Yes if you use a tie that would be fine I guess
Not sure if that is code anymore
I'll stick with a dedicated two pole breaker
Syncro 350
Hypertherm PM 45
1961 Lincoln Idealarc 250
HTP 221
Also if I was putting in a 220 outlet
I would have made it a 50 amp
Hypertherm PM 45
HTP 221
Hypertherm PM 45
HTP 221
Syncro 350
MM211 (Sold)
Klutch 120v Plasma cutter
MM211 (Sold)
Hypertherm PM 45
HTP 221
Also I think Dave was right
Looks like the only thing that separates a single pole from a 2 pole is the tie...
Hypertherm PM 45
HTP 221
Some are made as two pole and have one handle, some are two separate breakers with a tying mechanism between the operating levers. Don't run them as separated handles. If they are separate handles, at the very least get the proper connecting bar. Sometimes it was just a roll pin that went into the hole on the handles. You want them to both operate together. I DON'T know if that is still code, been too long. btw. Square D QO are the standard if you have the choice.
A red Buzz Box, a Hobart MigMan, Cricket XL, Spectrum 300, and a Syncrowave 250.
x - 330ST Aircrafter, 130XP
