Results 1 to 10 of 10
Thread: Novice welder
    Lone Star TX
    Novice welder
    I am teaching myself stick welding; I am in need of the user manual for the following welders:
    1. Sears Craftsman 230 Amp Continuous Control Arc Welder Model 113201330
    2. Sears Craftsman 230/140 AC DC Infinite Arc Welder Model 93420129
    Where can I find them?
    Thanks in advance.
    Mar 2017
    Re: Novice welder
    welcome have you tried google?
    Re: Novice welder
    Welcome!
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    Lone Star TX
    Re: Novice welder
    I did. I also tried sears parts, it is taking forever and no answer yet.
    Sebeka and Bemidji MN
    Re: Novice welder
    Those are pretty simple machines - what would you like to know about them?
    Bottom one was a 3 second google search
    https://www.searspartsdirect.com/par...CWELDER-manual
    https://www.searspartsdirect.com/mod...Term=113201330
    Airco 300 - Syncro 350
    Lone Star TX
    Re: Novice welder
    Thanks a lot for your replies.
    I am being cautious because these machines have not been used in a long time and I am not the original owner. Both of them started. I can't change the amperage in the the older one (230 AC).
    Jan 2014
    First state
    Re: Novice welder
    Quote Originally Posted by yosoypepe View Post
    If it has been setting for a long time, it may take a little finesse to move the amp control. Try loosening the knob, then pushing it back and forth several times. I have a similar Craftsman AC buzz box, and it sat for years unused, as I just use my Miller machine. Some months ago, I decided to do a little stick welding with it, and it also was stuck, until I jogged it. Worked great, and still welds just as good as ever.
    BTW, I bought it new in 1980.
    Millermatic 180 Mig
    Lincoln IdealArc 250
    Thermal Dynamics Cutmaster 42
    Cut50 Plasma cutter
    Craftsman(1980) buzzbox
    Re: Novice welder
    Some of these are built by Twentieth Century, now Century. Pretty basic. I couldn't lay hands on my Twentieth Century manual from 1974. What's left to know?
    Lone Star TX
    Re: Novice welder
    Thank you so much.
    With a lot of determination and some luck I got it working.
    Lone Star TX
    Re: Novice welder
    I cleaned it and removed some rust, it is working now.
Page generated in 1,607,105,653.13332 seconds with 13 queries
