Results 1 to 19 of 19
Thread: Strange distributor
    Apr 2014
    South east new mexico
    Question Strange distributor
    Has anyone ever seen a distributor like this?? I found it while looking on Craigslist I have not seen it in person. I would like to find out more about it but I don't know where to start! Does anyone have any ideas??
    Jul 2014
    Bulldog Heaven at the end of my chain
    Re: Strange distributor
    Seen that mounting arrangement on several Continental and some Hercules Motors engines. They are hard on the bushings supporting the operating shaft as the entire rotating weight bears upon small support bearings/bushings.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    May 2008
    Orange, TX
    IH (International Harvester) used that type arrangement on a number of their engines.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2011
    A lot of those engines dated back to when they had a magneto instead of a distributor. They updated to point/condenser and coil system and got rid of the impulse fairbanks/morse/ wilco magneto that actually would run without a battery. Some of those engines were hand started either with a crank or turning the side mounted flywheel to get the motor started not having a starter and battery/generator system.
    May 2016
    Spokane, WA
    Must be an old tractor engine, because all of mine had them pointing up.
    RGL Motorsports LLC
    Mount Tabor VT
    It isn't a distributor, or at least it's magneto driven. A permanent magnet produces the voltage to spark. Function is much like battery ignition, but no battery is need to make it run. Most other manufacturers I don't know a lot about. IH used them on earlier letter series tractors. I have some with, some without. Magneto tractors seem to start more reliably in cold.
    Willie
    Jul 2014
    Quote Originally Posted by Gustav129 View Post
    Red Diamond? What size? I have a 450 in my 65 IH crane truck.
    Slob
    May 2016
    Spokane, WA
    The ones I had were a Blue Diamond 240. My 54 and 55 R-132's had them. I just grabbed a pic off Binder Planet to illistrate. I had a BG241 in my 66 1000A. Every other IH I've owned was 266, 304, or 345.
    RGL Motorsports LLC
    If that manifold in the OP says Red Seal, I think that would be a Continental industrial motor.
    Jul 2014
    I see. I had a blue diamond in my 56 S-160, and a 266V8 in an 66 R series pickup. Used to stomp on stock 350 Chevy's with that one. Had a scout w/304, and a Loadstar 1700 w/345 so vaguely familiar w/IH engines.....
    Slob
    Oct 2011
    Elkhorn, WI
    Not uncommon of an upgrade on engines that have good reputations and the manufacturer keeps them around forever. A magneto has advantage over a battery system in that a battery voltage is lowered from cold weather cranking. A magneto trips over at the same 6k to 8k volts every time!
    Southern Illinois
    Hey Slob, didn't IH make a RD501 as the biggest of that series? Seems like it came with 3+3 split exhaust. My wife's uncle had an old R190 winch truck that had the RD450
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
    Nov 2012
    ROCKVILLE ,,VA
    my old farmalll cub had this style y-69 continental, thing away started never had any problem,,, also have Airco HORNET 300,with f-162 Continental it has Fairbanks mag instead of x4b16a mag it has x4b 16 v with" V" means inverted installed
    Jul 2014
    Quote Originally Posted by Sparkie View Post
    Yes, they produced an RD-370, RD-406, RD-450, and RD-501 of the "Red Diamond" Sizes. A lot of the RD-501 engines had four barrel carburetors where the smaller variants had 856FFG Holley 2 barrel carbs. I have a RD-450 in my 65 R-190 crane truck which runs very well. Most of the RD-450, and RD-501 engine trucks had the split exhaust manifolds but some, (as mine) have the single 3.5" exhaust manifold.
    Slob
    Southern Illinois
    The one I messed with had single exhaust and the huge 2 barrel Holly
    Steve
    2015 Lincoln MP210
    Jul 2014
    Great engines and very powerful for their sizes. Mine still runs very well but parts are difficult to source new or rebuilt except through specialty suppliers.
    The RD-450 would have a 885FFG Holley carburetor. Big sucker for sure.
    Slob
    May 2008
    Orange, TX
    The '55 IHC Farmall 100 I used to have has a distributor arrangement just like that shown in the OP's photo of the Lincoln. My grandfather's Cub did too.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2008
    Orange, TX
    Willie
    If you're referring to the engine in the OP's photo, it's definitely a battery powered points distributor and not a mag.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Mount Tabor VT
    You are correct, but you knew that. Looking at the wiring, it is obvious. I'm familiar with IH tractor, and power units from the forties, and fifties. I believe otherwise identical engines might have either battery powered, or magneto powered ignition. The near vertical units are driven from the oil pump. The horizontal shaft variety are driven from timing gears, or chain as the engine might have. I have a Farmall Cub '50? that has always been hard starting with battery ignition. It would only start by hand cranking. Compression was low, but I believe the electric starter consumed needed battery power leaving not enough to fire the plugs. A friend has an earlier one with magneto, better compression. It starts easily.
    My engine is newly rebuilt, but hasn't been reunited with the tractor. Maybe this winter.
    Thanks for the correction.
    Willie
Page generated in 1,713,254,421.57839 seconds with 18 queries
