Results 26 to 50 of 80
Thread: Recommend me a good drill bit set for metal
    Apr 2016
    CA
    Re: Recommend me a good drill bit set for metal
    Do any of ya'll use the stepped hole cutting drills and if so what brands do you use?
    Oct 2013
    Long Island, NY
    I usually dont use them, much rather use a real drill or annular cutter but the cost difference of the harbor freight units vs name brands is insane. I can't justify buying anything else being they can't be sharpened and I can throw out 5 harbor freight ones for 1 name brand.
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
    I use them a fair amount. 1/8" and less. The Irwin used to be pretty good, Lennox seem ok, klein are really good. Going to try a viking brand, should be here tommorow, if so I will post how it performs. They also work well for debburring holes and round tube.
    Apr 2016
    CA
    Oh yeah I had not even thought about using them to debur tube and pipe.
  5. #30
    Feb 2010
    TX / MN
    I bought a few sets of step drills at HF (drillmaster) a few years ago. They out perform the greenlees I use at work.
  6. #31
    Apr 2016
    CA
    Quote Originally Posted by arcflash View Post
    Seriously I figured they would be junk.
    I am still waiting to hear how the vikings worked for M J D
  7. #32
    Mar 2017
    Qatar
    The stepped drills from Ruko are very good, but they are not cheap, best prices I have seen are on amazon.de. Irwins are also good.
    Miller Dynasty 280 DX TIGRunner
    Fronius Transsteel 2200
  8. #33
    I received the 1/2" step bit today. I tried it out on some 14 gauge with some cutting oil and it drilled really well. Not quite as fast as a good 1/8" bit for the pierce on the first step, but overall pretty good. After piercing it drilled smooth and fast thru all the steps. Overall, better than any others I have used. I would recommend them over other brands.
  9. #34
    Jun 2017
    AJO, ARIZONA
    Quote Originally Posted by Advan View Post
    I'm not here to recommend any particular set of bits, but to advise you to stay away from the hype of all the crazy alloy and coating marketing BS.... I usually recommend nothing more than good bright HSS bits, but do agree a cobalt alloy bit is nice, if from a quality manufacturer. Forget coatings, they're worth nothing unless you're in the business of repetitive high-speed drilling like in some sort of production environment.
    Sorry, but you don't know what you're talking about, those coating are anti wear coatings and aid in keeping the bit running cooler among other things.
    NRA LIFE MEMBER
    MIDSTATES 300 AMP AC MACHINE
    GOD BLESS AMERICA!
    RONALD REAGAN
  10. #35
    Apr 2017
    Long Island, NY
    For the record: DRILL HOG, despite their two American flags on their logo, are made in China. Deceptive advertising at best IMHO!
    Lincoln Invertec V205-T Tig/stick
    Miller Coolmate 1.3 Coolant System
    Millermatic 211 Mig Welder
    Speedglas Adflo PAPR 9100 FX-Air
    CertiFlat FB2430 fabBlock U-Weld Kit Welding Table
    FW3012 CertiFlat fabWing 30" X 12" Extension Table
  11. #36
    Oct 2012
    Sacramento, California
    The 12 step is what I use most at work. Shop buys them, I've tried Lennox, Milwaukee, Irwin and harbor freight.
    Doesn't matter which brand, the 11/16 step rounds over and is a bear to get past
    Don't know why, it's done it on every one I've tried.
  12. #37
    I've got a few of the TEMO brand carbide steps and so far they are pretty dern good haven't broke one yet but i tend to be a little careful with drills in general... although anything below a 1/16th in a hand drill is just asking for it
    https://www.ebay.com/sch/golden_coulee/m.html?_nkw=step
  13. #38
    Jan 2013
    Chapin, SC
    Back to twist drills. You might want to look at Cle-Line drill bits. They are usually 135 degree split points and work extremely well on metal. Bonus: They are made in Seneca, SC. Bonus 2: They are not especially expensive.
    Available at the usual places including Home Depot.
  14. #39
    Aug 2004
    North Central Indiana
    I buy Champion products when accuracy and durability matter. I should mention I don't own any of their step drills http://www.championcuttingtool.com/a...ep-drills.html
    And use a cutting paste when your drilling horizontal and overhead holes, it really does make a difference.
  15. #40
    Apr 2016
    CA
    Thank you Fnord5 for that tidbit of info. Taking notes.
    ronsii I'll have a look at those as well.
