Results 1 to 3 of 3
Thread: quick auger fix improvement...
    Jan 2016
    northeast USA
    Using the auger with the 2 separate teeth always caused an issue with clumps of grass getting caught between them as they spread apart, and in time the auger wouldntName:  weld 001.jpg
Size:  56.9 KBName:  weld 002.jpg
Size:  66.9 KBName:  weld 003.jpg
Size:  63.7 KBName:  weld 004.jpg
Size:  69.0 KBName:  weld 006.jpg
Size:  60.8 KB drill into the ground from all the build up, so a little weld should be the fix, and the teeth will still unbolt if they need replacing..
    Jan 2016
    northeast USA
    Re: quick auger fix improvement...
    and the weld,7018 at about 140 amps, time stamp on pics is wrong..Name:  weld 007.jpg
Size:  62.7 KBName:  weld 008.jpg
    Yeah,
    It kind of makes you wonder why it was a two-piece in the first place.
    Years ago, I used to do a lot of augers and drag-chain stuff for grain conveyor systems, and I'd often double-flight the ends to renew and improve the pickup.
Size:  54.9 KBName:  IMAGE008.jpg
Page generated in 1,713,293,058.00491 seconds with 20 queries
