Results 1 to 9 of 9
Thread: 54' ShortHood welds Perfectly, but wont run a grinder...even when idled up???
    Jun 2016
    Anyone have any clue why this is happening? from everything that I have read, it seems like if its welding it should be running a grinder. thanks in advance for any input. I can get the outlet to run a small light when its running, but no grinder. Also the only way I can get it to idle down is if I open the vacuum valve slightly, and it will idle back up when I strike an arc. is this normal? or did I mess up and adjustment on the carb when I was doing the rebuild. It has the marvel carb. Thank you
    May 2008
    Orange, TX
    Re: 54' ShortHood welds Perfectly, but wont run a grinder...even when idled up???
    What grinder?
    Is it rated for operation on DC?
    Bad receptacle that loses contact under load?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2008
    Orange, TX
    Quote Originally Posted by 54_shorthood_pipe View Post
    That's how it's supposed to work.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jun 2016
    its says AC on the grinder duaneb55, does that mean it wont even turn the grinder unless its ac/dc? or only straight DC?
    Jun 2016
    its a dewalt grinder. and I believe the receptacle is in working order.
    May 2008
    Orange, TX
    As the welders' auxiliary power is DC, any motor device has to be rated for operation off AC/DC or DC only power sources.
    Usually any brush type motor qualifies but definitely no variable speed units.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jun 2016
    Thanks man, I'll try a different grinder
    May 2011
    Andover, Ohio
    Welcome...
    Lincoln A/C 225
    Everlast P/A 200
    Jun 2016
    Thanks M J Mauer. Bought this Short Hood and love it. Welds better than a new Miller lol. Still working out the small bug though.
Page generated in 1,607,058,042.94230 seconds with 11 queries