    Henry TY for bringing the two flags not made in good ol USA Hog wash Crap-O-La to our attention ...
  16. #41
    Jun 2008
    New Plymouth ID
    I bought the drill hog m 7 off of ebay they are way to brittle I chipped the 3/8s in the mill. And snapped off several of them hand drilling, absolute garbage was going to warrentee them but all i will get is more crap that chip when they break through or snap off deep. Ihad a set of irwin max i really liked got dozens of holes out of each one. Replaeced them with another set just like them. they had changed the heat treatment and would snap off if you breathed to hard on them. All my hand drilling is done with a milwaukee hole shooter without the second handle. I have twisted the shanks on the harbor freight silver demming sets. nothing quite like untwisting your drill bit.
  17. #42
    I don't think I've broken a single bit in the drill press since I slowed it down to 80 rpm. I do leave a little slack in the belts so they slip when it jambs. Hand helds of course are a different story...
    Feb 2014
    n.w. of chicago
    On the steel corrigated decks I've drilled thousands of holes with these for bang it's inserts all different brands usually Lenox but that's just what the supply house sent, they make sense in alot situations, most pressure and heat is on a initial hole after that it works like a annular cutter
  19. #44
    Arizona
    Being an electrician I use them a lot. Used Greenlee for a while, right now we are using the Dottie ones with the replaceable tips (the tip is what dulls first) and they are holding up pretty well, just have to watch that tip when drilling a live enclosure as the tip like to drop off when it comes through. Seldom need to go bigger than 1/2" as at that point we insert the punch to finish the hole for whatever size pipe we are fitting. When the tips go dull you can just start with a regular twist bit but sometimes for drilling into live enclosures that is kind of dangerous.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
  20. #45
    Interesting... I didn't know they made them with a replaceable tip. I am currently looking at one that goes out to 1 3/8 and would like one that goes to 1.5" if they make them...
    Apr 2016
    CA
    Replacable tips is kind of cool. Ever break a tip off leaving the threads below the surface in the hole?
  22. #47
    Southern California
    X2 for CLE-LINE, available at home depot and lowes, made in USA, good metal, sharp, competitive pricing to norseman. I've had good luck with Milwaukee shockwave drill bits as well, but for pete's sake don't use an impact for metal drilling! I'm also a fan of the harbor freight step bits, they last decently and one cannot go wrong for price per cut. Use cutting fluid and go slow! Learn how to sharpen twist drill bits by hand (not that hard, 30 mins to competence, draw reference angle line on tool rest with sharpie), and learn to read the chip for pressure. Remember a hot chip (within reason) is taking the heat from the cut, when i use the step bit in thicker material the chips burn my arms if not protected. P.S. I bought drill hog m42 bits and they aren't the worst, though far from the best - sharpen extremely well but tend to chip on the corners, they're better than most in the drill press and about average in a hand drill due to chipping.
  23. #48
    Aug 2008
    Toronto ,Canada
    I bought a set of Viking mechanical drill bits made by Norseman and the have performed beyond expectation, I highly recommend them:
    https://www.amazon.com/Viking-Norsem...et+%2829+Piece
    Ken from ontario,Canada.
  24. #49
    https://www.wttool.com/index/page/pr..._shopping=true
    Forgot who makes them, but very good bits. Actually ground properly. Handy to have all the sizes, especially if you do a lot of tapping.
  25. #50
    Mar 2014
    I have a funny HF story: when south, visiting grandpa in Santa Rosa, I stopped by the local HF store and needing some extra weight in my baggage to replace that of the canned salmon just dispensed, I could not help but buy an on sale 29 pc. super-duper drill set (tiN coated, of course) for $19! They MIGHT be useful as a nail, in something like balsa or perhaps used to remove hardened ear wax. Of course I knew better! Of course I couldn't help myself! I'm pretty good at sharpening drill bits but alas, they are still nails with a twist. Sure looked good, though...
    I've had a 29 pc. set of Hanson's HSS (now Irwin) for longer than I can remember. Most of the wear is dingle-berries on the shank. Though it is true that most of my work is with AL, still, they will pass on ready-teddy after I croak.
    SO...here's my offer to the OP's query, and cobalt to boot:
    https://www.amazon.com/Irwin-Tools-3...+drill+bit+set
Page generated in 1,603,835,054.88940 seconds with 12 queries
