Page 10 of 11 FirstFirst ... 891011 LastLast
Results 226 to 250 of 275
Thread: Primeweld AC/DC Tig 225X
  1. #226
    Re: Primeweld AC/DC Tig 225X
    Quote Originally Posted by rb70383 View Post
    Figures the newer model comes out after I order one. Lol Either way. My first tig. Is this still a good kit that was mentioned earlier in the thread:?
    https://weldmongerstore.com/collecti...ardware-bundle
    Anything else I should look into getting? Only welding I do now is mig. While researching there are all kinds of nifty things to get....
    I've read that tungsten colors aren't as big a concern as before with the transformer machines?
    Tig welding has a steep learning curve. I haven't even lit an arc yet...
    2 percent lanthanated is a good choice. Might want to get a torch lead cover as well.
  2. Likes Rondo liked this post
  3. #227
    Laredo + Midland/Odessa
    Quote Originally Posted by DavidR8 View Post
    Dustin Gallagher from Primeweld just said "We are working a digital welder made in Italy will be comparable to miller quality. Price point will be around 2600usd"
    I wonder who in Italy makes a top quality welder?
    @Oscar, are you aware of any decent Italian machines?
    Edit to add photo from Dustin.
    Attachment 1717729
    Yea, there's a few in Italy that I know of. For sure I know it's not Stel; they're moving forward, not backward. That welder looks like it came from 2010
    This is what Stel's current line up looks like.
  4. Likes DavidR8 liked this post
  5. #228
    Apr 2007
    Portland, OR
    Does anyone know how to tell if these are in stock ready to ship?
    What pedal is shipping with them?
    Is there a receptacle for cooler?
    Miller Syncrowave 180SD
  6. #229
    Apr 2020
    Canada
    Quote Originally Posted by slodat View Post
    Check the Primeweld website for current status.
    It ships with an SSC style pedal and I believe the new units have a 110v receptacle for a cooler.
    David
    Millermatic 130
    Primeweld 225
    Victor Journeymen
  7. #230
    Apr 2007
    Portland, OR
    Thank you! I called them. You are correct on both: SSC style pedal and 120v receptacle for cooler. Order placed!
  8. Likes DavidR8 liked this post
  9. #231
    Apr 2007
    Portland, OR
    How long is the included torch? I’m wanting to order a torch cover.
  10. #232
    Apr 2020
    Canada
    It’s the shorter of the two lengths CK offers.
    David
    Millermatic 130
    Primeweld 225
    Victor Journeymen
  11. Likes slodat liked this post
  12. #233
    Delaware
    The receptacle is a 120/240 volt set up for the Primeweld cooler. The CK17 torch has a 12 1/2 foot cable.Name:  20200626_170935.jpg
  13. Likes DavidR8 liked this post
  14. #234
    Feb 2011
    Thanks for the offer mechanic416, I finally stepped up to a tig as I have an aluminum project I want to do.
    I got my welder yesterday, I haven't even pulled the welder it self out, so I haven't laid eyes on the outlet in the back however, I'm out to get a tig hose cover and a pack of 2% as recommended, Thanks again. pics of the accessories,:
    Ok went through weldmonger, got a tig torch stand, a hose cover and a combo pack of the 2%. Its all the little thigs that add up as well.
  15. Likes DavidR8 liked this post
  16. #235
    Jan 2021
    Somewhere South of Denver
    I just read this entire thread and want to say thanks to all the positive posts, and even the few negative ones. I saw this welder used in a YT video and that got me to doing more research on it. I'm a complete newbie to welding so I'll have quite a few questions.
  17. Likes superwelder, John Baptist liked this post
  18. #236
    Apr 2007
    Portland, OR
    Received my welder today.
    I ordered the Furick cup mounting direct from Furick. This is my first air cooled torch (I have a water cooled torch on my Syncrowave). The rear caps don’t seat all the way into the torch body. Is this normal?
    This is how I have it going together:
    Is this ok/correct?
