Results 1 to 14 of 14
Thread: How do you set amperage on SA200
    Dec 2016
    I am trying to figure how I can set a specific amperage on my sa200. It has ranges for example 80-130 but the fine dial goes to 100 so for example how would I set 125 amps? I have looked at some other threads but have not found my answer. Thanks
    May 2010
    Port Orchard, WA.
    Re: How do you set amperage on SA200
    I use the face plate on SA-200s only as a reference. I find the spot that works best for a particular type and size rod, and mark the face plate with soap stone.
    All my SA-200s have remotes so I mark them.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Sebeka and Bemidji MN
    Quote Originally Posted by Nathan114312 View Post
    130-80=50 amp range.
    Each 10 on your fine would be 5 amps.
    Set to 90 on the fine dial for 125 amps.
    And like CEP said, adjust from there to taste.
    Airco 300 - Syncro 350
    Mar 2009
    Plus or minus a frog hair
    Feb 2009
    Central Illinois
    This is a good question. I havn't run my red face enough to get to know it. I do understand any amperage can be had at two different settings.
    Which setting gives the better preformance. A low fine current adjustment or a high fine current adjustmet or are they the really the same.
    I know, I need more hood time with the machine. Owning one is just an itch I had to scratch.
    Thanks
    Dan D.
    Manipulator Of Metal
    Quote Originally Posted by DanD78 View Post
    Thanks
    Dan D.
    Lower range, higher fine will give you more arc voltage and makes 7018 very nice to run. Good arc starting.
    Higher range, lower fine will give "an aggressive digging arc that is good for vertical and overhead" according to one sa-200 manual.
    Name:  sa-200 arc settings.jpg
    May 2008
    Orange, TX
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2016
    Thank you everyone! This helps me alot
    Nov 2013
    Livingston, New Jersey, United States
    I don't know but was told say the 120 to 190 to subtract 120 from 190 witch is 70 so each 10 would be 7 degrees.
    John
    Sent from my XT1254 using Tapatalk
    Nov 2012
    Quote Originally Posted by johnrbauer View Post
    John
    Is that Fahrenheit or Celsius degrees?
    Nov 2013
    OK it is easier to figure 10 degrees I like that much better. Thanks for setting me straight
    John
    Apr 2008
    NW ON Canada
    John
    You got it, just in amps instead of degrees. Then add the 2 together for a total amp setting of the machine.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    MS
    Nathan, I visualize this just a hair differently but am doing the same things as everyone else suggested. Second gear is 120-190 amps. That is 70 amps of difference. I few the fine control in percentage. On the fine control 0=120 amps=0%, halfway is 50=155 amps=50%, wide open is 100=190 amps=100%. Same as what everyone else said but for some reason my brain has always interpreted it into percentages and that was easy enough to know amperage roughly speaking. You never know unless you put a meter on it, but who cares. When it is welding right you know and the numbers will get you close enough to easily fine tune it.
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    SA-250 TMD
    Squarewave 200
    Thunderbolt AC/DC
    1951 G.E. welder
    Nov 2010
    SE Nebraska
    Pretty clever for a beginner!
    -Doogie
    Miller 350P
    Miller Trailblazer 325 EFI w/ Excel Power
    Lincoln LN25 suitcase welder
    XMT 304/22a feeder
    Miller Syncrowave 350LX
    Miller Econotig
    Hobart Handler 140
    (2) Uni-Hydro 42-14
    Hypertherm 65 plasma
    WEBB Gap bed lathe
Page generated in 1,607,058,911.34758 seconds with 12 queries
