Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 76 to 100 of 192
Thread: Cutting 6x6 tubing, hiring help
  1. #76
    Feb 2015
    North Sewickley Pa. Shop in Monaca
    Re: Cutting 6x6 tubing, hiring help
    Old school water tank building co...... Most up to date tank builders use flux-core with a feeder.....usually with a Bugo - Track......
  2. #77
    Ct
    Moving 6x6 tubing around the shop isn't easy, putting then up on horses, dealing with the drop, that's why I wanted to cut them with the plasma, I have to finish these tomorrow by myself.
  3. #78
    Aug 2006
    MASS.
    It is when u are setup right,you need build one of these.This is not the wood business stuff gets heavy REAL fast.This will lift around 1800lbs,it swings out my front bay door.And as u can see my Tb300d can be loaded, unloaded fast into my 350UB.
  4. #79
    Dec 2003
    Fairfield,CT
    Quote Originally Posted by admswelding View Post
    My saw is setup in shop ready to go just push on button.And your not gonna beat it with a 6" wheel.LOL
    Right on...
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
  5. #80
    Ct
    Apparently I'm not set up right, forgive me
    My bandsaw cannot cut 6x6 at 45 degrees
  6. #81
    Aug 2006
    MASS.
    I just gave u the design and pic,now get on it!!
  7. #82
    Ct
    About 5 minutes worth of plasma cutting, and this is what I get, I'll need to touch it up with a grinder a little but it's pretty darn good, that's what I was looking for. https://images.platforum.cloud/uploads/201...e177cca28b.jpg
  8. #83
    If a perspective employee takes a measurement and says, 26" and 5 lines you're in trouble.
  9. #84
    Jun 2018
    NC
    I knew a guy that couldn't read a tape so he would just keep his thumb on the tape at the spot he measured and walk over and transfer the mark where his thumb was at onto what he was cutting, It worked great untill the peice was more than the width of his arms length.
    CR
  10. #85
    In the past I made 45 degree jig for band saw. It was faster than resetting band from 90 to 45 degree cuts .
    Any use jig for 45 degree and it was right every time.
    As tape goes the worse was 120" and 12 ' I do not know how many time a employees would make cut for 120" when I had 12 feet on the cut list or need cut 12 feet at 120 inches.
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  11. #86
    PS: Just try making left and right hand parts . It was worse so bad when left and right hand came up I had to go shop and mark all parts on how to make part
    I have do marking 3,000 parts so done right
    Sent from my SAMSUNG-SM-J320A using Tapatalk I
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  12. #87
    Oct 2009
    Foley, Al
    Feet have no place in a fab shop. List/say/measure all dimensions in inches.
    Who is John Galt?
  13. #88
    Northern California
    I went thru this a lot while hiring weldors and machinists. It took a long time for the truth to sink in. While you are trying to coax adequate performance from an inadequate employee, you are missing out on the possibility of hiring an adequate (or better) employee. Don't waste time, cut him loose. My "keepers" (long term employees) started keeping a list of the quick turnovers. It ran over 100 in the twelve years before I "retired". I'd guess maybe one in twenty was a "keeper". You have to kiss a lot of frogs.....
    South Bend Heavy 10L Lathe
    Kent 9x42 Vertical Mill
    AHP Alpha-TIG 200x
    1974 Lincoln AC-225
    HF 4x6 Bandsaw
    Kalamazoo 8CW Horizontal Bandsaw
    Welding: It's like sewing with fire.
  14. #89
    Ct
    Quote Originally Posted by bassboy1 View Post
  15. #90
    Feet and inches on the tape
    Good luck and some drawings come with feet and inches all was inches only but still there is tape.
    Now to find a tape with just inches
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  16. #91
    Sent some CAD drawings in inches only to an architect. Architect sent them back in feet and inches.
  17. #92
    Back 30 year ago Most drawings where in feet and inches.
    All drawings father did was feet and inches, it onle took me 20 years to have my father make shop drawings in inches.
    I ever received drawings in metrics
    My self I can work in just inches or feet and inches.
    I do like just inches
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  18. #93
    Ct
    So now the guy is upset, claims I owe him $200 for 9 hours, during which he only made 4 cuts in the 6x6 tubing, 3 of which had to be completely redone. He says my shop isn't set up right, he was tripping the breaker using the plasma cutter, says if I had the right breaker it would act differently, blah blah blah blah. I'm tired of dealing with people who don't know what they're doing. This just adds one more bad experience to the other bad experiences that I've had trying to hire someone.
  19. #94
    Aug 2006
    MASS.
    I don,t even waste the time giving anyone a shot anymore.
  20. #95
    Ct
    I do plan on making one of those cranes, that's a good setup, I'm building a new shop soon so I'll have the opportunity to put one of those in.
  21. #96
    Ct
    So now he told me to pay him the 200 or I can pay a dentist
  22. #97
    Sounds like real winner
    I would have the police talk to him.
    Next they will he will find ever government agency to take you. Just tell you to call the police on this guy.
    If show up again have this guy your lawyer Smith and Wesson
    Good luck
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  23. #98
    It sucks that he did not work out but if you were paying him by the hr then you do need to pay him what ever time he worked. Even if he did very little. That is the way it is good or bad. If he is threatening you then you need to get the law involved. as far as paying him you have a week to write the check.
  24. #99
    Jun 2018
    NC
    Tell him that's a good idea because dentist have brains and will probably do a much better job cutting that tubing.
    CR
  25. #100
    Aug 2006
    MASS.
    He,'ll pound your teeth in,you better watch out.
Page generated in 1,713,301,284.67145 seconds with 18 queries
