Results 1 to 25 of 26
Thread: New Cutting and Fabricating project in Jim's Shop
    Oct 2007
    New Hampshire, North Carolina
    Normally I don't have the time to take on major jobs in my shop (Hypertherm and my wife keep me busy), however I agreed to design and build a good sized backlit sign for a local Auto Body business in my area......(just so happens that I need a few auto body jobs on my vehicles, and these guys are the best!). Here are a few pics of this project, which is a 4' high x 12' long steel two sided sign with cut out lettering and LED backlighting. The front and rear panels are 3/16" steel which will be allowed to rust naturally on the outside, but are painted white inside (for light reflectivity). The sign will weigh about 650 pounds when done.....so I will use my excavator to pick it up off my fab table and get it out of my shop! I'll post pictures as I get more done, and a final picture or two after installation! The first pic is the existing wooden sign (rotting after after 35 plus years), the new sign will drop right on the existing brackets.
    Difficulties? Cutting a 12' long sign on a 4 x 4 cutting table (12' x 4' sheets of 3/16" are heavy!). With mu son helping we were able to reposition and index for two cuts (8 feet) then spin the material around (and the cut file) for the last 4'.
Size:  98.1 KBName:  IMG_0264.JPG
Size:  117.6 KBName:  IMG_0263.JPG
Size:  106.1 KB[ATTACH=CONFIG]1668911[/ATTACH
    Jan 2014
    Hallieford, VA
    Re: New Cutting and Fabricating project in Jim's Shop
    Nice approach to supporting letter interiors Jim.
    Jerry
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Oct 2007
    When backlit and you have "stenciled" letters....I don't like the look. Hopefully these supports will not show as much!
    Feb 2017
    Perhaps a naive question - but I presume you cut the interior of the letters out by hand with a torch, once you welded on the back supports?
    Oct 2007
    I cut the lettering out with bridging to hold the inside pieces in place, then welded on the inside supports and cut the bridging out with a hand plasma. You can see the lettering as cut in the first two pics. If you look carefully you will see a mistake in my CAD drawing on one of the panels, fixed before I did the second! Jim
    Quote Originally Posted by robster34 View Post
    Mar 2009
    MN
    That's going to be a nice birdhouse. Good job!
    My name's not Jim....
    Feb 2009
    Chicago
    Sign looks like wood when it's all done
    I still never understood how people index parts so well.
    Great work
    Hypertherm Powermax45
    2015 AHP Tig
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    ViperMig 180
    Razorweld, Vipercut/Vipermig, SSC Foot Pedal & MK Products & Atlas Positioner Dealer
    Oct 2007
    Birds, hornets nest, etc. It will need cleaning on occasion! One side of the sign will hinge down (about 300 lbs worth!) for cleaning or any maintenance of the LED's.
    Mar 2009
    MN
    Just wanted to make sure you saw it coming.
    Oct 2007
    Its starting to get real heavy....Name:  IMG_0268.JPG
Size:  109.0 KBName:  IMG_0269.JPG
Size:  96.0 KBName:  IMG_0270.JPG
Size:  138.2 KBName:  IMG_0272.JPG
    Feb 2015
    Austin, TX (now) -- Boston, MA (then)
    Awesome work Jim!
    Millermatic 211 w/Spoolmate 150
    Hypertherm PMX45XP
    Wishlist:
    HTP Invertig 221
    Oct 2007
    A little more progress.....simply have not had much shop time in recent weeks, the pesky day job is keeping me busy! Now to sand the faces, fabricate the electrical box and covers for sides and top, put it outside and get the rust / patina started. If anyone is interested in LED's that can live in wet / hot / cold climates like here in NH....go to Sign Lighting World. Great products, good prices and incredible tech support for choosing the right LED's for your project. These may even be too bright, however a dimmer module can take care of that...which we will determine at installation. Jim Colt Hypertherm
Size:  83.1 KBName:  IMG_0390.jpg
Size:  69.2 KBName:  IMG_0393.jpg
    Sep 2011
    USA
    Looks Good Jim. I'm not crazy about the rust idea, but the customer is the boss.
    ________________________________
    Everlast PA140ST
    Everlast PowerPlasma 50
    And no you can't Borrow them
    Mar 2005
    Under a Rock
    The sign is ok...
    But I'm diggin the Kubota tractor...
    is that a B7200?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Oct 2007
    Nope, it is an L4310 . Great tractor, I also have an RTV900 utility vehicle.
    The sign is ok...
    is that a B7200?
    Mar 2005
    Under a Rock
    Nope, it is an L4310 . Great tractor.
    Cool.
    I just bought a kubota BX ... front end loader is very handy to have.
    great machines... love the Oranges.
    Hypertherm PM 45
    HTP 221
    Jun 2013
    Hi Jim, curious why you didn't choose a weathering steel for the project if a rust finish was the goal?
    Oct 2007
    The inside all needed to be painted with a flat white finish for good even reflectivity, as well as a rust preventative. Only the face will remain unfinished. Also, I would have had to special order corten steel in a 12' x 4' x 3/16" plate size here in NH, adding substantially to the cost. My experience is that this P&O plate will start out (boosted with rust promoting chemicals) a kind of orange looking rust, then over tome will reach a deep brown. It is exactly what the customer wanted. Jim
    Quote Originally Posted by weldinON View Post
    Delaware
    Jim, you and your son did a great job on that sign. The customer should be very happy with it.
    Now if you ever plan on retiring you can make a few bucks doing signs.
    Oct 2007
    George, My son moved to Colorado almost 3 years ago. I miss him in the shop, but it is just me there now! I don't do much paid work at all as the day job keeps me busy. This sign was a request from a friend that has taken over the family body shop...and needed to replace the decades old wooden sign with one that hopefully will last just as long!
    Jim
    Jun 2016
    Back to the jungle
    Simple. Clean. Tough. Unlike the POS they had before. Good work.
    May 2015
    Barre Town, VT
    That looks great!
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    Feb 2010
    Mn / Tx
    When you put the power to it it, it puts it in a whole new light. Looks great!
    Jan 2017
    Dallas, TX
    Great job and thanks for sharing the pic's!!
    Oct 2007
    There will be more at install time, sign is outside getting its "patina". (cost more than just plane old rust!). Jim
Page generated in 1,593,890,161.00791 seconds with 12 queries
