Results 1 to 11 of 11
Thread: Plasma cutter laying on its' side, OK?????
    Jan 2013
    I'm looking for a bit more room in the garage. Is there any reason why I can't lay my plasma cutter on it's side and use it in that position???
    Thanks,
    Pete
    Everlast i210 with 200a spool gun
    Everlast i140e
    LOTOS LTP5000D Non-Touch Pilot Arc
    "Things are never so bad that they can't get worse...."
    Sep 2005
    Cave Creek AZ
    Re: Plasma cutter laying on its' side, OK?????
    Likely not a good idea, the plasma might pool on one side!
    Only thing That might be a problem is cooling air intake/ exhaust, mine is on the side, also the water trap would be useless on the side, so it probably is not a good idea.
    Oct 2007
    New Hampshire, North Carolina
    With the Hypertherm systems (and probably others) there is a water trap with an auto drain that probably will not operate as designed. Jim Colt Hypertherm
    Can't you make a free standing jib crane setup ? Doesn't weigh much and just swing to location when needed. Maybe setup a trolley setup on some unistrut .
    Jan 2016
    northeast USA
    Quote Originally Posted by fps View Post
    Thanks,
    Pete
    how much more room could you possible gain by turning the unit on its side? and as said above..probably not a good idea...
    Jan 2013
    Hi Jim,
    Since this is a Hypertherm 30, I won't be laying it down. Thanks. FWIW, now that I'm retired () I've been trying to setup the garage up as my welding man cave. I have separate heat, A/C and 50a 220v power.
    Thanks,
    Pete
    Everlast i140e
    Feb 2010
    Northern MN
    Many of them have a water trap in them (as Jim said) I'd just make a nifty little rack that put the thing above or below your favorite welding machine.
    May 2015
    This is what I was trying to find out. The Hypertherm 30 has dimensions of like 7" X 16" or something like that.
    Mar 2009
    I have a feeling it was a conversation with his wife that went something like this:
    Him: My shop is too small I need to add on 1200 sq/ft
    Her: Can't you just lay your plasma cutter on its side?
    Him: Yes, but I will only gain 15.666689 square inches
    Her: That much? Let's try that first.
    Jan 2013
    Quote Originally Posted by Pipeliner View Post
    Damn...........You got me.......BUT, the only way you could possibly know something like that is.................Your Married, too
    Everlast i140e
    Mar 2009
    That's a big 10-4.
Page generated in 1,713,288,157.08082 seconds with 17 queries
