takes time and beer. Be careful to brace the doors as I found out the one front wall had no nails attaching it to the side wall. Good Luck!
    Nov 2010
    VA
    My shop has 9' doors, was that way when I bought the property. If they were 12', I could get my yard lift inside with a load on the forks and could also get most trucks in. My International's headboard clears the door openings by about 3/4" - can't get dump trucks or a standard service truck with crane mounted to the boxes into the shop as it sits.
    Good luck on the project; I've never been any good with wood and will be trying to learn something here.
    Applied Fabrications, LLC
    Mobile Welding / Mechanical Repair in VA's Piedmont & Shenandoah Valley
    I don't do a lot with wood anymore, pretty much just rough work. Probably 15 years since I laid any block, fortunately there will only be around 200 block . After looking things over, I found that the building is anchored with powder actuated nails, which can be a pita to deal with. The framework of the building should be pretty sturdy being it has 1/2" OSB for sheating. The biggest cost should be the door, quote was 900$ and change for a 9' x12' insulated door, installed.
    Jan 2008
    Lansing, MI
    I'll send you encouraging texts...
    You're much braver Thani. If I tried to do anything to this heap of crap I call a garage, it would probably fall over
    Jan 2008
    Lansing, MI
    Mr. Patience doesn't do wood lol.
    Mr. Patience can do wood, but certainly not a Bob Villa level. But for the record Mr. Patience would have bytch slapped Villa repeatedly for being an annoying schmuck.
    Jan 2008
    Lansing, MI
    Mr Rig would have grabbed a guitar and gave him forty whacks for good measure
    Mr Rig does wood.. With a circular saw or chain saw. If he can't screw or nail it together he don't do it..
    Sebeka and Bemidji MN
    Damn man, you were talking about cutting the nails this morning - saw this thread and figured it was all lifted and blocked for laying courses in the morning.
    You're slacking off and going to your regular job instead of working on the shop
    Airco 300 - Syncro 350
    Funny how that works. It will be nice to actually have some time to work on this over the weekend. Hopefully it goes smooth, and I can find all of the fasteners that are holding it in place.
    I'm sure it'll go smoothly - but if it doesn't, just use more power - that'll fix it
    Sep 2011
    Jasper TX
    Just a walk in the park...
    Feb 2008
    North of Philly
    Where did you get the quote on the door and what model? I'm thinking a 10'x12' door for the new "shed" later this year.
    I never was a big block fan. I'd jack it all up and pour the walls myself. 8" or wider and you'd have enough room to shoot in the crete if you are careful or pump it. I was just talking to the guy who owns the farm where we do 4-H Wednesday night. He's got an old barn the lower block wall is bowing in due to soil on the outside. He asked if I did block or knew a mason. I told him it's a shame we got rid of all the concrete wall forms last year. I'd have easily poured him a nice 10-12" wall about 4' hight to get him above grade, then framed the rest for infill.
    Ronald Reagan
    This quote was from a local dude who installs a lot of commercial doors. I found prices all over the board, so check around.Menard's was more for the door, uninstalled than this guy. The bonus is that he gave me a fair price for the old doors and openers. As for the block, if this was a bigger building and I had access to forms, poured would be the way to go.
    Mar 2016
    My dream is to have my shop re-wired by a real electrician.
    It's hard to weld when you can't see.
    Dec 2009
    Stevens Point, WI
    Exciting stuff! Let me know if you need any help. I can bring the antique skidsteer by as well if needed.
    Really at the point of lifting the garage adding in another stack or two of blocks for that extra foot might make you happy in the future. Plus with the $0.01 savings at Menards right now you'll be making out like a bandit!
    You're doing better than me... my plan A was to remove the flat roof that I didn't like off of a pig barn and extend the 8' walls up to 14'. When I got into it, Plan B ended up blowing everything off to floor level and starting from scratch. That was 3 yrs ago and I'm still working on it.
    Quote Originally Posted by VPT View Post
    Going higher may happen, a 10' tall door was 100$ more than a 9' door. I would need 5 courses to fit in the 10' door without messing with trusses. Thanks for the offer. I could use a load of masonry sand if you have a dump trailer or small dump truck.
    Do it if you can... you won't regret it. My 12ft door isn't high enough...
Page generated in 1,606,468,004.35801 seconds with 12 queries
