Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: Cast iron braze with aluminum bronze
    Big Lake/Monticello MN
    Re: Cast iron braze with aluminum bronze
    Quote Originally Posted by killdozerd11 View Post
    Dave i did sil-bronze with tig on some of the vintage race / rally cars
    The heat is much more controllable with tig than O/A ...Had too much dropped on the floor trying with O/A doing it uphill and in corners...
    Too much wide spread heat even with the smallest tip i had
    I kind of thought I might have that same result - that's why I chose tig too.
    I like OA in general but find tig to be better for nearly everything.
    Btw, what did you use the sil-bronze on?
    Syncro 350
    Apr 2010
    This was a Lotus Cortina that the guy rolled at a race a few years ago
    replaced top and whole drivers side
    he wanted sil bronze done on the seams and over layed on some of the welds
    and as long as he's paying ...I'll do it...that's expensive rod and the do make mig spools of it but real pricey stuff
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Cool pics dozer
    Syncro 350
    Jun 2016
    Back to the jungle
    Now give them a "bill" for $150/hr so their lawyer can go after the dirtbags at the shipping outfit. Three hour min.
    They wont be supergluing after that lesson
  5. #30
    Jan 2014
    Hallieford, VA
    Pretty work Dave.
    Jerry
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
  6. #31
    Apr 2007
    Poco British Columbia
    That is "sew" nice, I guess your reputation was hanging by a "thread"
    Bet they were glad you could fix it, the older generation is so much more appreciative.
  7. #32
    I need to try this process on some fugly CI I have from a woodstove part that broke (a dog that holds a panel in place inside, so it needs to be kosher).
    Tried "buttering" the break on both sides, and that worked surprisingly well. I'm hoping that if I match up the two broken sides, I can get it to "wick in" as you can with other kinds of brazing. I'll try it with the AC balance on 8 on the Sync. (I used 6 before, I think.) We'll see...if you don't hear back, that means it turned into another disaster...
    Honestly, I was surprised I could get it to stick at all. I've heard horror stories about woodstove cast iron getting full of carbon or whatever and being a royal bitch to accomplish anything with...
  8. #33
    I didn't butter the sides and it won't wick like soldering that I could see. I ground out the cracks and filled them back up like I was welding it.
    DC- works too for the process and I think it's a little more controlled for a small part.
    Syncro 350
  9. #34
    Thank you sir! I'll report back for good or ill...don't need the woodstove just yet – it's 88° here today!
  10. #35
    It was in the 20's this morning (fahrenheit) so my wood boiler has been going couple weeks now for shop and house.
    Syncro 350
  11. #36
    Oct 2012
    East Van BC
    I have used aluminum bronze to repair a cast iron drill press vice. I think I ended up using AC with the machine's minimum EN Balance. It didn't need fixing again in the six months I was still at the shop. I think a little bit of cleaning action helps with the crud coming out of the casting.
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Boice-Crane Band Saw
    Victor O/A
  12. #37
    Quote Originally Posted by Brazin View Post
    I tried my syncrowave 350 on max DC- (min DC+) and it did have nice clean color after welding.
    Running straight DC still had the same color after cleaning, but looked dull right after welding.
    I think you're right, the cleaning action can help.
    I'm no pro at it though.
    Syncro 350
Page generated in 1,713,308,817.42798 seconds with 18 queries
