Results 26 to 37 of 37
Thread: Making a dome end on pipe
    Re: Making a dome end on pipe
    Dave, your diagram worked pretty well....welded it up with some 3/32" 7014
    Making a yard art cactus.....
    That looks great.
    If you were making multiple pieces, you could make a round mandrel (?) the same size as the ID as the pipe... weld it to a long rod and slide it up inside the heated pipe.... then tap it into shape.
    Aug 2012
    AR
    Quote Originally Posted by ManoKai View Post
    Remember to use the OD dim for the math matrix.
    I've seen that video...good one.
    Aug 2012
    AR
    That looks great.
    I started to do that with a piece of sucker rod I have. The largest OD of the pin end is a slip fit into the pipe ID, but the threaded end was a bit smaller than I needed. I looked all over my scrap pile and didn't find anything that would fit. Might try to grind down an old trailer hitch ball or axle and weld it to a long rod.
    You are right, a mandrel would make for a speedy and consistent job!
    Nov 2010
    Texas
    That turned out great!
    Aug 2012
    AR
    No one was more surprised than me that it worked!!!!!!
    Oct 2016
    Raleigh, NC
    If the first drawing is to scale. Could you not change it's scale so that it's length is the same circumference of the pipe?
    Then print, and trace, and cut?
    Oct 2016
    that is a sweet job!
  8. #33
    Aug 2012
    AR
    Quote Originally Posted by Kolas View Post
    If you need to change the scale, just wrap a blank template around the pipe or measure it with a tape measure. Lay it out, divide by the number of segments you want and go from there. Really simple. I think there is a youtube video by Hobart showing how to make the template...search youtube for orange peel and look for the Hobart video.
  9. #34
    Big Lake/Monticello MN
    The drawing was not to scale since it will change with each different size pipe.
    The pipe size and number of petals are what dictate the size of everything on the drawing.
  10. #35
    These are heated and hammered domes. It takes about five minutes each, and you just need to fill a quarter inch hole at the top.
    I would have thought this method silly if someone just told me about it, in fact when the fellow who taught me, told me, I thought "oh my God this is going to suck". But in less than five minutes I was quenching a pipe he handed me with a dome that had a quarter inch hole in the top of it. He still has me beat for speed and sometimes I end up with a three eighths inch hole in the top of the dome, but I have improved to about five or six minutes.
    You just keep rolling the pipe and hammering it medium lightly. It just turns into a dome. I have thought I messed them up a couple times, and just kept going to see what it would look like. To my surprise I was able to reshape it using different hammering angles.
    Sincerely,
    William McCormick
  11. #36
    These are heated and hammered domes. .
    Sincerely,
    William McCormick
    Cool.
    I'd like to see an action shot of those being made.
  12. #37
    Cool.
    Next job I get I will do that, it was much easier than I thought.
    Sincerely,
    William McCormick
Page generated in 1,713,283,519.17298 seconds with 20 queries
