Results 1 to 13 of 13
Thread: Different way to find year of SA-200?
    Nov 2015
    I have an sa 200 that the faceplate that was on it had serial number of what I have learned to be a 1973. I'm thinking it is older than that. Was wondering if there was any other way to determine year. The reasons I believe is older is the on/off switch, choke, and start button are all on back beside battery. And I have to push bar and stick pin in for it to remain on high idle. Any help would be greatly appreciated.
    May 2008
    Orange, TX
    Re: Different way to find year of day 200?
    Sounds right. Take the unit Code# off the face plate and download the manual to compare.
    http://www.lincolnelectric.com/en-us...r-manuals.aspx
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Nov 2015
    Here are some pictures i have of it I don't know if that helps any
    Nov 2015
    I have printed off manual. I was wondering if there was any place on frame,engine, etc that the serial number would be stamped. Seems hard for to believe the only place for a serial number is on the face place that to me is an interchangeable part and frequently done by what I've seen. I have been told it could be anywhere from a 66-70. And I don't know if it's a red face or black face. Is there I can confirm that too?
    May 2008
    Orange, TX
    Re: Different way to find year of SA-200?
    Yep. That's correct. Unfortunately the only place Lincoln put the unit SN was on the face plate.
    Some older (Short Hood) units had the SN stamped in the generator housing but not the later units. However, you should find the Code# stamped in the housing near the main and exciter housing split line on the left side (facing control panel) approximately in line with the 10 o'clock exciter housing bolt.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jun 2013
    What makes you think its older than 73? 73 was a major transition year for the sa200. During that year the cable lugs went around to the side, the electronic idler showed up, Face plate changed to green light style. Around this time too came the hex barrel. Cant tell for sure from your pics but if it is a hex then for sure its 72 0r 73. I don't think there were any hex barrells prior to 72 but i could be wrong about that. The faceplate you have was used after the redface from about 1970 or 71 till the green light, three or four years later. Yours could very well be an early 1973 model.
    piece of soapstone
    tape measure
    chipping hammer (wire handle type)
    tip cleaners
    Nov 2015
    Quote Originally Posted by Blackslacks View Post
    The faceplate in the picture is new one I put on it. But everybody I have talked to have seemed to think it's 66-70. I found plate on side of engine with code and number. Is there a way I can look those numbers anywhere?
    Sent from my iPad using Tapatalk Pro
    Mar 2009
    What about the code # like in Duane's picture?
    Nov 2015
    Quote Originally Posted by Pipeliner View Post
    It's stamped 7214. Was wondering the first year they put choke and push button on fromt
    Mar 2009
    Code 7214 was used in 1972 and 1973.
    My undereducated guess is they were using up the earlier chassis before the full on greenlight chassis were in full production. (output studs on front panel vs side, no notch vs notch for radiator cap, R57 vacuum idler vs electronic plunger type, and start/stop/choke controls on battery end) I've seen quite a few like this out there. Even a couple of low mount starters on octagon barrel gennys.
    Oct 2013
    cntrl FL
    Here is a 1973 code 7214 machine just like yours.
    SA 200s : 1944 1945 1963 1965 1969 1980
    1981 SA 250 D3.152 DC only
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart GPB 258 Pipeliner
    Hobart GPB 261 Mainliner
    Hobart Airforce 250
    Everlast PA 200st
    Oct 2013
    cntrl FL
    here's a few more with the starter side
    2004 Ranger 10,000
    Lincoln Pro Mig 135
    Miller Load Bank
    Hobart Airforce 250
    Everlast PA 200st
    Nov 2015
    Good enough for me. Thanks for all the help. Its greatly appreciated
Page generated in 1,606,991,979.44641 seconds with 12 queries
