Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Thread: random welds/repairs
    Big Lake/Monticello MN
    The farmer's drawbar:
    Weld hole closed, drill to 1-1/8", add a top bar drilled to match with dog-leg
    You can see from the damage that the pin was much smaller than the hole.
    Name:  hole (Medium).jpg
    3/16" 7018 to speed up the process.
    Name:  hole2 (Medium).jpg
    Wood line up dowel.
    Name:  drawbar dowel (Medium).jpg
    Jig on the bottom of railroad track. Bend up to 90 deg, then quick tack the 2nd piece, bend down and let cool, cut welds to take out.
    Name:  drawbar jig (Medium).jpg
    I shaped the top piece to match the bottom.
    Name:  drawbar side (Medium).jpg
    Syncro 350
    Re: random welds/repairs
    Installed:
    Name:  drawbar installed (Medium).jpg
    Top view.
    Name:  drawbar top (Medium).jpg
    Putting some TIG welds on my press brake (goes in my 25 ton hyd press).
    The upper blade guides.
    Name:  press brake1 (Medium).jpg
    Back stepped to control warping.
    Name:  press brake3 (Medium).jpg
    Syncro 350
    Very ugly trailer.
    It was a boat trailer that he wanted squared off and stake pockets put in.
    His request was to plate the sides with 2" square and then close in the front, trim fenders to fit.
    I bent the stake pockets and light mounts out of 1/8"
    I shortened the hitch tube about 4 feet.
    Name:  trailer front (Medium).jpg
    Marked fender with tape, cut with plasma.
    Name:  fender marked (Medium).jpg
    Fender cut, love how plasma cutters do their thing
    Name:  fender cut (Medium).jpg
    Syncro 350
    CT
    Not bad for a hobbyist!
    Miller Multimatic 255
    MS
    Very nice work Dave. We always called (I am fairly sure this is correct terminology) that piece on top of the drawbar a "hammer strap".
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    SA-250 TMD
    Squarewave 200
    Thunderbolt AC/DC
    1951 G.E. welder
    Hay rake needed a new bar bent and installed.
    I torched out the broken parts so it could slip into the original holes.
    Also welded some cracks on the 3 point.
    Name:  rake (Medium).jpg
    Name:  rake3 (Medium).jpg
    The door in this trailer had about 8 broken welds on the tin (about 1/16" thick) and needed 2 braces and 1 higher top rail.
    I used 3/32" 6011 (didn't have any small 6010) since many of the broken welds were in corners that I couldn't clean paint out of.
    Just continued using it for the rest of the welding - they were a little rough looking but he liked them just fine
    Name:  gate (Medium).jpg
    Name:  inside (Medium).jpg
    Name:  6011 weld (Medium).jpg
    Syncro 350
    Darn, I was shooting for "part-time semi-pro"
    Quote Originally Posted by Blocker View Post
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    Thanks I definitely used a little hammer persuasion on that drawbar - lol
    Syncro 350
    MS
    Welding on used stock trailers is a long misunderstood form of anger management training Dave.
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    SA-250 TMD
    Squarewave 200
    Thunderbolt AC/DC
    1951 G.E. welder
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    Ha! I bet it would be a good way to watch people stack up frustration points like a video game
    The small 6011 worked out pretty well for it - tacks and welds were all at around 65 amps or so - none of it looked "pretty"
    Syncro 350
    Nov 2014
    PDX PNW
    Quality work is what I'm seeing!
    MS
    Sometimes you have to glue the old paint to the new metal and get down on one knee. Horse trailers are almost always in better shape. Do you have the summer off Dave....to indulge in your vices?
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    SA-250 TMD
    Squarewave 200
    Thunderbolt AC/DC
    1951 G.E. welder
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    Yep, summer off from teaching - so far have welding, carpentry and mechanic work lined up. Not sure about the dump truck driving yet.
    Have an applied calculus class to prepare and I'm thinking I'll get approval to add some pipe welding to the welding class. I'll have to practice! LOL
    Syncro 350
    Thanks moto
    Syncro 350
    MS
    I hope you get your pipe class approved. Do you let them weld any aluminum or other exotic materials?
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    SA-250 TMD
    Squarewave 200
    Thunderbolt AC/DC
    1951 G.E. welder
    Jul 2013
    Pine City mn.
    Is there enough space between those hitch pieces to go over his drawbar? Depending on what he pulls it with that looks tight. Otherwise very nice projects.
    Jon
    Yeah, I know, but it'll be ok!
    Lincoln Square wave 255
    Miller Vintage mig
    30a spoolgun
    Thermal Dynamics Pacmaster 100xl plasma
    Smith mc torch
    Ellis 1600 band saw
    I started a couple of them on tig aluminum towards the end of the year, they planned to take another course with me in the upcoming year so I ordered some aluminum for them.
    Syncro 350
    Quote Originally Posted by welderj View Post
    Jon
    He said his hitch was a little over an inch and requested 1.5" clearance. It ended up a just little more than that so hopefully it's ok for him.
    I drilled the 1-1/8" hole he requested with a standard 1" bit, then a step bit that was 1-1/8".
    That step bit barely survived - what do you use for large holes?
    Syncro 350
    I have a set that is 1" thru 1.5" with 3/4" shanks. Bought it off eBay a year or 2 ago. Certainly not the best drills, but decent enough for the price.
    Thanks, I will check into that. At least I can sharpen twist bits fairly easily.
    Syncro 350
    Nov 2012
    new york city
    nice work dave. those welds look fine from where i'm sitting.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Soda springs,Id
    Wood line up dowel.
    Dave, I can almost guarantee a 1 1/8" pin wont be used to hook up to the tractor.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Mar 2016
    Minneapolis MN
    Your posts here nicely clear. Hope the weather is cooler than down here in the cities...
    Mike
    He said his pin is 1" and he wanted it 1-1/8" drilled - hope he's right
    Syncro 350
    Quote Originally Posted by cloudman View Post
    Temps made it to 69 degrees today
    ...but the heat is on its way according to the weather guessers...
    Syncro 350
    Quote Originally Posted by docwelder View Post
    Thanks - He's just too old to do it all himself anymore - and he was happy with them so I must have done ok
    Syncro 350
Page generated in 1,713,305,337.09340 seconds with 18 queries
