Page 4 of 4 FirstFirst ... 234
Results 76 to 80 of 80
Thread: Various attempts to join cast iron to mild steel plate
  1. #76
    Feb 2014
    Iowa
    Re: Various attempts to join cast iron to mild steel plate
    I'll echo ManoKai, good job, and thank you for taking the time to test & analyze different procedures/materials, and posting pics of your results.
    Miller Dynasty 350
    Miller CP300
    Miller CP200
    Lincoln Idealarc 250/250
    Smith torch
    Lagun FTV-2
    Kent 13x40 TRL lathe
    Bunch of other metal cutting tools
  2. #77
    Aug 2015
    I fixed a fireplace that was made out of cast iron. It had 3 legs that were bolted on. One of the bolts broke off from rust and couldn't be replaced. So I cleaned both sides of the legs and MIG brazed it with silicon bronze wire. So far it's been ok but we are careful not to bump it around. MIG brazing is fast and ductile. No cracking issues.
    Name:  fire pit 1.jpg
  3. #78
    Jan 2011
    This should have had some 4x4 x1/2 flat stock welded to the bottom plate at each leg position.Now put the welder away.Drill and tap each square and bolt the legs on to the plate.Those legs are cast iron from a stove.The are some jobs that shouldnt be welded.My wood stove has square tubing legs welded to the bottom plate.This would have worked on the barrel stand.
  4. #79
    Fredericksburg, VA
    Someone had asked me where I got the Nickel 55 rods so here are some links.
    Blue Demon ERNI55 1/16" TIG rods are $45 for one pound
    https://www.amazon.com/Blue-Demon-ER.../dp/B00I4WXZNK
    Blue Demon ERNI99 3/32" TIG rods are $48 for one pound
    https://www.amazon.com/Blue-Demon-ER.../dp/B00I4BXP5Y
    The 309 MIG wire I used or the equivalent 2lb roll for $20
    https://www.amazon.com/WeldingCity-E.../dp/B007JCQTFW
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  5. #80
    Quote Originally Posted by 69sa200 View Post
    Gorgeous brazing!
Page generated in 1,713,304,538.76034 seconds with 18 queries