  19. #237
    Apr 2020
    Canada
    Is this ok/correct?
    I’ve never used those caps but if the o-ring has seated and the tungsten is snug then I’d say you’re good to go.
    David
    Millermatic 130
    Primeweld 225
    Victor Journeymen
  20. #238
    Apr 2007
    Portland, OR
    Another photo showing the back better.
    With the long back cap.
  21. #239
    Delaware
    You need to change a few of your settings. You don't need pre flow unless you plan on doing SS. You need to up the post flow to about 7 seconds and the switch bottom right need to be set on the bottom not the middle.
  22. Likes ronsii liked this post
  23. #240
    Apr 2007
    Portland, OR
    Thank you! I’m still reading through the manual.
    Can you answer my back cap question? Is this normal/ok?
  24. #241
    Delaware
    As long as the o-ring seals it will be fine. A little silicone grease on the o-ring will help it seal also.
  25. Likes ronsii liked this post
  26. #242
    Jan 2021
    Did you order the TIG kit? I've been looking at that kit, but I don't know enough about the components to know if it fits the TIG225x that I ordered. I know the torch that comes with the 225x is a #17, but that's all I know about it.
    Jim
    PrimeWeld TIG225X
    2017 F-350 CCLB 6.7L
    2013 Polaris Ranger 900 XP in 2006 Fleetwood Gearbox 220FB using 3" Andersen WDH
    I don't always tow heavy, but when I do, I use my Superduty.
    Here fishy, fishy... ¸.·´¯`·.´¯`·.¸¸.·´¯`·.¸ >< ((( °>
  27. #243
    Jan 2021
    The PrimeWeld manual calls for a 50 amp breaker for 220v. But in the specifications section, it looks like it's only going to pull about 33 amps. I have a 40 amp 220v circuit in my garage that I've used for 20 years for tables saws and an EV. After an email conversation with my electrician (a relative), I think it may take a lot of work and expense to upgrade the circuit to a full 50 amp rating.
    I don't want to be unsafe. I really hate half-assing things. But now is not a good time to have to shell out what he's recommending, which is all new wiring from the main panel, to include replacing the existing garage breakers with GFI.
    Is the PrimeWeld going to work on the existing 40 amp circuit? I'm not welding thick aluminum, not more than 1/8". This is all small stuff right now, just to learn how and get familiar with the machine.
    Jim
    PrimeWeld TIG225X
  28. #244
    Apr 2020
    Canada
    I’ve got mine on a 40A and it works great. Had it up to 200A and no problems. At the time the wiring was exposed in the wall and it wasn’t even warm.
    David
    Millermatic 130
    Primeweld 225
    Victor Journeymen
  29. Likes HRTKD liked this post
  30. #245
    Delaware
    Quote Originally Posted by HRTKD View Post
    Yes it will work fine on a 40 amp line. Please don't cut the plug off the welder. Just install a new 6-50R to plug it into.
  31. Likes HRTKD liked this post
  32. #246
    Jan 2021
    I have a question about how to know what the settings are on my machine. The AC Frequency knob has a range of 40 to 200. In the position shown in the picture, what would you come up with for a number? I figured the range is 160 (200 minus 40) so half of that would be 80. 80 + 40 = 120. The knob is just a bit counterclockwise of center, so I'm guessing the frequency is 115 Hz.
    Jim
    PrimeWeld TIG225X
  33. #247
    Apr 2020
    That’s correct, you are sitting around 115’sh.
  34. Likes HRTKD liked this post
  35. #248
    Feb 2021
    Mines been working fine on a 30 amp circuit.
  36. #249
    Delaware
    it starts at 40 then the first gray line on the left is 80. Straight up on the gray line is 120. Next gray line on the right is 160 and then on to 200
  37. Likes HRTKD liked this post
  38. #250
    Jan 2021
    Quote Originally Posted by Tillerdemon View Post
    Thank you for the confirmations.
    Jim
    PrimeWeld TIG225X
Page generated in 1,713,308,940.85747 seconds with 21 queries
