Results 1 to 15 of 15
Thread: 5 Gallon oil bucket cart ideas needed
    May 2013
    South of Dallas
    I buy my motor oil in 5 gallon buckets, and I would like some cart ideas to make dispensing it easy. Im using a hand pump to pump it in to 1 gallon buckets now
    Mar 2016
    North Georgia
    Re: 5 Gallon oil bucket cart ideas needed
    They make oil bucket carts cheaper than you can buy the casters.
    May 2013
    South of Dallas
    Im looking for a cart that would help in dispensing the oil, not just moving it around
    Sep 2015
    SE Pa
    Do you want to keep the oil in the bucket or make a dispenser?
    May 2013
    South of Dallas
    I think Id like to keep it in the bucket and use it as a dispenser, But Im open to suggestions as to what others have made
    Mar 2009
    Just one grade / weight of oil or will there be multiple types?
    Sep 2015
    SE Pa
    You could make rollers to set the bucket on its side on horizontally,with the spout at 12 o'clock take off cap.When you rotate the bucket slowly the oil come out in a steady stream.As you use the oil you just rotate the bucket more .When done put spout at 12 o'clock,put cap on
    May 2013
    South of Dallas
    I use 15w40, and buy it in 5 gallon buckets.
    I was thinking about some thing like you suggest. I though I would see what others are using
    They make lever handle pumps that replace the lid on 5 gallon containers. It is fairly easy to use, especially for motor oil. I use one to pump 85-140 gear oil, and it works good. Pretty reasonable price as well. Many lube and oil distributors sell them.
    Apr 2012
    Flat lands of Colorado, where the wind blows
    I bought a pump for a one gallon/5 quart oil jug, and it has a clear plastic hose on and use it to put oil in the small engines, (one of the better things I have ever done)
    putting a hose on the pump of the 5 gallon bucket and then just pump it into where you need it, with the bucket on the ground or dolly a 1/4 tun valve at the near end of the hose would keep hose spillage down, measure the number pumps for a quart and mark the pump or drum and when changing oil pump the need pumps and you should be there, (your hose could be 10 feet long if needed) with a 1/4 tun valve at the out put end and short spout, you should be good to go,
    Dec 2009
    Randle WA
    http://cdn.morsedrum.com/ops/PL15_DIM.pdf
    Bucket tipper with dimensions
    Millermatic 200
    Hobart Handler 120
    Victor O/A & Ramco Bandsaw
    Lincoln 225 AC
    SnapOn AD Hood
    Miller XMT304/22A
    Hypertherm Powermax 1650 G3
    Lincoln Idealarc DC600 w/Extreme 12 VS
    Miller Digital Elite "Joker"
    Upstate NY
    They make pumps for 5 gal buckets that replace the lid.
    I've got one on the gear oil bucket and another on the hydro-trans.
    Yes, I have to carry (use the factory handle) the bucket to where it is needed. Then pump the fluid up.
    Here's one on Amazon: https://www.amazon.com/Powerbuilt-64...+gallon+bucket
    Welders:
    2008 Lincoln 140 GMAW&FCAW
    2012 HF 165 'toy' GTAW&SMAW
    1970's Cobbled together O/A
    Nov 2012
    Gimli Manitoba
    The bucket tipper works good. The one raptorduner showed. We had something similar on one of the ships I work on for boiler chemical. Easy to pour from.
    Sent from my SM-G903W using Tapatalk
    Miller 180SD
    Lincoln weld pak 180
    Hobart 250ci
    Mill
    Lathe
    May 2013
    South of Dallas
    I think Ill make a cart of some kind about waist height and use the lid style pump
    Just use a hand truck, put an empty 5 gal. bucket on the bottom and the full one on top with the spout facing towards the handle, you will be able to tip it and pour it with a controlled dose.
Page generated in 1,606,280,721.36992 seconds with 11 queries
